Sade
84 -
Everything posted by Sade
It's my first time using the space tool, I copied and pasted from another document but it says 'not specified' how do i fix this to show dimensions?
I recently downloaded enscape for sketchup, it also downloaded as a vectorworks plugin too. How do I uninstall it as ever since I downloaded it I have been having problems with vectorworks.
Hi, I'm trying to delete an object perpendicular to the object and for some reason the snapping element has disappeared. It was working earlier. I also can't find the snapping tool option.
I have a vectorworks drawing, but due to cadblocks and other reasons there are many duplicate lines. I wish to laser cut the drawing however I need to get rid of these duplicate lines. I was told Autocad has an overkill command, does vectorworks have something similar?
that's exactly what I meant thank you very much!
Hello, Is there a way to change all viewports to the same page size at once? I was given a document with hundreds of viewports and the page sizes are wrong. I would love to avoid having to do it manually one by one. Thanks
@Jesse Cogswell Thank you again!!!
- 5 replies
- help
- troubleshooting
(and 2 more)
Tagged with:
@Jesse Cogswell Hi again, sorry to ask but could you also convert the file below for me please? 3d model.vwx
- 5 replies
- help
- troubleshooting
(and 2 more)
Tagged with:
@Jesse Cogswell Thank you very much!
- 5 replies
- 1
- help
- troubleshooting
(and 2 more)
Tagged with:
@michaelk I will do that thank you!
Hey guys, I posted earlier about a predicament regarding not being able to open a 2021file in 2020. I've attached it below would someone mind converting it to an earlier version of Vectorworks? It would be much appreciated!
- 5 replies
- help
- troubleshooting
(and 2 more)
Tagged with:
So I created a file in Vectorworks 2021 want to send it to my friend who is using the 2020 version. I no longer have access to it because my free trial ended and wasn't aware that it was not compatible is there another way for me to access the file so I can send it to my friend?
I recently learned how to use both the sectional viewport tool and the Helidon tool in Vectorworks. I have created a 3D model for my university project that is based in Italy, I enabled shadows for the OpenGL rendering option, I was wondering is there a have the shadows come up whilst using 'sectional viewport'? Also can is there a way to enable shadows for the Hidden Line rendering option?
I'm having trouble using the 'hidden line' rendering feature. The hatches should be below the walls and furniture but for some reason it covers it, I have tried 'send to back' but yet that does nothing. Does anyone know how I can fix this? However it does work in OpenGL(screenshots attached below)
I know in Vectorworks you can import slopes but is it possible to make an object that has already been created slope? I need the highlighted object to slope down is this possible?
For some reason I have this object which follows my screen on every vectorworks file I've been working on lately. I created the shape a few weeks ago but noticed that it just won't disappear any ideas on why this is happening and how I could get rid of it? Screenshot attached below, it is located just above my cursor towards the bottom of the page and is light grey.
When I try to export my drawing as a PDF it does not come out fully and I'm not sure why. Attached below is what it looks like in Vectorworks and what it looks like after being exported as a PDF. Also the part of the drawing that did not come out is a hatch if that helps
- 2 replies
- help
- troubleshooting
(and 2 more)
Tagged with:
I'm trying to do an isometric at 45 degrees but vectworks offers one at 30 degrees is there anyway to change this?
I know you can choose the height in the properties section but the only options I can see is 3m, 4m and 6m
@Hans-Olav Thank you very much. If i want to edit the height of the tree do you know how I could do that?
Hi guys, I'm trying to put some trees in my plans and I would like the trees in the plans to match the sections I will do later on by doing a 3D model. I did some research and I found out about the VBvisual Plant and it was supposed to be under the 'Visualisation' pallet but I can't seem to find it. Does anyone know how to access it o Vectorworks 2019 or have another solution to add 3D trees?
@ASagatovVW Thank you!
For some reason when I try to draw lines this purple things flashes on the screen, does anyone know-how to fix this?(picture attached below)
Usually, when I finish a drawing or model in Vectorworks I export it as a PDF but now I need to export it as an image file. This is going to sound a bit stupid but how do I export an image file as the size I want it? My page size is set to A3 already and I find that with exporting an image file it doesn't follow the constraints of the page. I tried to set the dimensions to A3 page size and export it said something about it being a huge file and then the program crashed. (screenshots attached of what I wanted to export in the program vs what came out)
- 1 reply
- 1
