Paulo Ferrari
Distributor
    81
Everything posted by Paulo Ferrari
  1. Hi Carrie, @CarriebCarrie I Suggest this Macbook´s Models: - MacBook Pro 16-inch 2019; - MacBook Pro 15-inch 2019; - MacBook Pro 15-inch 2018; - MacBook Pro 15-inch 2017; - MacBook Pro 15-inch 2016; - MacBook Pro Retina 15-inch mid 2015 with AMD Radeon R9 M370X; Regards Paulo Ferrari
  2. Your Hardware is OK. About this Visual Bugs, it's necessary analyze properly what happens. First, You can try reset user library to default. Follow this Troubleshooting: Just do these steps: " 8- Right click on the bottom left of your desktop and choose File Explorer from the menu. 9- Rename the "20XX" folder in the "C: > Users > YourUsername > AppData > Roaming > Nemetschek" folder. To other Info like "2020_old" "
  3. Sound Good, This Visual Bugs, you have in Renderworks Mode? Or in OpenGL or Wireframe? If you have any Print Screen or Video to Show us this bugs, it's helpful. Thanks
  4. Hi @B Cox What is your complete Setup (CPU and RAM Memory)? Regards Paulol Ferrari
  5. Hi @Renaud I don't know how it works your NAS, but to install Vectorworks project sharing server it need Windows or Mac in your machine. I think that most NAS using Linux, and you don't have the access to install softwares. I recommend to install Vectorworks project sharing server in Mac or Windows Machine that have access of this NAS, and set the server to store these files in this NAS. Regards Paulo Ferrari
  6. @Nhan Probably it's a setup in your network (LAN) that block Vectorworks to locate your License Server.
  7. Hi @Nhan Sorry, Now that I understand your question 🙂. To Set up your custom config, You can using this xml file (LoginDialog.xml) there are locate in Vectorworks 2021/Settings/SeriesG Folder. If you setting up a Vectorworks SeriesG in one machine, you can copy this LoginDialog.xml that Vectorworks generated to replicate in other machines. To replicate this file in other computers, I recommend you create a simple installer to put this file in the path automatically. Regards Paulo Ferrari
  8. Hi @MGilc As far as I know, Vectorworks have only Hybrid Objects (2D and 3D) in Library of objects (Blocks). If is necessary, you can import DWG files with this 2D Furnitures Blocks. Regards Paulo Ferrari
  9. @Nhan Hi @Nhan You just need Install Vectorworks 2021 in the Client Machines, using SerieG Serial Number. When you open Vectorworks 2021 SerieG for the first time, it open the Config Window. Most of time the Vectorworks find the Server (Site Protection) automatically. Regards Paulo Ferrari
  10. Hi @TAB I would change this graphic card for one Geforce RTX 2060 or something more powerful. This Quadro K2200 4GB DDR5 have only 640 Cuda Cores (It's too weak to usign with Vectorworks 2020/2021). Comparing the RTX 2060 have 1920 Cuda Cores
  11. Hi @jmal2787 Yes, this is a High End Graphic Card. FYI, During Renderworks (Rendering) Vectorworks using only CPU to processing the Render. And GPU it's using to show the graphics on screen (Palletes, Windows and Menu) 2D Graphics, Wireframe, Design and Sheet Layer. Follow a table that explained exactly that Vectorworks using during the processing.
  12. @Hans-Olav Thanks Hans And @barkest . It's work, I rename the textures Files, but still missing two textures. I will search this two textures here. Regards Paulo Renan Ferrari
  13. Hi my friends I have some problems to import .OBJ files, follow the link to download one of these files. When I tried to import this .OBJ, the textures doesn’t import (Appears this message in attach). Import only the 3D Object without textures. http://vectorworks.com.br/temporario/Obj_File.zip Anyone have a idea, what it's happen? Regards Paulo Renan Ferrari Technical Manager
  14. @beanus Hi Beanus, Hi, that is right. During Renderworks (Rendering) Vectorworks using only CPU to processing the Render. And GPU it's using to show the graphics on screen (Palletes, Windows and Menu) 2D Graphics, Wireframe, Design and Sheet Layer. Follow a table that explained exactly that Vectorworks using during the processing.
  15. @Fernanda Diaz Nice, I'm glad I could help you. Have a nice weekend.
  16. @Tmorgan But it's very strange this problem. I have Vectorworks 2019 since SP0, in both System (Windows and Mac), and this problem never happened with me. My Mac Specs, it's huge worst that your MacBook.
  17. @Tmorgan Copy your older folder (2019) That I recommended backup in (HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks) . And your templates, blocks and user settings come back. Sorry, if I have any Idea to help you in this case, I Will share with you.
  18. @Janvin Lowe Ok Javin, but anyway, When you use again the Gridline Tool. Try this: Deactivate the Automatic Graphics Switching. This Increase the Graphic Performance in Vectorworks. https://support.apple.com/en-us/HT202043
  19. @Janvin Lowe Hi, Can you send to us, your Hardware Specs? Your Vectorworks Service Pack is SP6?
  20. @Tmorgan So, Can you Resetting Vectorworks Preferences. The preferences, plant database, workspaces (etc.) are located in the HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks > 2019 folder. The Library folder for your User account is hidden. The easiest way to display it is to open Finder, then hold down the alt/option key on your keyboard while clicking "Go" from the menu bar, then selecting "Library" 1) Go to this folder found in 'HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks' (I Will Recommend Back Up This folder (2019) First, in other folder) Delete the 2019 Folder 2) Empty the trash, then reboot your computer. If the trash will not empty because a file is in use, reboot before emptying it again. Ps: I edited this information above, from this article.
  21. @Tmorgan Ok, Try Deactivate the Automatic Graphics Switching, and keep me in touch. I'll Waiting your reply.
  22. @Tmorgan Try, Deactivate the Automatic Graphics Switching. Your Vectorworks Service Pack is SP4? https://support.apple.com/en-us/HT202043
  23. @Fernanda Diaz Hi Fernanda, Pls verify your Vectorworks 2019 Service, If you have SP2 Installed, Update to SP4. And always maintain your Graphic Card Driver Update, follow the link to Download the Driver of AMD Fire Pro W210. https://support.hp.com/us-en/drivers/selfservice/hp-z240-tower-workstation/8354563 https://www.amd.com/en/support/professional-graphics/firepro/firepro-wx100-series/firepro-w2100
  24. @khumenny Hi, Can you send to us, your Hardware Specs?
