Content Count
22 -
Community Reputation
9 NeutralAbout Edgar RAMEL
Rank
Greenhorn
Personal Information
Occupation
Architecte-paysagiste en entreprise aménagements extérieurs
Homepage
www.landscop.fr
Location
France
Recent Profile Visitors
293 profile views
Hello, I also miss that data. It would be nice to have the 2021 catalogs ... Thank you in advance. Cordially. Edgar
Hello, I try to use geo localized images with the adhoc. The quality of the images provided by the ArcGIS server is very average, especially compared to Google Maps or Geoportal. I tried to add the Geoportal Server, but it does not turn around image (successful from the BRGM). Do you have ways to access the correct aerial images? BRGM server: http://geoservices.brgm.fr/geologie Geoportal Server: https://wxs.ign.fr/choisirgeoportail/geoportail/r/wms?SERVICE=WMS&REQUEST=GetCapabilities If you have solutions ... 😃 Cordially. Edgar RAMEL Landscop Design - Landscape Bonjour, J'essaye d'utiliser les images géo localisées avec l'outil Adhoc. La qualité des images fournies par le serveur ArcGis est très moyenne, notamment par rapport à Google Maps ou Géoportail. J'ai essayé d'ajouter les serveurs Géoportail, mais cela ne me retourne pas d'image (réussi à partir du BRGM). Avez-vous des pistes pour accéder à des images aériennes correctes ? Serveur BRGM : http://geoservices.brgm.fr/geologie Serveur Géoportail : https://wxs.ign.fr/choisirgeoportail/geoportail/r/wms?SERVICE=WMS&REQUEST=GetCapabilities Si vous avez des solutions … 😃 Cordialement. Edgar RAMEL Landscop design - Paysagistes
Rotate Objects erroneous view 2d rotated
Edgar RAMEL replied to Edgar RAMEL's question in Troubleshooting
Hello, I just installed the latest update SP.4 US and the problem reported in this post is still there. It's really annoying and unproductive not to use the angles of rotation of objects wedged on the direction of the turned-up view. If developers read this post, thank you please tell me what they think and if they have a solution to that. Thank you in advance. Cordially. Edgar PS: the video is from the French SP.3 but SP.4 US produces the same result Bug rotation objet dans vue 2d pivotée.mp4 -
Hello, VectorWorks plant systematically during import EMF files ... Attached is a file for example. If someone has an explanation? I am speaking on SP3.1 in Windows 10. The EMF is generated by CorelDRAW or Adobe Illustrator (problem with two sources). Thank you in advance. Edgar Plot Buzon BC-5.zip
Version Vectorworks 2020 SP3.1 Hello, Big problem since update. When rotating view 2d screen is applied, parametric objects (found with beams and North) to take no account of the angle of rotation as we enter IOP. In the example in the capture, I want to straighten the beam to -90, and -90 + IOP returns angle rotation of the 2D view = -85.12 °. This problem is really annoying to orient objects when the view is rotated 2d 😞 Thank you to find a solution very quickly, please. Thank you in advance. Cordially. Edgar RAMEL
In search of Lost Plugins Utility Classes …
Edgar RAMEL replied to Edgar RAMEL's topic in Vectorscript
Hello Peter, Super great ! I tested all this on. Thank you so much. -
Hello, 👏🏻 Thank you @Peter Vandewalle !!! Great, that's exactly what I was looking 👍🏻 There are just shadows, text styles and textures that are not included. But it is already very good. How can I thank you? See you soon. Edgar -
Hello, Maybe the subject has already been discussed, but I didn't find it on the forum. I had once found on http://www.vectordepot.com some very useful plugins to manipulate or manage Classes. Especially those by Petri Sakkinen and Katerina Panagiotakis. Today these plugins are mostly obsolete with the 2020 version and I miss them in my production process. Two plugins in particular are obsolete. They are "Assign obj attrs to class.vsm" and "class, set object default.vsm". The first one allows to modify the attributes of an object and once the result is satisfactory, to apply these attributes to the class of the object. This was very useful and efficient when you regularly create new non-standard classes from existing classes. The second plugin: "class, set object default.vsm", was "simpler", but very practical, it allowed to give the default class attributes to an object at once (you can do it from the attributes palette, but you can't put a shortcut in it). These plugins are obsolete, especially because new attributes (transparency, shadow, gradient, ...) have appeared and are not managed by these plugins. I don't know if anyone has something similar in store? or wants to put their fingers in the code, but "Assign obj attrs to class.vsm" was really a very productive plugin and I would be willing to offer a few liters of coffee to whoever could give it back to me 😉 I didn't find @Petri Sakkinen on the WEB, but I attach his plugins and his notice for those who would be interested. Thanks in advance. Ð -------------------------------------------------------------------------------- Bonjour, Peut-être que le sujet a déjà été abordé, mais je ne l'ai pas trouvé sur le forum. J'avais trouvé jadis sur http://www.vectordepot.com des plugins bien pratiques pour manipuler ou gérer les Classes. Notamment ceux de Petri Sakkinen et Katerina Panagiotakis. Aujourd'hui ces plugins sont pour la plupart obsolètes avec la version 2020 et ils me manquent dans mon processus de production. Deux plugins le sont plus particulièrement. Il s'agit de "Assign obj attrs to class.vsm" et de "class, set object default.vsm". Le premier permet de modifier les attributs d'un objet et une fois le résultat recherché satisfaisant, d'appliquer ces attributs à la classe de l'objet. C'était très utile et efficace quand vous créez régulièrement de nouvelles classes non standard à partir de classes existantes. Le second plugin : "class, set object default.vsm", était "plus simple", mais très pratique, il permettait de remettre d'un coup les attributs de classe par défaut à un objet (on peut le faire depuis la palette des attributs, mais on ne peut pas y mettre de raccourci). Ces plugins sont obsolètes notamment car de nouveaux attributs (transparence, ombre, dégradé, …) sont apparus et ne sont pas gérés par ces plugins. Je ne sais pas si quelqu'un a quelque chose de similaire en magasin ? ou a envie de mettre les doigts dans le code, mais "Assign obj attrs to class.vsm" était vraiment un plugin très productif et je serais prêt à offrir quelques litres de café à qui pourrait me le rendre 😉 Je n'ai pas retrouvé Petri Sakkinen sur le WEB, mais je joins ses plugins et sa notice pour ceux qui seraient intéressés. Merci par avance. Ð Assign obj attrs to class.vsm class, set object default.vsm Class struggle.txt
Hi all, Indeed, the "Tag" tool is very interesting. Calculations can even perform for the label display. For example: the surface of the object multiplied by a database field. For me, unfortunately, it lacks the implementation of the functions of spreadsheets that would best customize the labels. Ditto for information objects (object function). We have #AREA#, #PERIM#, #SURFAREA# but no #VOLUME# ... I miss in my opinion. Otherwise the tool is quite powerful!
Hello @Vlaval , Here in pictures how I do it (here with a V.2020 US from VectorWorks). I do not know if it's very orthodox, but it works for me ... I don't know what the developers think about it? Formerly on the old versions of VectorWorks, the plant database was editable with the data from the object info palette and also from the spreadsheet. Now it's locked and suddenly it has become quite heavy and painful to edit the characteristics of the plants (SKU, price, remarks in particular). At your disposal and disposition to improve this plant tools that could be a real bomb, but whose complexity and randomness must repel a lot of landscapers who use so "simple" symbols ... Cordially. Edgar RAMEL Sorry if the syntax is not very good, but I am French-speaking, it is our friend Google who speaks for me in the language of Shakespeare... 😉
Hello @Vlaval, I have no rounding in the resource manager (in 2020 at least) cf. attached screenshot. If ever, you can try to modify the units of the database to get to what you want as in the attached screenshot. Cordially. Edgar
Hello, I found this solution to work around the problem for the moment. By modifying the properties of the "sum" field of the "plant record" database by indicating a numeric format without a decimal point, this eliminates the problem in the labels. Hoping that it will not create any more ... My screenshot is on French VW 2020 SP1.1 to see for the US version. Good evening. Edgar
Same problem for me ... Still no fix since June?
Hello, I noticed the same problem. This is not reproducible and appears a bit randomly. You have to restart so that it does not happen. Looks like there is an OpenGL cache or something that bug after a while and the restart erases it.
