michnov
    12
Reputation
0 Neutral
Personal Information
  • Location
    Russian Federation
Recent Profile Visitors
  1. Hi everyone! I have workstation based on 24-Core AMD Ryzen Threadripper 3960X, 4342 MHz but performance of vectorworks and speed of cloning ,distribution, moving objects is extremely slow. I worked on the same project on 2 different stations, one of them is mine and the second based on AMD Ryzen 9 5950x and on the last station the performance was much better and faster...Does anyone know what to pay attention to and where to start in solving this problem?
  2. Juan I wrote from maneshin.projects@gmail.com
  3. My activation was reset and I installed VW to the new PC. I got the error "An attempt to activate over the internet has failed because of communication problems. Do you want to try again? Make sure you have unrestricted internet access and that you are connected." "Try Again" or "Quit." My Firewall and antivirus fully closed. I'd tried to install VW to the old computer(it works before activation was reset) and had the same error. I found 2 topics where people have the same problem and no one couldn't help. I sent 2-3 requests to VW support and now VWS ignoring me. How I can use my high cost soft??????
  4. I created extrude object, how i can set the image on the one of side?
  5. It's so interesting thank you for new information, but my problem is more easy. I need to do truss system with truss from VW libraries.
  6. How to do beams visible at the shaded view?
  7. When i already created a truss construction which i need how to assign it to truss system without snap each part to other part?
  8. First im do the front rectangle, second from top view, third left/right view. Then im press script and first rectangle becomes a 1st viewport and going to 1st sheet layer etc.
  9. Is it possible to choose fixtures, use script write 2 value(Channel and Unit number) and after this the fixtures autonumbered? If yes how to do it?
  10. How to create script for step scaling viewport. For example: tap one button +5 scaling, tap another button twice -10.
