ComputerWorks
    32
Everything posted by ComputerWorks
  1. Version 1.0.1
    64 downloads
    This node will provide you with the coordinates of all four corners and the dimensions (width and height) of the bounding box. Get Bounding Box v2 is a modification by ComputerWorks GmbH based on Get Bounding Box. Compatibility: Vectorworks 2019 and higher.
  2. Version 1.0.0
    56 downloads
    This node returns all objects from groups chunked into separate lists according to the group they were previously part of. Mind you: this node will ungroup your original groups, so make a copy of it first, if you wish to keep the groups. Ungroup to List was created by ComputerWorks GmbH. Compatibility: Vectorworks 2019 and higher.
  3. Version 1.0.0
    37 downloads
    With a single click this node provides the user some of the most commonly used operating system and Vectorworks information. There's an option to see the information as an alert additionally to getting the data via out-ports. For more experienced users this node can serve as a template for their own custom nodes and networks when system information is needed. Get System Info was created by ComputerWorks GmbH. Compatibility: Vectorworks 2019 and higher.
  4. Hello Mi&D, the tool is already using new nodes, so it's only compatible with Vectorworks 2019 and higher. Regards, CWD/ala
  5. Version 1.0.0
    114 downloads
    This tool was commissioned by ComputerWorks GmbH edited by: Markus Graf and Pascal Völz supervised by: Antonio Landsberger Compatibility: Vectorworks 2019 and higher. Area Verification is a Marionette tool used to graphicallly and tabularly verify the surface area of spaces/rooms (circle, rectangle, poly line & polygon) in the class "Rooms". To do that the Marionette network divides the areas into calculatable subareas: circles, rectangles, triangles. The graphical area verification using subareas is often required when applying for permits (building construction, landscaping). For easier usage a wrapper node is provided. How to use: a) Place the geometries (spaces/rooms) in the class "Rooms". b) Run the wrapper node. c) Update table. To do: - update table when running script - implement an add-on to turn spaces into polygons (soon)
  6. Version 1.0.0
    86 downloads
    This tool was commissioned by ComputerWorks GmbH edited by: Markus Graf and Pascal Völz supervised by: Antonio Landsberger Compatibility: Vectorworks 2019 and higher. Tiles is a Marionette tool for bond pattern planning using geometric shapes (circle, poly line, polygon, rectangle) to show distribution of whole and cut tiles. For easier usage a wrapper node is provided. How to use: a) Place the geometries (rooms) in the class "Rooms". b) Place the arrow (in class "Direction") inside the room you want to get the tile pattern for. c) Change the values according to your liking. d) Run the wrapper node. e) Update table. To do: - update table when running script - implement an add-on to turn spaces into polygons (soon) - implement more than one bond pattern
