Hi,
I am setting up a template for our studio so that when used, all the required information is present for each sheet layer (Floor plan sheet layer, Lighting plan sheet layer, Builders works, services plan etc...)
I have 2 queries:
1. Is there any way of setting the required classes for an entire sheet layer ahead of actually creating the viewport. So that when someone does use the template - and creates the new viewport- they don't have to go through all and uncheck what they require to be visible? Ideally if all the relevant classes were already switched on this could save a lot of time.
2. Usually when setting up a drawing pack I'll do my first sheet layer then duplicate the sheet layer and rename/re-do the information required so that the plans are all aligned the same on each sheet layer. With creating a template that is already all set up this isn't possible. Any thoughts on how to ensure the plans are the same on each sheet?
Any advice would be great!
