14 -
Everything posted by REYES
NEVERMIND. It was taking the data as text from the records parameter ILO of taking it as a number. I typed =AREA and worked.
Hi @Pat Stanford I tried this and thought it would work but it's not working for the areas of my spaces, any idea of what might be happening?
Override class appearance doesn't work for curtain walls
REYES replied to REYES's question in Troubleshooting
Thanks Tom. I agree. Do you know how to file as a bug? -
@Pat Stanford, Thank your response. I've had some more time/need to try and figure this out and I am still not able to. I've changed all the parameters inside the curtain wall (panels, frames, wall attributes, insertion options) to 'object class' and 'attributes by class' and it seems to work when I change the class visibilities in the design layer. However still doesn't override when using viewport overrides. Would you have a file where it is working so I can take a look at what I am missing here? Thanks, Reyes -
I agree. In order to test it out I minimized the amount of classes to only one and still have the same problem. I have tried to make sure all attributes are "By Class" in the AP and in the CW settings, and still have that issue. Wondering if anyone has succeeded at this and I'm missing something or if it's a real bug. Anyway's I'm attaching the file I've been using to test it out in case anyone feels lucky. thank you. CURTAIN WALL OVERRIDE.vwx -
Hi, Override is a crucial part of our workflow in our office and we cannot make it work with curtain walls. See attached photo. With only one class in the model (Black pen white fill) it shows correctly in the Design layer on the right but when we override it to render it with orange pen it only works with standard walls and polygons, but not with curtainwalls.
Same problem here. has an Enhancement request been placed?
Door Hardware Doesn't allow to edit hardware [Read only]
REYES replied to REYES's topic in General Discussion
Thanks Judah, that worked!- 2 replies
- door hardware
- read only
(and 1 more)
Tagged with:
I realized I put this in the wrong tab so I move it here: For some reason it won't let me to add new Hardware to a door. After clicking manage hardware the Door Hardware library "Add" and "Remove" tabs apear as grays nd it won't let me to edit them either. It's probably related to my Door hardware library being Read Only mode. Which I don't know how to switch from. I'm the only one with this issue in the office and we can't figure out what I have different from other users. See screenshot attached. It happens both in project sharing files and in new files. It'd be great if anyone can help out. thanks
- 2 replies
- door hardware
- read only
(and 1 more)
Tagged with:
- door hardware library
- read only
(and 1 more)
Tagged with:
Thanks Kevin, It happened that the geometry was somehow corrupted and copying it to a new file solved the issue with the Custom Renderworks visualization problem. Reyes
- 2 replies
- renderworks
- curved
(and 2 more)
Tagged with:
Even if the Curved Geometry is set to 'Very High' some of the curved elements come out shattered when rendered with Renderworks. As you can see, at the revolving door (modeled not plugin) or the street light outside (imported from sketchup). It shows perfectly fine in the Open GL (also attached) mode or in the hidden line. Any ideas on what might be the problem? I can send over the file if needed... Thanks!
- 2 replies
- renderworks
- curved
(and 2 more)
Tagged with:
Insert Hyperlink into Worksheets?
REYES replied to ericjhberg's question in Wishlist - Feature and Content Requests
Plus one here too. -
I have the same problem. Some of my materials default to Obj. Size 0 all the time.
