mstuen
    2
Everything posted by mstuen
  1. Seems to be a licensing issue cutting off the higher universes. Getting it worked out now that I've identified it.
  2. Hi, I've got a design using a couple hundred Astera Titan tubes in mode 42 (RGB 16 pixel) and while I thought this was a Vision friendly personality/model I can't seem to get them working. My other lights (MLs) work just fine. Model is the one included with Service Select and mode within the dropdown is 42. Units place properly into vision and show their fixture and address numbers correctly. Is there anything else I need to check to make sure they work? Is this setup missing the vision .lit file? Or something else I don't understand, which is totally possible as my setups usually are just an array of movers that seem to be plug and play. Thanks for the help.
