Daniel Dickman
    98
Reputation
10 Good
Personal Information
  • Occupation
    Lighting Designer
  • Location
    United States
Recent Profile Visitors
1,782 profile views
  1. When I select an adapter, the make/model fields in the OIP are greyed out. Is there anyway to define make and model?
  2. It also seems I cant modify pan or tilt values from a work sheet. I don't understand what the difference is modifying these values in the OIP vs a worksheet. Seems it should work in either place.
  3. Hey there, I have a worksheet with a number of lighting devices and positions. Each position is exactly the same fixture layout just at different rotations. I have modified all of the Z fixture heights on one position and I was hoping to just copy paste the updated Z locations in a worksheet and paste it on to the other fixtures but it seems I can't edit any of the X,Y,Z locations via a worksheet. Anyone know why? In the worksheet I can edit channel and position name just not x,y,z locations.
  4. I'm working on some rack elevations, On my schematic I have some devices with the device names like "WX-MXL316498X" but the display tag is "CAD PC 1". On the rack elevation side, I frequently find myself wishing I could abbreviate an Equipment item's name similar to the Device Name/Display Tag functionality of schematic devices. If I change the name of the equipment item to "CAD PC 1" it breaks the link to the schematic device. Is there any way to display the Display Tag on an equipment item rather than the full device name?
  5. All of the low, medium, high detail levels are ticked. Interestingly, if I remove the 3D component entirely and turn it into a 2D symbol, I can get it to render correctly, but the draw in front view box must be selected. 2D Symbol - Draw in Front View Selected 2D Symbol - Without draw in front view selected
  6. When using a hybrid symbol with my equipment item, I'm having an issue where the 2D component in Top/Plan view does not render correctly? What am I missing here? Equipment Item In Top/Plan View What the 2D component should look like
  7. Hey all, In my drawings I like to color code my devices by discipline (lighting, audio, video, etc). Currently I'm using various device symbols that I've made for each discipline. This works good enough but Its a bit of a manual process to select the right symbol for each device. Here is what one of my typical devices looks like using the custom device symbols. In addition to this, I have a record attached to each device where I define the discipline of the device for use in worksheets. Since I'm already defining the discipline in my "Device Additional Info" record, I would like to use Data Visualizations to help color code my devices based those values. My goal is that the data visualization only changes the color of the rectangle that is behind the device tag text. I do not want the data visualization to change the fill of the entire device object. Here is what I've attempted so far... I have created a new Device symbol named "Standard Device Label". In this symbol the rectangle behind the Device Tag text is set to a fill of black and a class of "Device Discipline Color" In my new Data Visualization, I set the criteria to "Class is "Device Discipline Color" With the criteria set, it says it finds objects that meet the criteria but I can't seem to get the colors to actually change when I define the discipline field in my record. I understand that my record is attached to the device and not the rectangle inside the device symbol, so I assume that's why this doesn't work. Does anyone have ideas for a better approach?
  8. Hey Conrad, I got around to testing this in the metric template and can confirm the cable tag does not overlap with the arrow. Is there way for me to manually place the cable tag on the arrow line where I want? Similar to a normal polyline circuit.
  9. My company has finally upgraded to VW2023 and I'm getting around to playing with some of the new ConnectCad features. I see we can now reshape arrow circuits, but how can I move the cable tag so it doesn't overlap with the arrow?
  10. @Conrad PreenIs there any harm with us modifying the pre-made records? The record "Device Network Info Record" for example, I would like to add a field for Gateway.
  11. Ahhh I'm still in 2022, Our organization hasn't updated to 2023 yet. Thanks Nikolay
  12. This was a very helpful video! Thanks for posting! Is there anyway we can map text inside our Device Symbol (dev_label_generic for example) to our custom records? I can't seem to get my custom device labels to display text from these records. The only way I can get text from these records to display is by adding text directly inside of the device itself (as shown in the video).
  13. Hmm I trying to add these to a custom workspace that I already have and it isn't working. Even tried duplicating my custom workspace and still no luck.
  14. Ahh okay. So what I didn't realize is when you change Load Name it immediately changes the Instrument Type field to match, That's what made me think it was load name because I could see the name change when I would export new MVRs. Okay... so MA Name = VW Instrument type. Does that really make sense? I could easily change my instrument type fields to match what I want my MA naming to look like, but now that will break all of my instrument type columns in worksheets/lightwright. It really feels like we need a new Fixture Name field in future versions.
  15. First off I'm using VW22. I've been doing a lot of testing of the MVR export and importing into MA3. Overall the entire process is very easy and a huge improvement over the MA2 export plugin. One thing I am struggling with is fixture naming in MA3 vs Vectorworks. When you import your MVR in to MA3, MA associates its fixture name column with the Load Name column from Vectorworks. By default, Vectorworks just copies the Instrument Type into the Load Name field for each lighting device. Typically when I first import my MVR into MA3, I go through and give all of my fixtures logical names, so they are easier to understand in my fixture sheet. Now my challenge here comes when I need to reimport an MVR to MA3 in order to update some 3D positions in my rig. In Vectorworks I move my fixtures in 3D space as needed, I export MVR but now the MVR is going to overwrite all my neatly named fixtures in MA3. Obviously, the solution here is to update my Load Names in Vectorworks so they import the way I want them named in MA3. But I can't seem to easily apply bulk naming to this field via Spotlight numbering tool or via lightwright or worksheet. The only available field is called Load Information. But I need to edit Load Name. Does anyone have any tricks to easily bulk edit the Load Name field? I really don't want to update this field 800 times manually. In the long term it doesn't seem like the Load Name field is really the best field to use for the MVR export tool, I wonder if VW needs to consider adding a Fixture Name Field to the Lighting Device record.
