richardavatar
  • Content Count
    9
Everything posted by richardavatar
  1. richardavatar
    3D Connexion Spacemouse
    I am finding that a real barrier to me getting started with Vectorworks is that my 3D Connexion Spacemouse, that works really well with Sketchup, just doesn't seem to work well enough with VW. There are some long and complicated threads in the past but I can't get to the bottom of whether the Spacemouse really works with Vectorworks. If it does I could really use some help setting it up as it doesn't straightforward. thanks
  2. richardavatar
    for anyone else who looks at this - I discovered that the problem was that the Spacemouse had to be in 'Target Camera Mode' for navigation to work properly. pressing button 1 on the Spacemouse enterprise cycles between modes
  3. richardavatar
    hi unfortunately those settings don't seem to work for me. Not having roll is confusing as you really need all axes to navigate easily. I've noticed that in 3D mode the model seems to tilt around a point some way from the model itself which makes it even harder to control. Is there a setting that will change this?
  4. richardavatar
    thanks for people's input on this... So, I have managed to get to the point that the model doesn't fly off the screen uncontrallably, but I have no where near the level of control that I have with Sketchup and I don't think I could stand to work like this. As soon as I go into 3D mode the way that the 2D blue settings worked has changed (speed sensitivity) I have no idea why roll has to be disabled as this is a key control Perhaps this is all because VW wasn't really designed as a 3D software originally
  5. richardavatar
    Hi thanks for taking the time to answer this post. Yes I have downloaded SP3 and use the latest driver So far I have only been able to get 2D top view to work, using these mappings attached. I just need the right mappings for the green axes that do not conflict with these. Why do you prefer roll switched off? I use all of the axes in Sketchup and it all works really well. I wouldn't want to disable any of the axes in VW. I havent' spent much time with VW due to not being able to get the Spacemouse working and being able to do most things in Sketchup. I think you are the first person to say you need to activate the flyover tool for it to work. I was just selecting a perspective view. What happens if you then need to select another tool? Do you use a particular perspective view to navigate successfully? I will try what you suggested activating the flyover tool if I can get the axes mappings for the green axes that will work with those that I know work on the blue axes can't help feeling this is all alot more complicated than it needs to be. I have actually been in touch with 3D Connexion who say there is a problem with Vectorworks, but that doesnt explain why some people seem to have got the Spacemouse to work I just tried it with my blue mappings and your green with the fly over tool active - this didn't work!
  6. richardavatar
    Hi I am using Mac OS X 10.12.6 with Vectorworks 2018 SP2 As I mentioned above the only mappings that I can get to work reliably are in 2D I can't get spin, tilt and roll to work in a way that I can control things
  7. richardavatar
    HI Andy It is not about the speed - it is getting a set of mappings that actually moves in the direction I expect it to. This is all so much easier with Sketchup - I am seriously considering giving up with Vectoworks entirely
  8. richardavatar
    I have tried perspective, but it is still all over the place unfortunately
  9. richardavatar
    thanks, but I still can't get it to be controllable I'm afraid, The only mode I can get to work predictably is top view / 2D which kind of defeats the object of having a 3D mouse. I have tried lots of different settings, but no joy
