Swatz
    8
Everything posted by Swatz
  1. That helped to not have a corrupted file anymore, but the lights still weren't coming on. BUT! I figured it out, I'm not sure if it's because of the symbol geometry, but I turned off Cast Shadows in the lights and there they are!
  2. No I just added those lekos in today. there are 4 led wash moving heads on the truss that are a deep blue and cyan that do not show up.
  3. I knew they were turned off I'm still missing the LED Washes there should be blue and cyan on the ceiling and walls. I attached the pdf with the rendering my boss has now. It needs those washes. The stage and podium are lit with the lekos and the profiles are showing the gobos, but I cannot get the washes to come on other than in Open GL Ive tried using VW lights to recreate the look and nothing, I've swapped the symbol to something similar, still nothing. Is there a limit to how many lights can be on in final renderworks modes? US Grant Chicano Federation VER. B.pdf
  4. I have attached the file, I get most of them to come on, but I cannot get all lights to come on in any Renderworks mode. I can see them one at a time in OpenGL but no other. Please help I need this done today. US Grant Chicano Federation v2018.zip
  5. That's interesting because there is an option to import. Which I tried to do, but I guess you have to have a certain record format attached. I also tried using the same record format in the Bumpers file, but no luck there either. I just used the symbols as they are and made my line array. Thanks for the reply.
  6. Now the question is, how do I use my custom bumper in the speaker array tool? RCF HDL-30A.vwx
  7. You have to tell the lights to rotate as well. In the OIP go to set 3D rotation. You can not rotate lights and truss all at once unless you ungroup high-level objects, and then group them all together, which is not recommended. It's much easier to do the first method.
  8. Sparky I have the exact same machine without the external monitor. Works like a charm!
