Hi, I'm new to VW and this forum. Looking to see if anyone had same issues and what the fix or workaround is - I have two questions please
1) When using Label Legend Manager I can add a name, enable focus and color, etc, and activate but when I go to Edit Layout
It looks different than the tutorial. Instead of the labels showing on the left in 2D there is some kind of 3D message on the right
and after I drag them to the light in the middle of the edit layout and exit they do not show up as blue squares and hence never show up later.
2) I focused a light against the tutorials pipe and drape, and set the focus point, adjusted the beam settings, angles, brightness, etc rendered in 3D
and the first light position and beam show correctly, as Ul-1, but then it asks to use the mirror tool to create Ul-2, etc, and every time I do and look in 3D
view that next uplight is at like a 45 degree angle to the pipe and drape, so it is wrong, instead of mirroring exactly. Can someone please explain why?
Is there an Object info setting to fix this or a workaround? Did I mirror it wrong somehow?
thanks
