Parker Battle
12 -
Reputation
0 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Hello, I am having this issue within sheet layers on my viewports. The 3d part of the device is on top of the 2d elements. Sometimes when I change a setting, it'll get fixed but then revert after panning or zooming. When I export to PDF, only the 2D elements show. I guess I am trying to turn off just the 3D element. The view is Top/Plan. Thanks. Please see screen shot
@Tamsin Slatter Thanks for looking at this. The viewport is to a reference. In the reference file, there is not a reference within it. The way I have this current document setup is I have three design layers each with a viewport to the reference. These three viewports are stacked on top of each other. So for Instance, layer "Plot Ref - Fixtures" has just the 'fixtures' layer turned on in the viewport to the reference. 'Plot Ref - Arch' has just the 'arch' layer visible in the viewpoert from the reference. But if I go to the 'Plot Ref - Fixtures' layers viewport and try to make the 'arch' layer visible on that viewport, it goes blank. Does that make sense? Thanks!
I am referencing a file and a viewport connected to it. If I change the viewport to add a layer from the reference file (make it visible), that entire reference disappears. If I make it invisible, it is ok. The reference doesn't show, the viewport is still there. Here is a screen recording. https://www.dropbox.com/s/qj42s8pzvzd78mn/VWX Ref Issue.mov?dl=0 Thoughts? Thanks!
I put my resource manager on my second monitor. When I am working in other apps and then pop back to VWX, the resource manager goes back to the other screen with the rest of the app. It takes some time, not automatically. Is there a way to keep it from popping back?
After updating to 2019, when I choose page size unavailable in page setup, All the paper sizes are weird. ARCH D is 35.5 x 23.19, ARCH C is 23.5 x 17.19, ASME A is 10.5 x 7.69, etc. I have looked around at different xml files trying to see if those values are in there somewhere, no luck. Any idea on where those values come from and why they are off? Thanks!
Well, I walked away for an hour and now it's working. Not sure, but I am glad I know about the naming thing now. Thank you all!
I've looked through my symbols a few times now. Don't see anything.
I did.
Nope. Sorry that didn't find anything
Figured out why it disappeared. Symbol name in the position didn't match anymore.
Good to know. That fixed a symbol that was named Balcony Rail. When I renamed it and renamed the position, the position disappeared, position label stayed. However, I can't find symbol or class named Box Boom SR or SL. Is there a way to search through the file for that name? Nothing comes up in the resource manager
When I try to name a position, such as "Box Boom SR", it claims the name already exists, but it doesn't. I know it doesn't because it doesn't when I pull up a list in find and replace, it is not there. v.2017
