mike11968
    12
Everything posted by mike11968
  1. @Gadzooks Create roof definitely works much better. Thank you!
  2. @Gadzooks the connect combine tool worked for the main structure of the roof but it did not trim the top roof component. As shown in the attachments, the ridge components still overhang.
  3. I am trying to offset 3 sides of a roof component, but it is only allowing 4 sides. Is there anyway to overhang the 3 sides parametrically? As shown in the attachments, I am trying to avoid the components intersecting at the ridge.
  4. as shown in the attachment, the vertical hatch is not rendering out completely leaving a blank white space. I tried changing the wall style and surface hatch components but nothing is working. is there anyway to correct this?
  5. as shown in the attachment, the vertical hatch is not rendering out completely leaving a blank white space. I tried changing the wall style and surface hatch components but nothing is working. is there anyway to correct this?
  6. What settings are needed to get elevations to look like the attachment?
  7. As shown in the image below, theres 8 of the same doors and I would a column that lists the sum of the same door. The red # which represents the quantity in the image is what I'm trying to achieve.
  8. Is there any way to make a column listing the quantity of doors in the door schedule?
  9. that seemed to work but is there any way to eliminate the grayness and just keep the shadows? The look I'm going for is applying the shadows of the top drawing to the hidden line drawing below. Also is there anyway to control the sharpness of the shadows?
  10. Is there any way to get line weights heavier in the foreground of elevation with out drawing on top?
