KevinW
    3
Reputation
6 Neutral
Personal Information
  • Occupation
    Production Design
  • Homepage
    www.nimblist.com
  • Hobbies
    Pipe Organs
  • Location
    Lancaster, PA
  1. It would be super helpful to have leader lines that take the opposite color of what's under them. This lets you annotate objects that have the same color as your annotations. See below images. In its simplest form, it would result in the leader being initially white, followed by a simple difference: leaderColor = abs(leader - bg). I imagine this implemented as a tick box somewhere. Custom default and invert colors would be a nice extension of this feature.
  2. Fixed! This is indeed related to the Windows 10 Fall Creators Update. I removed the folder: C:\Users\USERNAME\AppData\Roaming\Nemetschek\Vectorworks Cloud Services\ ...and it works now. Thanks to Alexander Sagatov for the technical support.
  3. I am currently getting this error as well, with the following configuration: Vectorworks: 2018 SP2 Build 401138 64-bit Windows 10 Home 64 bit, up to date. Traceback (most recent call last): File "Vectorworks Cloud Services.py", line 5, in <module> File "DCC.pyc", line 9, in <module> File "PySide\QtGui.pyc", line 12, in <module> File "PySide\QtGui.pyc", line 10, in __load ImportError: DLL load failed: The operating system cannot run %1. Web suggests this is a Problem with PySide importing OpenSSL and not finding ssleay32.dll and libeay32.dll
