tavbut
19 -
@Tom W. Yes, I use space object to display space name and altitude in section VPs. In top plan there is no issue with overlapping. @Nikolay ZhelyazkovIt's great to know it's on your radar. How are you thinking about this? The idea of a dialog that let's you select elegible objects does not seem like it would make things faster because in some way it will still be a tag to tag, or object to object approach. Ideally the tool should be able to identify the objects that are seen/visible in each viewport and attach accordingly (I can imagine it is a mayor task to program). In the case of tagging space objects in section viewports it would be wonderfull to have a boole option that makes the tagg only attach to spaces being cut by the section line. Or maybe that should be a viewport feature like turning on story height indicators.
@Tom W. I can't thank you enough for your response. I agree on using classes just for visibilities. I'll try these functions soon, and probably encounter the same issues with section viewports. In fact, now that I think of it, I already have. Data tagging door and window objects do that too, the tags attach to objects that are not visible in the section viewport and that is REALLY annoying (using both collective and individual tagging). Also when tagging space objects the same happens. It is very tricky to tag space objects one by one so I tend to use collective tagging, but then you have to decipher which is the tag that corresponds to the space shown in that part of the viewport. Depending on the project that often means you'll end up getting a bunch of data tags on top of each other, move them one by one to see which one is the right one and delete all others...complete nightmare indeed. It would be wonderfull if data tags had the ability to just attach to visible objects.
I'm trying to achieve something like this.. I need to submit/deliver 2 kind of finishing documents to clients: Finish indicators on drawings and finish report by space. Honestly this is a sour topic for me, it's one of the things colleagues from other softwares boast about when comparing to vectorworks and I haven't been able to "defend" myself. I'm hoping the functionality exists and I just don't know how to do it, and if that's the case I apologize in advance for dragging you in... Anyways, I'm going to lay out the way I do these things and the advantages/disadvantages to see if there is a more appropriate way of managing finishing info or any workarounds. 1. Finishing indicators on floorplans, sections and details. That can be done currently with data tag or a callout. Advantages: Callout's connection to a database is an excellent way of managing a structured finish catalog. Callout interface is friendly, allows for keynote annotations on drawings and keynote legends (less text on drawings, good). Data tags can be linked to geometry enabling automation/drawing coordination. They can read materials and class descriptions from objects except walls. Disadvantages: Callouts - There is no connection to the model info whatsoever, so there is no space for automation or drawing coordination. Collaborating on a database over a cloud based file sharing has been impossible for me. Data tags - Lacking the ability to read materials/class descriptions from walls or wall components. (i'll leave an image at the bottom for that, data tag calling for material and class description in the bottom row) 2. Finish worksheet by space/room. I'm currently doing this using the space object. Advantages: Finish categorization by constructive element (wall, floor, ceiling). Database workflow. It's great for the space planning stage, but not so great for detailing and documentation stage. Disadvantages: No connection to the model info(no automation/drawing coordination). Independent database, no relation with the callout's database, so there's the need for maintaining and coordinating 2 separate databases/finish catalogs. Here's the ideal workflow from my point of view: Model objects, assign materials, annotate drawings in viewports with data tags that can read surface or components materials for all objects, and then some sort of code that can report the materials being used by space (I think this part may be tricky). The key ideas here are: Collaboration capabilities, drawing coordination (model to annotation to worsheet or other type of report), reporting (by project, by space). If anyone has an idea on how to accomplish this, PLEASE let me know, and thanks in advance.
@Antonio LandsbergerThat's an excellent way of looking at it. Query all and filter. Thanks!
Non interrupting flyover with trackpad.
tavbut posted a question in Wishlist - Feature and Content Requests
Greetings, I would like to have a way to rotate the view without interrupting the current action, or selecting the flyover tool. Currently it can be done using a mouse by pressing the middle button and option(i belive) at the same time, when you move the cursor the view rotates, then when you release the buttons it comes back to your previous tool automatically. The same should be happening with the track pad. -
Hi everyone! I'm trying to create a Marionette network that works with objects from a set of layers. I could do that using the Objects by Criteria node and selecting each layer individually, but I wonder if there is a way to call for a set of layers by any common parameter like tag, story, or the first letter layer's name.
@Marissa Farrell Thanks!
Hi, Is there a way to delete Marionette menu commands? I've been doing some tests and now have a bunch of menu commands listed that don't work.
Hi, I want to make a marionette menú command that works on a selected object. I already have my network working, wrapped and ready to hit "Convert to menu command". At the time it is calling/getting the handle of the object through a name node, but I wonder if there is a way to get the handle of the selected object. Can anyone help me?
AVERAGE, MAX and MIN in database headers.
tavbut replied to tavbut's question in Wishlist - Feature and Content Requests
Thanks again for your input! I agree with you, it's a mayor challenge to achieve "converting" database to cell by cell formula. I'm facing all of the issues you describe trying to accomplish that. So, from your point of view, would it be an impossible task for Vectorworks to include the drop down menu options for Database Headers and Database Subrows as I describe above? Or should I give up the idea? I'm just curious if you see some fundamental flaw in the functionality I'm proposing. -
@Pat Stanford I'm sorry to drag you into this topic, I think maybe you know how I could work around this issue I'm having. You have helped me in the past so I figured I ask directly. Do you know of any scrip or command that converts a database into a spreadsheet, placing in each cell the formula that would get the same result as when it was a database? It's complex for me to explain... Thanks in advance! -
Hi everyone, I would like to add this functionality to the database interface inside worksheets. I would want to have control over the header mode and subrow mode, like this: Database Header options: -Sum Values. This is the way the headers work right now. It adds up all the values of every subrow. -Average. This would show an average of all the values in subrows. -Min value. This would show the minimum value of all the values in subrows. -Max value. This would show the maximum value of all the values in subrows. Now, when summarize items is turned on we only have two options: if all the values are de same we get the value as it is, and if they are different we get a "--". If the "sum values" check box is turned on all the values are added up. I suggest to expand that capability as follows: Database subrow options: -Sum Values. This is the way "Sum Values" option work right now. -Average. This would show an average of all the values. -Min value. This would show the minimum value of all the values. -Max value. This would show the maximum value of all the values. Let me know what you think. Maybe there is some other way of looking at the issue at hand? MacBook Pro (14-inch, 2023), Apple M2 Max, 64 GB. OS: macOS Ventura. Vectorworks 2024, Designer -
You could use a conditional to solve that issue: =IF(('recordName'.'fieldName' = 0),'', 'recordName'.'fieldName') Hope that helps!
Sorry for the slightly late reply, but, thanks @Peter Vandewalle !
Thanks for sharing Peter!, I'll try this soon.
