mgt
22 -
Never
Everything posted by mgt
well- i solved the problem... the printer is shared through another computer. all I did was place the missing font in the fonts folder in the library on that computer. now everything prints fine. strange thing is that other documents with the same font printed fine through that computer before I added the font to the library. -mgt
The printer is substituting the text in text blocks- it doesn't matter which font is being used- it all comes out Geneva. In this case, the font on the drawing is Palatino. -mgt
I believe this issue was addressed for previous versions of OS X - but I am running VW 10.1, Mac OS X.2.6 and all of a sudden yesterday, the system default font was substituting for the font on our drawings. the quick fix was for us to print to a PDF and from there print to our plotter (HP 455CA - gimpprint). This works fine- but it would be nice to print directly to the plotter. VW is the only application that does this - all other programs print properly. any suggestions? -mgt
we've had the same problem- usually restarting the plotter works... i think it's a problem with gimp print. -mgt
ah... Deleting parametric constraints select the object- in the menu bar Edit--->Edit Constraints delete the constraint...
i'm hoping there is a simple command somewhere to turn this thing off, but... we have a curved wall on one of our drawings - and the radius is shown in red. This is fine with the exception that no one knows how the radius line got there, or how to turn it off. We can't select it, move it or edit it in any way. It isn't a huge issue because it doesn't show up when we print the sheet- but it is a bit annoying when one is trying to work on the drawing. does anyone know about this? -mgt
let's say I have an image of a person I want to put on an elevation (presentation drawing)... usually I would export the elevation to photoshop and place the image of the person on a separate layer (as a cutout)- but if i want to do it the other way around - import the image of the person to VW - I will always have a rectangle with some white area around the image. Is there any way I can import a cutout of an image, or will images always import as rectangles? thanks- -mgt-
i checked vectordepot, but no luck... i'm relatively new to writing scripts for VW, but i'll give it a try. [edit]whoops- i did find something... it works great with VW10 thanks again [/edit] thanks- -mgt- [ 06-08-2003, 04:25 PM: Message edited by: mgt ]
maybe this is possible within the program already- but has anyone written a script for printing the file path on sheets? This is helpful when the number of sheets in a project gets up there (and helps with those who for some reason cannot follow server filing procedures). I know this is possible in AutoCAD... something like: Computer Name/Project Files/20-20/Building A/First Floor Plan etc... I'm thinking that this would be easier in OS X (you know, with unix and all...) (Mac OS 10.2.6, VW 10.1.2) -mgt-
hi- Are there any conflicts with fonts such as tekton or stencil with VW 10.1? We were having trouble with VW 9.5.3, and would like to return to using tekton on our drawings. The version of tekton we have is a type 1 postscript font... I do not believe any fonts we had were MM fonts. (VW 10.1, Mac OS 10.2.6) thanks- -mgt
My coworker asked this question: When one does a Command-3 (or view at 100%), why is it not the actual scale? He even put a ruler up to the screen to show me. Actually, I wonder if any graphic program can show actual scale on screen. I'm not sure how useful this could be, but I'm curious. (VW 10.1, Mac OS 10.2.5) -mgt
hi- a quick question- how do I move walls without stretching others? i.e. if I want to move a wall that is joined to another, how do I make VW 10 behave in the same way as VW 9? I did a quick scan of the manual, but couldn't find any documentation of this change. We've been grouping the walls in order to remove them from others... the extra step is a bit annoying, I was wondering if there is a way around this. thanks- mgt
This is just a suggestion - but could the tech people at nemetschek post a "bugs/known issues" section on its boards - that would save some of us some time trying to see if what we are experiencing is a bug that will be fixed, a bug in the OS, or if it is something that can be prevented on our side. a section on "coflicting applications" would be helpful as well (something like - Real Player can cause some problems with VW 9.5.3 - or the fonts Tekton and Stencil cause VW 9.5.3 to crash in OS X). thanks- -mgt
I had posted a couple months ago on the same issue and it looks as if it still hasn't been resolved: http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=12;t=002357 I am still having problems with VW 9.5.3 (now running 10.2.4) - it crashes several times a day, usually when I try to copy and paste - either within a drawing or from one to another. I cannot work in two files at the same time - only one allows me to use any tools. I do not have any other programs running at the same time- I run disk utility regularly, deleted all conflicting fonts (mr. hand, tekton, stencil), etc... I have learned to live with saving every 2 minutes... -mgt
Just an update to the vectorworks randomly crashing in Jaguar- everything seemed to work fine for a week- but today I started experiencing the same problems as before. I ran Disk Utility again - and things seem to work fine again. Has anyone else experienced similar problems using VectorWorks in Jaguar? How can privileges affect the program's performance? If I run Disk Utility, how do I know which privileges affect VectorWorks? -mgt
Kevin- We don't have Norton Disk Utility- it created so many problems under OS 9, that we just stopped using the program altogether. How is it treating you in OS X? But- I ran the Disk Utility (which I had run before my vacation, but it appears that it didn't catch everything the first time) - it discovered some permission conflicts, and now everything works fine. Katie- thanks for all your help... -mgt
By the way- I know about the plethora of problems with the HP 455ca and vectorworks/apple/etc... - the programs mentioned previously are mainly for use with adobe products... and setting up files for our printer - although they seem to not work with this specific plotter. so- if I need to remove this software, let me know. -mgt
Katie- I am still having trouble running VW as a native OS X application... even when there are no other programs running. Gimp-pint was recently installed on this machine, as well as ghost print in order to run our hp 455ca plotter (which is not hooked up to the network at the moment). Is there anyway of checking in the terminal app if there are any conflicting programs? -mgt
Actually, I have had absolutely no problems with VectorWorks running in Classic mode (via the option in 'get info' to open the application in classic). I can even have many programs going at the same time and the only thing i experience is a minor slow-down in performance (although I can't seem to import DWGs as a classic app unless I restart into OS 9). It is when I run VW as a Jaguar application that I experience problems. What other programs are known to conflict with VW? Are any of them native to OS X? -mgt
I have a 733 MHz G4, with 630 MB RAM. I have restarted several times, and still the VW does not last more than 5 minutes without crashing... I've tried doing different things, like drawing polygons, walls, inserting windows, importing a DWG or image, and it crashes equally for all. I have also tried running with different combinations of programs, VW by itself, with realplayer, VW in 10 while I have classic running, with photoshop, a Mozilla, and so forth... still... VW seems to be going down by itself. I was at Build Boston back in November- the VW reps told me that I should stick with running VW in OS 9 due to stability issues in OS X... I guess this is what they were talking about. -mgt
Thanks for responding so quickly- I am currently running OS 10.2.2 - -mgt
I have been experiencing random crashes in VW 9.5.3 while running it under 10.2 (I've already gone through and removed all fonts, and suspect programs). For instance, whenever I startup VW, it crashes about 30 seconds later - even if i haven't done anything (I have left a blank document sit for a few seconds and it crashes). I really don't want to continue operating in OS 9, or run classic all day while in OS X. I have a couple questions- is there anything I can do to keep VW running in Jaguar without crashing all the time? Are VW 9 and 10 for OS X just carbonized versions? If so, when will Nemetschek release a Cocoa'd version? Should I update to VW 10? Is it more reliable in OS X? -mgt
