47 -
Everything posted by Oliver Hauser
Thanks so much Guys.
Hi Guys, This could be a silly question but does anyone know how to change the Z-axis(height) of the origin point?
@Sky Thanks Sky.
@Sky Thanks Sky, Do know where I can find that folder on Windows? The only files that I can find (C:\Program Files\Vectorworks 2019\Libraries) are below. - [Renderworks - Textures] - [Objects - Ent Lighting Gobos]
Hi Guys, I'm having this problem with 2019. Any resolutions yet besides an uninstall? Thanks.
Corrupt /missing file preventing opening of Vectorworks
Oliver Hauser replied to Oliver Hauser's question in Troubleshooting
Thanks so much Pat. -
Oliver Hauser posted a question in Troubleshooting
Hey Guys, For some strange reason my antivirus is picking up a certain file as malware in VW2019 and quarantining it, therefore preventing me from opening VW. Below are the details: File Name: C:/Program Files\Vectorworks 2019\Plug-Ins\Plug-In Support.vlb Threat Name: Gen:Variant.Bulz.14887 Has anyone experienced this? -
Unfortunately I have not found a work around yet, I've tried all sorts of methods. I hope the VW team resolves this soon. I would love to use gobos in my renders more often.
Thanks so much. Yes, totally, I have been doing so but still not much luck unfortunately. Will let you know if i find anything.
Still having this problem in VW2019. Has anyone found a solution by any chance? For me it's pretty random, sometimes it works and sometimes it doesn't. Tried pretty much everything in this thread plus replacing fixtures and playing with beam angles and focus. Nothing really works consistently.
Benson, you are the man. Thank you for this tip even if it is 10 years later.
Dammit!! That did it. Thank you.
Hi Guys, Hoping someone can help. I've created a loft surface and added a texture. When i render in either custom or OpenGL all i get is a wireframe mesh render. Does any one know what i might be doing wrong?
Hi Guys, Anyone else experiencing issues with SP3.1 update on W10? Basic functions are taking incredibly long to execute. for example, The softgoods tool freezes VW temporarily for about 5min every time I use the tool. Extremely frustrating. Importing 3ds files are also taking forever to execute and sometimes crashes VW. I didn't have this issue with SP3. Any help would be appreciated.
3D Lighting Symbols 3D Rotation Not Working for all Symbols
Oliver Hauser replied to rmarkowi's topic in Entertainment
Hey Guys, I know this is an old post but I'm having a similar issue with certain light symbols in vw2019sp2. When I rotate a symbol using 3D orientation in the OIP, only certain parts of the symbol rotate while the others stay fixed. I've noticed it happens mainly to symbols that have nested objects. Is there a magic way to fix this by editing the symbol directly? Thanks in advance. -
Instrument summary text disappearing Spotlight 2019 SP2
Oliver Hauser replied to Oliver Hauser's topic in General Discussion
Thanks a mil Mark. Yes exactly. Will try this workaround in the meantime. Just a note to anyone who is using this workaround. Make sure you tick the "plug-in parameters" check box in the eyedropper tool settings before using the tool. Cheers. -
Spotlight Inventory Color Summary Not working
Oliver Hauser replied to David Meagher's topic in Entertainment
Having the same issue. -
Title Block Manager crashes VW2019 Sp1
Easiest fix is to move the file to your desktop and work on it from there. Once done you can move it back to where ever you need for archive. -
Stage tool elevation problem VW2019 SP1
Oliver Hauser replied to Oliver Hauser's topic in Entertainment
Thanks Kevin. -
Hi Guys, I'm experiencing problems with the "Stage" tool(not "Stage Deck" tool) in VW2019 SP1. The default height in the OIP says 1219mm but when I change to Front View or any other view for that matter, the stage is flat (0mm). This is definitely a bug, I have confirmed this with other users. All the best.
Hey Mark, Glad to hear I'm not the only one. I use the Stage tool every now and then to redraw theatre stage layouts. Quick and easy to draw over PDF's with it. Yeah, I sure will. -
Hi @markdd, I think you might be referring to the "Stage Deck" tool. I'm referring to the " Stage" tool. Let me know if you have the same issue. All the best. -
Hi Guys, Is anyone else experiencing problems with the stage tool in VW2019 SP1? The default height in the OIP says 1219mm but when I change to Front View or any other view for that matter, the stage is flat (0mm) Any help would be appreciated.
