timtimtimtim
    5
Reputation
3 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. I wish I could select all the references, edit, and set their path to "relative" at once instead of having to do each one manually. I lose a lot of time doing this. My references frequently get set to "absolute path" by colleagues in other departments, and there isn't really anything I can do about that, so this would be very helpful.
  2. @DBruhnke @Pat Stanford Unfortunately, neither of those worked. I guess it could be a problem with the 2019 Windows version.
  3. I'd like to be able to set a data tag that has a two digit number that counts up incrementally like a normal data tag (01, 02, 03). Right now it will only do a single digit integer (1, 2, 3). I've tried changing the "sequence settings" field, but it doesn't work. Of course there's a workaround where I can just put the 0 as a text before the incrementing formula, but then I will get 3 digit numbers once I hit 010, 011, 012. I also tried the "user-entered field" option with a decimal number as a workaround, but that doesn't work either. Any help is greatly appreciated.
  4. I have my files automatically making backups every 5 minutes, but when the drawing crashes and I attempt to open one it just regenerates the stripped 3D geometry before ultimately crashing again. Most of my backups become completely useless. It would be great to have an option that would save a backup of the complete file without stripping the geometry. Yes, I could set it to overwrite the original, but I'm not putting all my eggs in one basket for obvious reasons.
