ckudi
4 -
Everything posted by ckudi
VW2018 - Architect borderline unusable (slow/crashes)
ckudi replied to ckudi's question in Troubleshooting
Hi NeilB Thanks for your response. - Are you seeing the issue with ALL files or just certain files? Does it occur even with brand new blank files not made from a template? This is happening in all files on all of our work stations. the only workstation that was not affected was the laptop which used exactly the same files. (this has since unfortunately stolen in a burglary and cant be used as a reference point to eliminate problems between the machines) The director has been going through the process of starting a new office template file from scratch and experienced the same issues. (I will confirm this with him though just to be doubly sure) - Are you working on files that are stored on a server or are they stored on your computer? The files are not locally stored, they are retrieved from the office network server. - Are all of your graphics drivers up to date, and are you 100% sure of this? (In some cases, drivers on Windows machines may not update with the various automatic updates, so driver updates should be checked for and done manually from the graphics card manufacturer’s website.) The graphics card update was the first response we got from our local distributor and their in house tech guy. This was done and did not fix the issue. (from memory it was not manually done but through the nvidia experience program, I will manually update to see if there is any change in performance) - Can you post a file in which you’re seeing the issue? I'm sure I will be able to post a example file here. I will need to check with the office director first though. (example file pending) I also just noticed (but I don't know what I am looking at) in the dxdiag above under dianostics there are errors with the line "apphangB1" and "apphangtransient" relating to VW2018.exe. The thread listed below seemed to sound similar to how our issue is. we also had similar problems in 2017, but I personally did not spend much time at this version as I was upgraded to VW18 quite quickly. and the fix of refreshing the workstation user did not work for us. -
Hi Pat Thank you for doing that. Yes I understand that is somewhat of a blanket statement saying that others are having similar problems. as specific incidents vary greatly between users depending on machine and version of software. But a simple google search with the key phrase vectorworks running slow has hits which in vague recollection resemble my issues but have no fixes. We are willing of course and greatly appreciate any time and help anyone can provide. We are also noticeably seeing hang times with text and deleting items. -
Sorry can a admin/ moderator move this thread over to the troubleshooting section if this is not appropriate here. Also if this helps the dxdiag information i see requested often. ------------------ System Information ------------------ Time of this report: 3/8/2018, 16:37:10 Machine name: NEATEFIVE Operating System: Windows 10 Pro 64-bit (10.0, Build 16299) (16299.rs3_release.170928-1534) Language: English (Regional Setting: English) System Manufacturer: Gigabyte Technology Co., Ltd. System Model: Z87-HD3 BIOS: BIOS Date: 08/03/13 10:57:23 Ver: 04.06.05 Processor: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz Memory: 16384MB RAM Available OS Memory: 16334MB RAM Page File: 7523MB used, 25194MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 12 DX Setup Parameters: Not found User DPI Setting: 96 DPI (100 percent) System DPI Setting: 96 DPI (100 percent) DWM DPI Scaling: Disabled Miracast: Available, with HDCP Microsoft Graphics Hybrid: Not Supported DxDiag Version: 10.00.16299.0015 64bit Unicode ------------ DxDiag Notes ------------ Display Tab 1: No problems found. Display Tab 2: No problems found. Sound Tab 1: No problems found. Sound Tab 2: No problems found. Input Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (retail) DirectDraw: 0/4 (retail) DirectInput: 0/5 (retail) DirectMusic: 0/5 (retail) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce GTX 960 Manufacturer: NVIDIA Chip type: GeForce GTX 960 DAC type: Integrated RAMDAC Device Type: Full Device Device Key: Enum\PCI\VEN_10DE&DEV_1401&SUBSYS_85201043&REV_A1 Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER] Device Problem Code: No Problem Driver Problem Code: Unknown Display Memory: 10174 MB Dedicated Memory: 2007 MB Shared Memory: 8166 MB Current Mode: 1920 x 1080 (32 bit) (60Hz) HDR Support: Not Supported Display Topology: Extend Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709 Color Primaries: Red(0.647961,0.334484), Green(0.284680,0.607922), Blue(0.151867,0.071789), White Point(0.313000,0.329602) Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000 Monitor Name: Generic PnP Monitor Monitor Model: 2870 Monitor Id: AOC2870 Native Mode: 1920 x 1080(p) (60.000Hz) Output Type: HDMI Monitor Advanced Color Capabilities: None Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll Driver File Version: 23.21.0013.9077 (English) Driver Version: 23.21.13.9077 DDI Version: 12 Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1 Driver Model: WDDM 2.3 Graphics Preemption: DMA Compute Preemption: DMA Miracast: Not Supported Hybrid Graphics GPU: Not Supported Power P-states: Not Supported Driver Attributes: Final Retail Driver Date/Size: 23-Jan-18 1:00:00 PM, 931584 bytes WHQL Logo'd: Yes WHQL Date Stamp: Unknown Vendor ID: 0x10DE Device ID: 0x1401 SubSys ID: 0x85201043 Revision ID: 0x00A1 Driver Strong Name: oem38.inf:0f066de3d2368449:Section096:23.21.13.9077:pci\ven_10de&dev_1401 Rank Of Driver: 00D12001 Video Accel: DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled MPO MaxPlanes: 1 MPO Caps: Not Supported MPO Stretch: Not Supported MPO Media Hints: Not Supported MPO Formats: Not Supported PanelFitter Caps: Not Supported PanelFitter Stretch: Not Supported Card name: NVIDIA GeForce GTX 960 Manufacturer: NVIDIA Chip type: GeForce GTX 960 DAC type: Integrated RAMDAC Device Type: Full Device Device Key: Enum\PCI\VEN_10DE&DEV_1401&SUBSYS_85201043&REV_A1 Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER] Device Problem Code: No Problem Driver Problem Code: Unknown Display Memory: 10174 MB Dedicated Memory: 2007 MB Shared Memory: 8166 MB Current Mode: 1920 x 1080 (32 bit) (60Hz) HDR Support: Not Supported Display Topology: Extend Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709 Color Primaries: Red(0.637219,0.341320), Green(0.312023,0.625500), Blue(0.154797,0.054211), White Point(0.313977,0.329602) Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000 Monitor Name: Generic PnP Monitor Monitor Model: 2870 Monitor Id: AOC2870 Native Mode: 1920 x 1080(p) (60.000Hz) Output Type: DVI Monitor Advanced Color Capabilities: None Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll Driver File Version: 23.21.0013.9077 (English) Driver Version: 23.21.13.9077 DDI Version: 12 Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1 Driver Model: WDDM 2.3 Graphics Preemption: DMA Compute Preemption: DMA Miracast: Not Supported Hybrid Graphics GPU: Not Supported Power P-states: Not Supported Driver Attributes: Final Retail Driver Date/Size: 23-Jan-18 1:00:00 PM, 931584 bytes WHQL Logo'd: Yes WHQL Date Stamp: Unknown Device Identifier: {D7B71E3E-5741-11CF-8650-2DA51BC2DA35} Vendor ID: 0x10DE Device ID: 0x1401 SubSys ID: 0x85201043 Revision ID: 0x00A1 Driver Strong Name: oem38.inf:0f066de3d2368449:Section096:23.21.13.9077:pci\ven_10de&dev_1401 Rank Of Driver: 00D12001 Video Accel: DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeHEVC_VLD_Main DXVA2_ModeHEVC_VLD_Main10 DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps= D3D9 Overlay: Supported DXVA-HD: Supported DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled MPO MaxPlanes: 1 MPO Caps: Not Supported MPO Stretch: Not Supported MPO Media Hints: Not Supported MPO Formats: Not Supported PanelFitter Caps: Not Supported PanelFitter Stretch: Not Supported ------------- Sound Devices ------------- Description: 2870 (NVIDIA High Definition Audio) Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0072&SUBSYS_10438520&REV_1001 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: nvhda64v.sys Driver Version: 1.03.0036.0006 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 15-Dec-17 12:00:00 AM, 226760 bytes Other Files: Driver Provider: NVIDIA Corporation HW Accel Level: Basic Cap Flags: 0xF1F Min/Max Sample Rate: 100, 200000 Static/Strm HW Mix Bufs: 1, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Description: Realtek Digital Output (Realtek High Definition Audio) Default Sound Playback: No Default Voice Playback: No Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1458A002&REV_1003 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: RTKVHD64.sys Driver Version: 6.00.0001.7535 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 16-Jun-15 12:00:00 AM, 4504320 bytes Other Files: Driver Provider: Realtek Semiconductor Corp. HW Accel Level: Basic Cap Flags: 0xF1F Min/Max Sample Rate: 100, 200000 Static/Strm HW Mix Bufs: 1, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No --------------------- Sound Capture Devices --------------------- Description: Realtek Digital Input (Realtek High Definition Audio) Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: RTKVHD64.sys Driver Version: 6.00.0001.7535 (English) Driver Attributes: Final Retail Date and Size: 6/24/2015 23:57:00, 4504320 bytes Cap Flags: 0x1 Format Flags: 0xFFFFF --------------------- Video Capture Devices Number of Devices: 0 --------------------- ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Splashtop Virtual Hid Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x00FF, 0xBACC FF Driver: n/a Device Name: Splashtop Virtual Hid Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x00FF, 0xBACC FF Driver: n/a Device Name: Splashtop Virtual Hid Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x00FF, 0xBACC FF Driver: n/a Device Name: Micr Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x045E, 0x07B2 FF Driver: n/a Device Name: Micr Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x045E, 0x07B2 FF Driver: n/a Device Name: Micr Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x045E, 0x07B2 FF Driver: n/a Device Name: Microsoft Hardware USB Mouse Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x045E, 0x07B2 FF Driver: n/a Device Name: Micr Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x045E, 0x07B2 FF Driver: n/a Device Name: Gaming Mouse G502 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC332 FF Driver: n/a Device Name: Gaming Mouse G502 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC332 FF Driver: n/a Device Name: Gaming Mouse G502 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC332 FF Driver: n/a Device Name: Gaming Mouse G502 Attached: 1 Controller ID: 0x0 Vendor/Product ID: 0x046D, 0xC332 FF Driver: n/a Poll w/ Interrupt: No ----------- USB Devices ----------- + USB Root Hub (USB 3.0) | Vendor/Product ID: 0x8086, 0x8C31 | Matching Device ID: USB\ROOT_HUB30 | Service: USBHUB3 | Driver: USBHUB3.SYS, 12/12/2017 12:54:55, 555416 bytes | +-+ USB Composite Device | | Vendor/Product ID: 0x046D, 0xC332 | | Location: Port_#0004.Hub_#0003 | | Matching Device ID: USB\COMPOSITE | | Service: usbccgp | | Driver: usbccgp.sys, 9/30/2017 02:41:08, 168856 bytes | | | +-+ USB Input Device | | | Vendor/Product ID: 0x046D, 0xC332 | | | Location: 0000.0014.0000.004.000.000.000.000.000 | | | Matching Device ID: USB\Class_03&SubClass_01 | | | Service: HidUsb | | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes | | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes | | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes | | | | | +-+ HID-compliant mouse | | | | Vendor/Product ID: 0x046D, 0xC332 | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE | | | | Service: mouhid | | | | Driver: mouhid.sys, 9/30/2017 02:41:08, 32768 bytes | | | | Driver: mouclass.sys, 9/30/2017 02:41:08, 57240 bytes | | | | +-+ USB Input Device | | | Vendor/Product ID: 0x046D, 0xC332 | | | Location: 0000.0014.0000.004.000.000.000.000.000 | | | Matching Device ID: USB\Class_03 | | | Service: HidUsb | | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes | | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes | | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes | | | | | +-+ HID Keyboard Device | | | | Vendor/Product ID: 0x046D, 0xC332 | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | | | | Service: kbdhid | | | | Driver: kbdhid.sys, 9/30/2017 02:41:08, 40448 bytes | | | | Driver: kbdclass.sys, 9/30/2017 02:41:08, 63384 bytes | | +-+ Microsoft Mouse and Keyboard Detection Driver (USB) | | Vendor/Product ID: 0x045E, 0x07B2 | | Location: Port_#0009.Hub_#0003 | | Matching Device ID: USB\VID_045E&PID_07B2 | | Upper Filters: dc3d | | Service: usbccgp | | Driver: dc3d.sys, 12/9/2015 14:19:58, 95024 bytes | | Driver: usbccgp.sys, 9/30/2017 02:41:08, 168856 bytes | | Driver: WdfCoInstaller01011.dll, 3/19/2014 15:27:44, 1795952 bytes | | | +-+ Microsoft Hardware USB Keyboard | | | Vendor/Product ID: 0x045E, 0x07B2 | | | Location: 0000.0014.0000.009.000.000.000.000.000 | | | Matching Device ID: usb\vid_045e&pid_07b2&mi_00 | | | Service: HidUsb | | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes | | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes | | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes | | | Driver: coin99itp.dll, 11/12/2015 12:07:34, 466728 bytes | | | | | +-+ HID Keyboard Device | | | | Vendor/Product ID: 0x045E, 0x07B2 | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD | | | | Service: kbdhid | | | | Driver: kbdhid.sys, 9/30/2017 02:41:08, 40448 bytes | | | | Driver: kbdclass.sys, 9/30/2017 02:41:08, 63384 bytes | | | | +-+ Microsoft Hardware USB Mouse | | | Vendor/Product ID: 0x045E, 0x07B2 | | | Location: 0000.0014.0000.009.000.000.000.000.000 | | | Matching Device ID: usb\vid_045e&pid_07b2&mi_01 | | | Service: HidUsb | | | Driver: hidusb.sys, 9/30/2017 02:41:08, 40960 bytes | | | Driver: hidclass.sys, 9/30/2017 02:41:08, 187392 bytes | | | Driver: hidparse.sys, 2/10/2018 17:47:33, 46080 bytes | | | Driver: coin99ip.dll, 11/10/2015 11:03:14, 466728 bytes | | | | | +-+ HID-compliant mouse | | | | Vendor/Product ID: 0x045E, 0x07B2 | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE | | | | Service: mouhid | | | | Driver: mouhid.sys, 9/30/2017 02:41:08, 32768 bytes | | | | Driver: mouclass.sys, 9/30/2017 02:41:08, 57240 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 334.8 GB Total Space: 457.4 GB File System: NTFS Model: SanDisk SDSSDA480G Drive: D: Model: HL-DT-ST DVDRAM GH24NSB0 SCSI CdRom Device Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:02, 159744 bytes -------------- System Devices -------------- Name: High Definition Audio Controller Device ID: PCI\VEN_10DE&DEV_0FBA&SUBSYS_85201043&REV_A1\4&1286464&0&0108 Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 86016 bytes Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 96768 bytes Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 379392 bytes Name: High Definition Audio Controller Device ID: PCI\VEN_8086&DEV_8C20&SUBSYS_A0021458&REV_05\3&11583659&0&D8 Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 86016 bytes Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 96768 bytes Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.16299.0015 (English), 9/30/2017 02:40:59, 379392 bytes Name: PCI-to-PCI Bridge Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_50011458&REV_D5\3&11583659&0&E3 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes Name: Realtek PCIe GBE Family Controller Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_06\4&1DCB0711&0&00E2 Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0406.2015 (English), 9/30/2017 02:41:03, 604160 bytes Name: Intel(R) 8 Series/C220 Series PCI Express Root Port #3 - 8C14 Device ID: PCI\VEN_8086&DEV_8C14&SUBSYS_50011458&REV_D5\3&11583659&0&E2 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes Name: Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller Device ID: PCI\VEN_8086&DEV_8C02&SUBSYS_B0051458&REV_05\3&11583659&0&FA Driver: C:\WINDOWS\system32\DRIVERS\iaStorA.sys, 12.08.0000.1016 (English), 8/7/2013 14:23:46, 644968 bytes Name: Intel(R) Xeon(R) processor E3-1200 v3/4th Gen Core processor PCI Express x16 Controller - 0C01 Device ID: PCI\VEN_8086&DEV_0C01&SUBSYS_50001458&REV_06\3&11583659&0&08 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes Name: Intel(R) Z87 LPC Controller - 8C44 Device ID: PCI\VEN_8086&DEV_8C44&SUBSYS_50011458&REV_05\3&11583659&0&F8 Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:03, 18840 bytes Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft) Device ID: PCI\VEN_8086&DEV_8C31&SUBSYS_50071458&REV_05\3&11583659&0&A0 Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.16299.0125 (English), 12/8/2017 12:24:06, 437144 bytes Name: Intel(R) 8 Series/C220 Series SMBus Controller - 8C22 Device ID: PCI\VEN_8086&DEV_8C22&SUBSYS_50011458&REV_05\3&11583659&0&FB Driver: n/a Name: Intel(R) 8 Series/C220 Series PCI Express Root Port #1 - 8C10 Device ID: PCI\VEN_8086&DEV_8C10&SUBSYS_50011458&REV_D5\3&11583659&0&E0 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes Name: Intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26 Device ID: PCI\VEN_8086&DEV_8C26&SUBSYS_50061458&REV_05\3&11583659&0&E8 Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 95640 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 454040 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 513944 bytes Name: PCI-to-PCI Bridge Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_88921458&REV_41\4&3AD3A588&0&00E3 Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.16299.0248 (English), 2/10/2018 19:06:11, 362904 bytes Name: Intel(R) Management Engine Interface Device ID: PCI\VEN_8086&DEV_8C3A&SUBSYS_1C3A1458&REV_04\3&11583659&0&B0 Driver: C:\WINDOWS\system32\DRIVERS\TeeDriverW8x64.sys, 11.07.0000.1040 (English), 7/27/2017 08:47:50, 206496 bytes Name: NVIDIA GeForce GTX 960 Device ID: PCI\VEN_10DE&DEV_1401&SUBSYS_85201043&REV_A1\4&1286464&0&0008 Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\dbInstaller.exe, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 464880 bytes Driver: C:\WINDOWS\system32\DRIVERS\NVIDIA Corporation\Drs\nvdrsdb.bin, 1/24/2018 13:23:45, 1473020 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\NvContainerSetup.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 4181928 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\NvCplSetupInt.exe, 1.00.0007.0000 (English), 1/24/2018 13:23:45, 101308928 bytes Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19952 bytes Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 219800 bytes Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 144592 bytes Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0224 (English), 1/24/2018 13:23:45, 19760 bytes Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 262536 bytes Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171712 bytes Driver: C:\Program Files\NVIDIA Corporation\license.txt, 10/28/2017 06:50:09, 27203 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 1/24/2018 13:23:45, 849392 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 419312 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 1/24/2018 13:23:45, 78094 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 509936 bytes Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.9077 (English), 1/24/2018 13:23:45, 918088 bytes Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 438768 bytes Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 2.00.0004.0000 (English), 1/24/2018 13:23:45, 532040 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvlddmkm.sys, 23.21.0013.9077 (English), 1/25/2018 10:41:38, 17493824 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nv-vk64.json, 1/24/2018 13:23:45, 669 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dumx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 18969472 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dumx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19358800 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvinitx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 197992 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumdx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 931584 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglshim64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 173432 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglv64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35404592 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvumdshimx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 577056 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2umx.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 28909824 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2umx_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 29740528 bytes Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1126888 bytes Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 988464 bytes Driver: C:\WINDOWS\system32\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 616240 bytes Driver: C:\WINDOWS\system32\nvDecMFTMjpeg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 740336 bytes Driver: C:\WINDOWS\system32\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1325384 bytes Driver: C:\WINDOWS\system32\nvEncMFThevc.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1334808 bytes Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 795928 bytes Driver: C:\WINDOWS\system32\nvapi64.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 4580832 bytes Driver: C:\WINDOWS\system32\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 40269808 bytes Driver: C:\WINDOWS\system32\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 12843496 bytes Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 4308976 bytes Driver: C:\WINDOWS\system32\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1134768 bytes Driver: C:\WINDOWS\system32\nvinfo.pb, 1/24/2018 13:23:45, 48407 bytes Driver: C:\WINDOWS\system32\nvmcumd.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 618928 bytes Driver: C:\WINDOWS\system32\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 19796336 bytes Driver: C:\WINDOWS\system32\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 13444552 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nv-vk32.json, 1/24/2018 13:23:45, 669 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dum.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15591424 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvd3dum_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 15912784 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvinit.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 171896 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvldumd.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 774304 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglshim32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 145616 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvoglv32.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 27975152 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvumdshim.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 495352 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2um.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 24473608 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\nvwgf2um_cfg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 25371952 bytes Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 1054704 bytes Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.9077 (English), 1/24/2018 13:23:45, 939832 bytes Driver: C:\WINDOWS\SysWow64\NvIFROpenGL.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 506864 bytes Driver: C:\WINDOWS\SysWow64\nvDecMFTMjpeg.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 599352 bytes Driver: C:\WINDOWS\SysWow64\nvEncMFTH264.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1043128 bytes Driver: C:\WINDOWS\SysWow64\nvEncMFThevc.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 1049480 bytes Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 635248 bytes Driver: C:\WINDOWS\SysWow64\nvapi.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 3894304 bytes Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 35180016 bytes Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 10900248 bytes Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.9077 (English), 1/24/2018 13:23:45, 3709424 bytes Driver: C:\WINDOWS\SysWow64\nvfatbinaryLoader.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 885680 bytes Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 16449872 bytes Driver: C:\WINDOWS\SysWow64\nvptxJitCompiler.dll, 23.21.0013.9077 (English), 1/24/2018 13:23:45, 11026080 bytes Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_7a39871618b19f06\VulkanRT-Installer.exe, 1.00.0065.0000 (English), 1/24/2018 13:23:45, 979288 bytes Driver: C:\WINDOWS\system32\nvdispco6439077.dll, 2.00.0049.0004 (English), 1/24/2018 13:23:45, 1976120 bytes Driver: C:\WINDOWS\system32\nvdispgenco6439077.dll, 2.00.0026.0002 (English), 1/24/2018 13:23:45, 1673616 bytes Name: Intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D Device ID: PCI\VEN_8086&DEV_8C2D&SUBSYS_50061458&REV_05\3&11583659&0&D0 Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 95640 bytes Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 454040 bytes Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.16299.0015 (English), 9/30/2017 02:41:08, 513944 bytes Name: Intel(R) 4th Gen Core processor DRAM Controller - 0C00 Device ID: PCI\VEN_8086&DEV_0C00&SUBSYS_50001458&REV_06\3&11583659&0&00 Driver: n/a ------------------ DirectShow Filters ------------------ DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.16299.0015 WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.16299.0015 WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.16299.0015 MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.16299.0015 Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.16299.0015 WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.16299.0015 WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.16299.0015 Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.16299.0015 Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.16299.0015 DV Muxer,0x00400000,0,0,qdv.dll,10.00.16299.0015 Color Space Converter,0x00400001,1,1,quartz.dll,10.00.16299.0015 WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.16299.0015 AVI Splitter,0x00600000,1,1,quartz.dll,10.00.16299.0015 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.16299.0015 SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.16299.0015 Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.16299.0248 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015 StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.16299.0015 MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015 MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.16299.0015 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015 VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.16299.0015 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.16299.0015 Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.16299.0015 SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.16299.0015 Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.16299.0015 DV Splitter,0x00600000,1,2,qdv.dll,10.00.16299.0015 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.16299.0015 Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.16299.0015 ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.16299.0015 Video Renderer,0x00800001,1,0,quartz.dll,10.00.16299.0015 MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.16299.0015 Line 21 Decoder,0x00600000,1,1,, Video Port Manager,0x00600000,2,1,quartz.dll,10.00.16299.0015 Vectorworks Frame Source Filter,0x00200000,0,1,FrameSourceFilter.dll, Video Renderer,0x00400000,1,0,quartz.dll,10.00.16299.0015 VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.16299.0015 WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.16299.0015 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax, File writer,0x00200000,1,0,qcap.dll,10.00.16299.0015 DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.16299.0015 Overlay Mixer2,0x00200000,1,1,, AVI Draw,0x00600064,9,1,quartz.dll,10.00.16299.0015 Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.16299.0015 WST Pager,0x00200000,1,1,WSTPager.ax,10.00.16299.0015 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.16299.0015 DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.16299.0015 SampleGrabber,0x00200000,1,1,qedit.dll,10.00.16299.0015 Null Renderer,0x00200000,1,0,qedit.dll,10.00.16299.0015 MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.16299.0015 Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.16299.0015 StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.16299.0015 Smart Tee,0x00200000,1,2,qcap.dll,10.00.16299.0015 Overlay Mixer,0x00200000,0,0,, AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.16299.0015 AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.16299.0015 Wave Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015 MIDI Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015 Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.16299.0015 File stream renderer,0x00400000,1,1,quartz.dll,10.00.16299.0015 Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.16299.0015 StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.16299.0015 AVI Mux,0x00200000,1,0,qcap.dll,10.00.16299.0015 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.16299.0015 File Source (Async.),0x00400000,0,1,quartz.dll,10.00.16299.0015 File Source (URL),0x00400000,0,1,quartz.dll,10.00.16299.0015 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.16299.0015 Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.16299.0248 BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.16299.0015 MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.16299.0015 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Video Compressors: WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.16299.0248 WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.16299.0015 MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.16299.0248 DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.16299.0015 MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.16299.0015 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.16299.0015 WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.16299.0015 IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015 PCM,0x00200000,1,1,quartz.dll,10.00.16299.0015 Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.16299.0015 GSM 6.10,0x00200000,1,1,quartz.dll,10.00.16299.0015 CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015 CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.16299.0015 MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.16299.0015 Audio Capture Sources: Realtek Digital Input (Realtek High Definition Audio),0x00200000,0,0,qcap.dll,10.00.16299.0015 PBDA CP Filters: PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.16299.0192 PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192 PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.16299.0192 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.16299.0015 Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.16299.0015 WDM Streaming Capture Devices: Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Realtek HD Digital input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 ,0x00000000,0,0,, WDM Streaming Rendering Devices: Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 ,0x00000000,0,0,, BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015 Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015 Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015 Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.16299.0015 Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.16299.0015 Multi-Instance Capable VBI Codecs: VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.16299.0015 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.16299.0015 MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.16299.0015 BDA CP/CA Filters: Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.16299.0192 Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.16299.0192 PTFilter,0x00200000,0,0,EncDec.dll,10.00.16299.0192 XDS Codec,0x00200000,0,0,EncDec.dll,10.00.16299.0192 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.16299.0015 Audio Renderers: 2870 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015 Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.16299.0015 Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.16299.0015 DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015 DirectSound: 2870 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015 Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.16299.0015 ---------------------------- Preferred DirectShow Filters ---------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred] <media subtype GUID>, [<filter friendly name>, ]<filter CLSID> MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS {78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec {58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject {5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec {44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS {20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject --------------------------- Media Foundation Transforms --------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms] <category>: <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version> Video Decoders: NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpeg.dll, 23.21.0013.9077 Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248 DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.16299.0015 Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.16299.0015 Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.16299.0248 WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.16299.0015 WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.16299.0015 MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.16299.0015 Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.16299.0015 Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.16299.0248 Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.16299.0015 HEVCVideoExtension Video Encoders: NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264.dll, 23.21.0013.9077 NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevc.dll, 23.21.0013.9077 H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.16299.0015 WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.16299.0248 Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.16299.0015 H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.16299.0015 WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.16299.0015 Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.16299.0015 HEVCVideoExtensionEncoder Video Effects: Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.16299.0015 Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.16299.0015 VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.16299.0015 Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.16299.0015 Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.16299.0015 Video Processor: Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.16299.0098 Audio Decoders: Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.16299.0015 MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.16299.0015 WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.16299.0015 Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.16299.0015 A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.16299.0248 GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.16299.0248 WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.16299.0015 Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.16299.0015 Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.16299.0015 Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.16299.0015 WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.16299.0015 G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.16299.0248 IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.16299.0248 MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.16299.0015 Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.16299.0015 ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.16299.0248 Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.16299.0015 DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.16299.0015 Audio Encoders: LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.16299.0015 MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.16299.0248 Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.16299.0015 WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.16299.0015 MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.16299.0015 Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.16299.0015 WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.16299.0015 Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.16299.0015 Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.16299.0015 Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.16299.0015 Audio Effects: AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.16299.0015 Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.16299.0015 Multiplexers: Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.16299.0064 Others: Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.16299.0248 -------------------------------------------- Media Foundation Enabled Hardware Categories -------------------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT] EnableDecoders = 1 EnableEncoders = 1 EnableVideoProcessors = 1 ------------------------------------- Media Foundation Byte Stream Handlers ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers] [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred] <file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred] .3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred .adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred .am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler .amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred .asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred .dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred .dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler .ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred .flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred .m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred .mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred .mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred .mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred .sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred .smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred .tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred .vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred .wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred .weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred .webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred .wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred .wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred -------------------------------- Media Foundation Scheme Handlers -------------------------------- [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers] [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred] <URL type>, <handler CLSID>, <brief description>[, Preferred] file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred ------------------------------------- Preferred Media Foundation Transforms ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred] <media subtype GUID>, [<transform friendly name>, ]<transform CLSID> {E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} {00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4} {EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B} MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9} {A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F} {A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F} {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT {73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E} MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} {63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879} MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT {53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905} MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject {3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject {33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9} MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject {30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000} {30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000} MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432} {0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9} {00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E} {0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A} {00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879} {00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F} MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B} {00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC} {00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE} WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514} {00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786} KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD} ------------------------------------- Disabled Media Foundation Transforms ------------------------------------- [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse] <transform CLSID> ------------------------ Disabled Media Sources ------------------------ [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse] <media source CLSID> --------------- EVR Power Information --------------- Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality) Quality Flags: 2576 Enabled: Force throttling Allow half deinterlace Allow scaling Decode Power Usage: 100 Balanced Flags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 50 PowerFlags: 1424 Enabled: Force throttling Allow batching Force half deinterlace Force scaling Decode Power Usage: 0 --------------- Diagnostics --------------- Windows Error Reporting: +++ WER0 +++: Fault bucket , type 0 Event Name: AppHangB1 Response: Not available Cab Id: 0 Problem signature: P1: Vectorworks2018.exe P2: 23.0.2.0 P3: 5a541f61 P4: 3b74 P5: 134217728 P6: P7: P8: P9: P10: +++ WER1 +++: Fault bucket , type 0 Event Name: AppHangTransient Response: Not available Cab Id: 0 Problem signature: P1: Vectorworks2018.exe P2: 23.0.2.0 P3: 5a541f61 P4: unknown P5: unknown P6: unknown P7: unknown P8: P9: P10: +++ WER2 +++: Fault bucket 129580992988, type 5 Event Name: RADAR_PRE_LEAK_64 Response: Not available Cab Id: 0 Problem signature: P1: CineRenderNEM.exe P2: 18.0.5.8 P3: 10.0.16299.2.0.0 P4: P5: P6: P7: P8: P9: P10: +++ WER3 +++: Fault bucket , type 0 Event Name: AppHangB1 Response: Not available Cab Id: 0 Problem signature: P1: Vectorworks2018.exe P2: 23.0.2.0 P3: 5a541f61 P4: a801 P5: 134217728 P6: P7: P8: P9: P10: +++ WER4 +++: Fault bucket 1250722863414590646, type 5 Event Name: RADAR_PRE_LEAK_WOW64 Response: Not available Cab Id: 0 Problem signature: P1: AcroRd32.exe P2: 18.11.20038.5321 P3: 10.0.16299.2.0.0 P4: P5: P6: P7: P8: P9: P10: +++ WER5 +++: Fault bucket 1572764199385109353, type 5 Event Name: WindowsUpdateFailure3 Response: Not available Cab Id: 0 Problem signature: P1: 10.0.16299.248 P2: 800704cf P3: 00000000-0000-0000-0000-000000000000 P4: Scan P5: 0 P6: 0 P7: 0 P8: <<PROCESS>>: AgentPackageWindowsUpdate.exe P9: {8B24B027-1DEE-BABB-9A95-3517DFB9C552} P10: 0 +++ WER6 +++: Fault bucket , type 0 Event Name: WindowsUpdateFailure3 Response: Not available Cab Id: 0 Problem signature: P1: 10.0.16299.248 P2: 800704cf P3: 00000000-0000-0000-0000-000000000000 P4: Scan P5: 0 P6: 0 P7: 0 P8: <<PROCESS>>: AgentPackageWindowsUpdate.exe P9: {8B24B027-1DEE-BABB-9A95-3517DFB9C552} P10: 0 +++ WER7 +++: Fault bucket , type 0 Event Name: WindowsUpdateFailure3 Response: Not available Cab Id: 0 Problem signature: P1: 10.0.16299.248 P2: 800704cf P3: 00000000-0000-0000-0000-000000000000 P4: Scan P5: 0 P6: 0 P7: 0 P8: <<PROCESS>>: AgentPackageWindowsUpdate.exe P9: {8B24B027-1DEE-BABB-9A95-3517DFB9C552} P10: 0 +++ WER8 +++: Fault bucket , type 0 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: GIB EzyBrace®.exe P2: 1.0.0.0 P3: 57b4f74f P4: KERNELBASE.dll P5: 10.0.16299.248 P6: 13ae3814 P7: c000041d P8: 001008c2 P9: P10: +++ WER9 +++: Fault bucket , type 0 Event Name: CLR20r3 Response: Not available Cab Id: 0 Problem signature: P1: WIN5ZDTNVII11ZO1TGEL1CLQLEA5TUCM P2: 1.0.0.0 P3: 57b4f74f P4: System.Windows.Forms P5: 4.7.2556.0 P6: 59b8360c P7: 2c8c P8: 168 P9: System.ComponentModel.Win32 P10: -
Hi to all users Our office has been using VW2018 (this also happened in 2017) and noticed a fantastic degradation in performance, reliability and stability. The program has a time delay for all actions almost immediately this is not a phenomenon that progressively gets worse although the time delay in itself can get worse. It is generally unstable with simple actions like the fill paint bucket tool causing the program to not respond indefinitely and crashing. There is also another major problem which is the object info palette struggling to refresh at a rate which is useful. Due to these problems the program is borderline unusable causing massive delays in drawing times. We are strongly considering abandoning the software package for a suite that will just at the least be responsive in a manner which doesn't cause efficiency issues, which is a shame as the software itself offers a workflow we really enjoy. All the office machines meet the minimum requirements and 1 machine in particular exceeds the requirements but is not free from the issues listed above (however it does not suffer the problems at the frustrating levels the other work stations do) I have seen this issue or similar issues raised with little to no feedback. (But to acknowledge JimW, as he does respond but I am yet to find an answer which addresses the issues) This is not a cheap package, and with the upgrade model the business is pushing we are constantly being pushed into updating every year to a newer version.... But why ? the previous version didn't work properly and the issues never got fixed. so why should we pay to upgrade to a newer version that also wont work. We have contacted the local distributor and spoken with their tech department provided files, computer specs and from their side they have stated the solution was to start from scratch and build the master file as new, in an attempt to (if any exist)remove any errors in older files from being carried over into the new version. This was completed and solves nothing. I know this is the wrong section but I cannot create a thread in the "known issues" Any response is greatly appreciated.
