2,324 -
Everything posted by Dave Donley
@Julia Langsman Believe it or not I had this file in my old saved folders. See if this works Water 2009 v2024.vwx
Hello @dvdvarch if you are on Windows and you are seeing slow launch and performance (unusably slow to do anything) this may be a known issue related to the AI Visualizer and removing the GenerateImage plugin from the Plugins folder may help. There is another update coming to address that problem ASAP.
Would someone be so kind as to tell what I have done wrong please?
Dave Donley replied to Iainy1961's topic in Rendering
Hi @Iainy1961 Showcase is a project to add pre-visualization features directly into Vectorworks. There is a private forum group for this where you can get preview builds and have discussion about this set of features. https://forum.vectorworks.net/index.php?/clubs/ -
Hello @Calbourne this might be happening if you have multiple VCS accounts and you are signing in with one that is not enabled for VSS.
@Iainy1961 You might start a thread in Showcase group about your file. We should be able to replicate what you want, with pre-viz as well. https://forum.vectorworks.net/index.php?/clubs/ -
when I open the AI visualizer, the dialog box is blank?
Dave Donley replied to grant_PD's topic in AI Visualizer
@cberg Next time you can try this, try getting to it from the Model menu AI Visualizer (might have to add to custom workspace, it's under recent changes 2024), there are alerts that will show when Vectorworks thinks certain things are not running or connected. -
Thanks for that @James Russell logged your wishes for our backlog of items for the next version(s). Can you elaborate on auto-prompting a little?
Hello @cberg if the VCS app is shut down during the lifetime of the Vectorworks session you might get issues like that. Does restarting Vectorworks fix it? You can also try right-clicking and choosing the Reload menu item in the palette. -
Turn off Draw Edges in the Shaded rendering. And/or try adding the words "edges", "lines", "neon" to the negative prompt. Pixel color and brightness differences are detected and turned into an image of the edges found. The extra edginess in a Shaded with draw edges on or in a hidden line rendering can cause this glowing edges result. For a prompt you might try being more specific to help the AI understand what it is seeing and what style you are wanting. Like a caption for a photograph. Hope this helps!
@TomKen This feature is available with subscription or Vectorworks Service Select licenses. If you are using multiple logins maybe one of the logins is a VSS or subscription license? If not you would need to upgrade to use the feature. -
Vectorworks 2024 not running after update
Dave Donley replied to thomasone's question in Troubleshooting
The GenerateImage plugin may or may not be involved. If removing it from Plugins folder helps that confirms a bug we found here very recently. There is a workaround to try (if it is related to GenerateImage plugin): Launch and sign in to the Vectorworks Cloud Services app Sign out and back in with Vectorworks application (the upper right signin button or from Home Screen) -
Hello again @gangotti try one thing for me, remove the GenerateImage.vlb file from the Vectorworks Plugins folder. We saw a problem with the AI Visualizer yesterday but only sometimes on Windows 10. Curious if that is a factor at all.
Hello @gangotti your issue sounds similar to this:
Hello @BartHays US law doesn't allow copyrighting of images produced by AI.
.las & .laz import problem with VWX 2023
Dave Donley replied to Jeff Prince's topic in General Discussion
Hello @Jeff Prince and @Benson Shaw We are updating the library used to import LAS and LAZ files and these imports should be fixed in the next major version of Vectorworks. -
shaded renders not looking the same in viewports
Dave Donley replied to grant_PD's topic in Rendering
Might try lower sheet layer DPI values, maybe it is hitting a limit with resolution. -
@grant_PD This looks like a bug if all the values for background, lighting, shaded options are the same between the design layer and viewport. Can you DM me the file so we can investigate it? I see some of the environment reflections on the walls in the VP. Object reflections are not showing on the floor in the VP. -
Incompatible Plug-ins Report: MaxonDocument Builder // MaxonRenderDevice
Dave Donley replied to High_Viz's question in Troubleshooting
@High_Viz Thanks for the details and sorry for the lack of info from me on this. The only AVX example I had before was when users would bypass Apple's installers to install macOS on unsupported Macs that were missing AVX. I will massage this part of the system requirements moving forward to mention your example as well: "Renderworks requires AVX support on AMD and Intel CPUs. Renderworks will not work on older Intel Macs that are missing AVX support, even if macOS 11 is installed on them by bypassing official Apple installers."- 20 replies
- 2
- vectworkworks
- graphics
(and 2 more)
Tagged with:
The K4200 began in 2014, also Renderworks requires AVX support on the processor and maybe this one doesn't have AVX support? Also it requires 64-bit OS. I haven't heard of these plugins not loading before like this. It means there is something missing from the system that these plugins rely on. We have had more issues when Cineware is trying to load or Redshift is being used, related to system requirements. I haven't heard of these plugins not loading before, until now. Maxon's requirements for Cineware 2023 (which is what Vectorworks 2024 uses) are here. Maybe the Windows 10 build version needs to be newer than what is on your computer. https://www.maxon.net/en/requirements/cinema-4d-2023-requirements- 20 replies
- vectworkworks
- graphics
(and 2 more)
Tagged with:
Hello @ratherfishing could you send me a file that shows this in a DM?
Model textures being downsampled on import
Dave Donley replied to Sheebarino's question in Troubleshooting
Shaded render mode limits image resolutions to 2k pixel resolution. Renderworks and Redshift should show full resolution. -
Rendering IPR Window
Dave Donley replied to Kevin K's question in Wishlist - Feature and Content Requests
Hello @Kevin K This is on the public roadmap as "in development". This is possible because Cineware is built-in to Vectorworks, and not a separate application anymore. We are working with Maxon to get this to you as soon as possible. EDIT: Redshift RT is a different Maxon technology still in beta I believe. Redshift IPR is a production-ready technology. https://www.vectorworks.net/en-US/public-roadmap?url=redshift-in-design-layers -
How to get plant image props to render at night correctly?
Dave Donley replied to JonKoch's topic in Rendering
I like the 3D plants and I want to try turning on some lit fog. 🙂 -
@Kevin K I would like the file please, thanks! -
Simple render for Spotlight - Paperworks
Dave Donley replied to Cristiano Alves's topic in Rendering
I agree with @EAlexander without much work you can try turning up the ambient light and turning on ambient occlusion to darken areas where surfaces meet.
