Arky
Content Count
11 -
Community Reputation
1 NeutralAbout Arky
Rank
Greenhorn
Personal Information
Location
United States
Recent Profile Visitors
This solved my issue, very grateful.
- 7 replies
- viewport
- sheet layer
(and 1 more)
Tagged with:
I spoke to Juan of VW tech support. We figured out the room boundary needs to be turned on for the leader line to be visible.
I have the same question
@Matt Overton That would be an nice feature for VW to add. It would also be nice not having to click into preferences to set the distance.
Thank you Matt for your response. That makes my life so much easier.
I wish there is a way to set distances of nudge. It is handy to quickly move an object out of the way to work on something behind it and nudge the first object back knowing it is back to its original location.
Boost Performance with Metal 2 (Mac)
Arky replied to MAD-LD's question in Wishlist - Feature and Content Requests
Do you guys think by adding external GPU will help? I am using MacBook Pro Touchbar 2017 and is experiencing same slowness. -
Add line style option for dimension witness line
Arky posted a question in Wishlist - Feature and Content Requests
It is drafting standard to show a centerline for a dimension witness line when measuring to the center of an object. I just think VW should make this available since it is so basic. -
Thank you Kevin for your response. That's exactly what I was looking for. Wish VW would make the editing simpler.
I am modifying from a standard title block to match my old title. However, I can't figure out how to add a new field to the title block.
I need to create a riser at the middle of landing of a double L staircase, so I used custom stairs tool for that. While it looks correct in plan, the railing in 3D zig zags out of the stairs. Please let me know how to fix this problem. Thank you all in advance. Custom Stairs.vwx stairs plan.pdf stairs isometric.pdf
