Danielle227
    11
Everything posted by Danielle227
  1. Thank you Boh. I do have renderworks. Is there a way to use a benjamin moore color as a render texture? Sorry for these very rudimentary questions, I am new to 3D.
  2. Hello. Is there a way to change the attribute on wall that I make with the wall tool? I seem to be able to change colors on the default unstyled walls when i'm in the 3D mode, but I can't figure out how to do this on walls I make myself. Hopefully I dont need to make a different wall type for each different color wall. Thank you, Danielle
  3. Thank you PeterYip, this worked for me! Also, I didn't know about the 3D polygon tool which is helpful too. It takes trial and error for me to set the correct location of the profile, I don't understand the logic of that.
  4. Hi, I've tried this over and over again, and must be doing something wrong. 3D is all very new to me.
  5. Hello! Is there a way to extrude along path on an exterior corner? I would like to wrap my paneling around this column in the corner of a room. I was able to do this when I hand-built up rectangles, but in a more complex moulding that has ogees etc I don't know how to do this. I've included screenshots.
  6. Hello everyone. Is there a way to use a custom trim profile on the door tool, or must the trim be added on separately if I were to want to use something other than the rectangle shape that is shown?
  7. I've discovered that if I give the referenced layer a DIFFERENT name than original file's layer name, the referenced classes can turn on and off. The new problem is that not all of the classes from the original file are showing up on the referenced file.
  8. I have referenced a floor plan from a plan file into a new elevations file. Within the new elevations file, I created a viewport around one room of the plan and put that viewport on a sheet in the elevations file. I want to turn off some of the classes of the viewport. When I click on the viewport, go into Object Info, and turn off some of the classes, they still appear in the viewport. Help! Referencing is not what it used to be, and I'm lost.
  9. How does one create a default style for the drawing label tool? I find that when I use the drawing label tool, I have to manually change the size of the text and change the bubble style for every viewport. This is tedious and would be a great timesaver to understand how to set it once, and have it as my default. Thank you! Danielle
