ScottL
    3
Everything posted by ScottL
  1. I am having the same problem. After much searching, I'm relatively certain that gridlines 1-4 and A-G don't actually exist in my project. However, I cannot use these numbers or letters in my grid - I get the same error message as noted by Todd V. above, "You have entered a label value that is already in use." The only solution I can find is to convert the smart grid tool to objects - give it a lobotomy, as my coworker says - which removes the value of having the tool in the first place. Any help would be greatly appreciated!
  2. I downloaded 2023 to my Mac yesterday, I discovered quickly that pressing "Option" while clicking the visibility columns does not function as it did in 2022 - after processing for five-ten seconds, it appears that all classes are turned on (as desired) but for only a split second before returning to the previous state; the selected class then reverts to a different class ("windows", in this instance) although I hadn't used that class recently. Selecting all classes and then clicking on the desired visibility column also does not work. Has anyone else had this issue? Has anyone figured out a workaround?
  3. I have had similar issues - crash followed by a new file with the .swap extension. It just happened again, but this time my original .vwx disappeared (going back to an earlier version). I am also looking for any information about this phenomenon and recommendations for avoiding/remedying this issue.
