Hi all,
I am dimensioning a lighting pipe from the centerline using the chain mode. I am wondering if there is a way when I adjust the dimension in a different direction.
For example, when I change the center-left dimension [3'-0"] to [2'-0"], it will adjust the dimension on the left. However, if I need to adjust from the center line to the right, it's moving the left dimension instead of the right. I try flipping the dimensions and looking at the setting, but I haven't found a solution yet.
Org dimensions:
Changing the left set of dimensions:
Changing the right set of dimensions:
