Hello Kevin, Solved! I had already created a blank file and had only tried to section a sphere with a 2d rectangle to no avail. I substituted the rectangle with an extruded line and it worked! "Extruded" was the keyword here! Thank you so much!
I have Vectorworks 2018. All of a sudden, after hours of normal work, the Model ( add, subtract, intersect and section ) command does not appear as available ( grey ). I quit and restarted, installed updates and reset everything and it still is unavailable. Has anyone encountered this?
I have the same issue in 2018 and seems to be related to the complexity of the render. When I delete elements in my workspace renderworks finishes the render.
