darienzaq
    4
Everything posted by darienzaq
  1. when you swipe up to show all windows it adjusts fine, until u swipe back down. it also makes twinmotion UI flash at times.
  2. Thanks @line-weight @Diego-Resuelvectorworks GOT IT!!!!!!
  3. Hey Everyone, I have two questions. 1. In a section viewport, how do i change the default black fill to the wall material/hatch/components? 2. In a viewport, how do i adjust the horizontal cut plane height (if possible)? Thanks!!!!!🙏
  4. darienzaq
    grid bubble
    jnr I think your issue would be fixed if you go under dimension standards in documents settings. Edit the current custom dimension standard and change the txt style to un-styled. From there you should be able to edit you grid bubble and dimension size. Annoying.... i know
