Paulo Ferrari
Distributor
    81
Reputation
17 Good
Personal Information
  • Location
    Brazil
Recent Profile Visitors
831 profile views
  1. Hi Carrie, @CarriebCarrie I Suggest this Macbook´s Models: - MacBook Pro 16-inch 2019; - MacBook Pro 15-inch 2019; - MacBook Pro 15-inch 2018; - MacBook Pro 15-inch 2017; - MacBook Pro 15-inch 2016; - MacBook Pro Retina 15-inch mid 2015 with AMD Radeon R9 M370X; Regards Paulo Ferrari
  2. Your Hardware is OK. About this Visual Bugs, it's necessary analyze properly what happens. First, You can try reset user library to default. Follow this Troubleshooting: Just do these steps: " 8- Right click on the bottom left of your desktop and choose File Explorer from the menu. 9- Rename the "20XX" folder in the "C: > Users > YourUsername > AppData > Roaming > Nemetschek" folder. To other Info like "2020_old" "
  3. Sound Good, This Visual Bugs, you have in Renderworks Mode? Or in OpenGL or Wireframe? If you have any Print Screen or Video to Show us this bugs, it's helpful. Thanks
  4. Hi @B Cox What is your complete Setup (CPU and RAM Memory)? Regards Paulol Ferrari
  5. Hi @Renaud I don't know how it works your NAS, but to install Vectorworks project sharing server it need Windows or Mac in your machine. I think that most NAS using Linux, and you don't have the access to install softwares. I recommend to install Vectorworks project sharing server in Mac or Windows Machine that have access of this NAS, and set the server to store these files in this NAS. Regards Paulo Ferrari
  6. @Nhan Probably it's a setup in your network (LAN) that block Vectorworks to locate your License Server.
  7. Hi @Nhan Sorry, Now that I understand your question 🙂. To Set up your custom config, You can using this xml file (LoginDialog.xml) there are locate in Vectorworks 2021/Settings/SeriesG Folder. If you setting up a Vectorworks SeriesG in one machine, you can copy this LoginDialog.xml that Vectorworks generated to replicate in other machines. To replicate this file in other computers, I recommend you create a simple installer to put this file in the path automatically. Regards Paulo Ferrari
  8. Hi @MGilc As far as I know, Vectorworks have only Hybrid Objects (2D and 3D) in Library of objects (Blocks). If is necessary, you can import DWG files with this 2D Furnitures Blocks. Regards Paulo Ferrari
  9. @Nhan Hi @Nhan You just need Install Vectorworks 2021 in the Client Machines, using SerieG Serial Number. When you open Vectorworks 2021 SerieG for the first time, it open the Config Window. Most of time the Vectorworks find the Server (Site Protection) automatically. Regards Paulo Ferrari
  10. Hi @TAB I would change this graphic card for one Geforce RTX 2060 or something more powerful. This Quadro K2200 4GB DDR5 have only 640 Cuda Cores (It's too weak to usign with Vectorworks 2020/2021). Comparing the RTX 2060 have 1920 Cuda Cores
  11. Hi @jmal2787 Yes, this is a High End Graphic Card. FYI, During Renderworks (Rendering) Vectorworks using only CPU to processing the Render. And GPU it's using to show the graphics on screen (Palletes, Windows and Menu) 2D Graphics, Wireframe, Design and Sheet Layer. Follow a table that explained exactly that Vectorworks using during the processing.
  12. @Hans-Olav Thanks Hans And @barkest . It's work, I rename the textures Files, but still missing two textures. I will search this two textures here. Regards Paulo Renan Ferrari
  13. Hi my friends I have some problems to import .OBJ files, follow the link to download one of these files. When I tried to import this .OBJ, the textures doesn’t import (Appears this message in attach). Import only the 3D Object without textures. http://vectorworks.com.br/temporario/Obj_File.zip Anyone have a idea, what it's happen? Regards Paulo Renan Ferrari Technical Manager
  14. @beanus Hi Beanus, Hi, that is right. During Renderworks (Rendering) Vectorworks using only CPU to processing the Render. And GPU it's using to show the graphics on screen (Palletes, Windows and Menu) 2D Graphics, Wireframe, Design and Sheet Layer. Follow a table that explained exactly that Vectorworks using during the processing.
