quote:
Originally posted by jan15:
I'm still not getting the concept here. You want the circle to be made up of several arcs? Why not draw an arc and Array it around its center? Wouldn't that be just as quick as the reverse method?
If you want it to stay a circle but with snap points at regular intervals, 1/5 for example, you could place a locus point on it and then array the locus 360/5 degrees around the center.
A lot of things would be quicker if there were a keyboard macro utility built into VectorWorks. Wouldn't it be nice if you could draw your construction line, then while it's highlighted just press F9 to make it a guide?
Absent that, I use a shareware keyboard macro program called mgSimplify (there are a lot of others for the PC, including EZMacros, and there's Quickeys for the Macintosh) to assign the commands I use most often to Function keys, and a Focus 8200 (or 9200) keyboard with 24 function keys. The Focus also has a built-in calculator that can send its calculated value to the cursor location.
As per dividing a circle, yes, I would love to have the equivalent of arraying loci around a point. That's one way of doing it and I've also drawn an arc of 180 degress and used the arc into segment command. Honestly, if I NNA would expand the abilities of Arc into Segments to include circles and do the same to Line into segments to include plines, life would be grand. The work arounds are there, but it would be helpful to be able to do it in 1 or 2 clicks.
And finally, keyboard macros would be a boon. I think that should DEFINITELY make the wishlist.
