17 -
Posts posted by Paul S. Morrill
I have a drawing with multiple LED Walls can I create a quick way to label them in a drawing
Basically pull the info from OIB?
size
pixel count
manufacturer
module count
etc.
Thanks
Yes there is a dual view mode Primary and secondary or both..
new it was here just could not find it.
thanks for help got it now.
that's what i was afraid of using a dual dimension mode - shows both better than nothing.
Thanks mark I have a new feature request 😉
Thanks Mark,
will this affect entire document or just this detail?
Good evening folks,
Doing a drawing and I need to dimension in inches only and i can't seem to list the dims in inches only. defaults to Feet-Inches.
What am I missing here. This should be easy can't find it?
Thanks in advance,
-paul
Ahh Multiple copies of extrude " Coincident objects thx mark 🙂 I think that fixed it
I do like coincident object selection tool J + HOLD > Click to select the extra stuff an unsung hero tool
Hi Folks,
looking for some advice here.
Any thoughts why my extruded "pilasters" have the Black lines when rendered?
everything else renders fine in this mode. and I have changed a couple of things.
Each time I render it looks great and at the very last second I get these black lines on these objects only.
any thoughts?
thanks
Thx Scott make sense on the naming I do the same essentially with names. FOH Mid SR MID SL USL USR.
I am struggling with the raking of the individual trusses in 3D for Client and keeping a good 2D plot for Shop.
So I have been playing with this for 2 days and cant seen to get this to work.
keep getting unexpected results. Entire DLVP Viewport rotates, can't change angles etc.
FOH truss
2 Mid Truss
2 US Truss
Should be simple Tried turning off Layers Etc
Anyone have a sample file and step by step to share.
Thanks,
Paul
On 1/21/2019 at 11:47 PM, scottmoore said:
Agreed. That said, and I have said this before, DLVPs do offer quite a lot of flexibility beyond simply raking a truss. Let’s say you have some lighting pods that are automated at different trims and different angles throughout an event. No problem. Make duplicates of your initial DLVP, class each seaparately and move/rake to your heart’s content. Have a piece of moving scenery that travels about on stage? Same thing. DLVP’s are really quite versatile and those are just two examples of uses that could not be accomplished by simply rotating geometry.
Clunky? Yeah probably, however, my solution to avoid the clunky aspect is to do the following in my template file:
- I have ten design layers already set for creating DLVP’s.
- I have ten classes already set up for DLVP’s.
- I have already created the physical viewport for each design layer, assigned it to it’s appropriate class and turned on the “use current class visibilities” option.
For me, all I do is start drawing in the pre-defined layer, go back to my standard drawing layer, turn on the appropriate DLVP class and rotate into position. Done!
Hi Scott,
This is a good thread
I already use a bunch of viewports and have a template for most of my layers working layers, lighting, audio, scenic etc. and I am venturing into DLVP for trussing. Etc.
Could you elaborate on how you use the 10 layers with DLVP and 10 Classes for DLVP
I am interested in your Naming conventions and how you handle layer height.
thanks,
-Paul
Just now, JustinVH said:
@pmorrill If you are a VSS subscriber you can submit a Spotlight Fixture request through the support page and the content team will work to add the light to the libraries if all the required information can be found.
Thanks I am vss and i checked there. of course i need it right away. i will submit and in the mean time i will try and modify the other existing symbol thx for the reply
Hi Folks,
Anyone have a model / symbol for the Kino Diva-Lite LED 41 DMX fixture.
VWX has the kino diva led 20 & 30 but alas no 40 or 41
Thanks
thanks checking it out
So I need to create a Large Sail of a sheer material for an entertainment project. it need to be billowy and does not hang flat.
any thoughts on how to go about this. Thinking a lofted surface of some sort. Thoughts???
TIA
-Paul
Best way to label multiple LED wall of different sizes
in Entertainment
Posted
