Stefan Bender
Distributor
    149
Posts posted by Stefan Bender
  1. IN the constructor of one of our classes, we query for a VCOM interface:
     Boolean succ = VCOM_SUCCEEDED( ::GS_VWQueryInterface( VectorWorks::EnergyAnalysis::IID_EnergyBuildingElementWinDoorEx, (IVWUnknown**) & m_energy_2021 ) );
    As requested in the SDK documentation, we release that interface in the destructor of the class:
    if (m_energy_2021) {
            m_energy_2021->Release();
          //  m_energy_2021 = nullptr;
    Before releasing, the refcount (m_energy2021->fPtr) is 1, after releasing it is 0 which looks OK.
    But after the end of the destructor, it seems that the VCOM destructor is called again, tries to release again and gives a debug warning saying refcount <0.
    Is this OK? Should I release the interface by myself or wait for the automatic destructor? SDK doc says  I should release, but looking at the source code in various SDK plug-ins I get a mixed feeling, in some routines the interface is released, in others it is not.
    What is the correct workflow? If I am supposed to release the interface by myself, why do I get the debug warning?
    Thanks for any help,
    Stefan Bender
  2. I never used this function, but maybe the dialog is not yet displayed when you call the function? Does it fail on Mac and Windows or just on one platform? Does the control with the given ID actually exist and is it a static text control? Which RGB values are you passing? How did you initialize the CRGBColor? Check if your color has a valid color ref and check the RGB values.
    • Like 1
  3. In one of our plug-ins (search and replace) we have to enter and leave symbol edit mode several times while a dialog is running. I.e., one user action enters symbol edit mode, another one should leave it.
    We are using ISDK->DoMenuName("Group Navigation Chunk",1) to enter symbol edit mode (works) and ISDK->DoMenuName("Group Navigation Chunk",2) to exit, but that does not work.
    Even after the call, you still see the orange "Exit Symbol" rectangle at the right top corner of the screen. Only after you quit the entire dialog, the orange recangle disappears.
    Is this a bug in VW, maybe a redraw issue? Or is there another way to exit symbol edit mode and make the orange rectangle disappear?
    Stefan Bender
  4. I don't know, but I had hoped that these functions are called so the PIO can handle  copy/paste on its own. There are so many Eyedropper options for various graphical attributes that the PIO should need to know which of them are switched on so it can handle the transfer accordingly.
  5. How can PIOs know the current settings of the eyedropper tool so they can support the tool?
    I see two functions
    // Eyedropper notifies that it is going to put the record 'hObjRecordCopy' as record for the current parametric object
                // In this event the object can alter the copy to ensure correct data transfer (the data has already been copied to the record)
                // NOTE! This object's record is still in place when this event is called
                virtual void            OnEyedropperPrepareCopy(MCObjectHandle hObjRecordCopy);
                // Eyedropper notification that has finished with copying this object
                virtual void            OnEyedropperAfterCopy(MCObjectHandle srcObject);
    in VWParametricEventSink that allow the PIOs to do something before and after copying, but how can the PIOs know which of the options of the eyedropper tool are set? Imho some data type "EyedropperToolPreferences" should be passed to these functions so the PIOs can react accordingly.
    Or is there another way for the PIOs to support the eyedropper tool?
    Stefan Bender
  6. Hi all,
    I'm trying to traverse the current workspace to collect information about the tools and menu items.
    Unfortunately, I have not yet found a way to do so. I tried using IWorkspaceFile interface, but all attempts failed.
    I tried
     VCOMPtr<VectorWorks::Workspaces::IWorkspaceFile> pwf(VectorWorks::Workspaces::IID_WorkspaceFile);
       TXString workspace_name;
        gSDK->GetCurrentWorkspaceFile(workspace_name);
    VCOMError e_open = pwf->Open(workspace_name,fsRdPerm);
    but e_open returned 1 and successive calls trying to access the menu bar also didn't work (null pointer returned by IWorkspaceFile::GetMenuBar).
    What mistake did I make? How can I get access to the current workspace?
    Stefan Bender
  7. Hi there,
    how can I find out the localized name of a plug-in (not the one that is currently running) if I only have its universal name? There is an SDK function GetLocalizedPluginName but it is faulty and just returning the universal name. Thanks for any help!
  8. Dear developers,
    have any of you ever used VWWallObj::InsertNewComponent or ISDK::InsertNewComponentN? I'm currently trying to "copy" the cavities of an existing wall that has 3 cavities (with a total width of 32 cm) to another wall with no cavities but a width of 45 cm. I'm adding 3 cavities/components seemingly sucessfully to the target (after reading them from the "source" wall by VWWallObj::GetComponentInfo), but when I analyze the "target" wall, all three cavities have a width of 0 and the overall width of the target wall is 0. The expected and required result is that the "target wall" has the same components and the same overall width as the source wall afterwards. I assume that the problem may be related to the fact that the target wall had no cavities before this. But I couldn't find an object variable or member function of VWWallObj to tell the wall that its width is defined by components and not by "width". Is there something wrong with my workflow? What can I do to make the target wall "accept" the actual widths of the cavities?
    Stefan Bender
  9. Dear developers,
    what does the second parameter "foldersAreCategories" mean? I tried either value and don't see any difference. What is this parameter used for?
    I'm asking because in VW 2019 we have serious problems with the resource browser control in dialogs. Symbols in subfolders do not show up, and clicking on names of subfolders causes flickering and garbage to be drawn (I'm about to write a bug report about that, but it would help to know what this parameter is meant for).
    Stefan Bender
  10. Hi Nebeor,
    This class should exist in all SDK versions since several years. I'm using VW 2018 and VW 2019 (probably not released yet) SDK.
    >>>Why does the name of the class starts with 'XXX' and not 'VW'?
    There's no actual class "XXXX...". XXX means just the name of the plug-in, as you have to derive your own class "XXX.." from the base VW class and overload some of the virtual functions.
    I don't know if there's a documentation, but you may wish to hava a look  at some of the sample plug-ins.
    Regards,
    Stefan Bender
  11. This class should be a lot older than Vectorworks 2015. It's in VWFC/PluginSupport/VWExtensionParametric.h.
    Maybe your plug-ins are not using this class and are based on some older classes and structures.
    Best regards,
    Stefan Bender
  12. Is there a way to assign a class to a Vectorworks object WITHOUT changing the class of its subobjects? Afaik SetClassID also changes the subobject's classes which is not wanted and causes lots of problems and delays in some situations.
    Stefan Bender
  13. Dear developers,
    for a new task I need to add a pair of (name, value) to the OIP of a PIO (see below). The texts need to be static and disabled. Sounds simple, but looking at the widget utility functions in the SDK I can not see how to do that. These functions assume that the values are part of the PIO's record format. But I need to write texts that are arbitrary values, no record fields. Currently I'm trying to define the widgets with type kWidgetStaticTextParam, but then the text at the right hand side of the OIP is empty and I don't know how to set it. SWidgetDefinition only contains a member variable fWidgetText (which would be the left one), but I can't see how to set the right hand value. Which widget type do I need to use and how can I set left and right hand text (as redlined in attached image) without having to "link" a record field to the widget?
    Stefan Bender
  14. Hi Nebeor,
    afaik there's no way to set the default class in the plug-in definition. You can hardly define a default class beside "None" and "Dimension" as you don't know in advance which classes actually exist when the user creates a PIO. You may need to check all places in your code where you create your PIO and set the default class before calling CreateCustomObject. You may also try to change the class within the regeneration code when a PIO is regenerated for the first time, but beware of infinite recursion (setting the class may trigger another regeneration...).
    Hth,
    Stefan Bender
