29 -
Reputation
5 NeutralPersonal Information
Location
Germany
Recent Profile Visitors
Hello everyone, I am experiencing unexpected behavior when executing a Marionette command I created. To explain the script: I want to get a pop-up that shows me the perimeter and area of a drawn object (polygon, polyline, square, circle, ellipse, etc.). That works so far. The only problem is that after the command, all objects are converted to a polyline. I would like the objects to remain as they were originally. For example, a square. Does anyone have any idea what I'm doing wrong? File and a little step by step picture attached. Thanks in advance. Laenge+Flaeche.vwx
Hi, Unfortunately it took me a while, as I was on the road the last few days. I'll try to show the steps in a short video. It's my first tutorial 😉 That's why it's a bit chaotic. I hope that I can help you with this. If you have any further questions, please let me know. Bildschirmaufnahme 2025-04-10 um 09.05.44.mov
Hi, I have been missing this function since I started working with Vectorworks 15 years ago. With update 4 the new function of label styles was added to the Spotlight version. (I'm not sure if this is the correct term in the international version as I use the German version. Here it is called “Etikettenformat”. I have built a kind of workaround to partially solve this problem. The labels can be made to look like a spreadsheet row. Unfortunately, before exporting, you always have to update the sheet in which the data is entered and then the label object on the layout sheet. But with this you get a list as PDF which is divided into pages. In my example DIN A4. Unfortunately, the automatic scaling in the columns does not work. If I notice in a project that the strings are getting longer and no longer fit into the column, you can easily adjust the text size in the basic label. My example is related to spotlight data in order to be able to export a fixture sheet. But you can easily adjust die Labels to any Worksheet you want to export a list. Is this what you are looking for? Fix ID Test.pdf
Ah, I got you. The screenshot looks very promising. Something like that would help me. I would be delighted if you could come up with a solution for Mac OS. I really appreciate your support. Thank you very much in advance.
- 8 replies
- marionette
- hyperlink
(and 1 more)
Tagged with:
Hello Marissa, Thank you very much for your support. I may not understand what you are describing in the last sentence. When I run the marionette, I receive the following error message.
- 8 replies
- marionette
- hyperlink
(and 1 more)
Tagged with:
Understood, thank you very much for your effort and thoughts. Have a nice day.
- 8 replies
- marionette
- hyperlink
(and 1 more)
Tagged with:
thanks Pat for the quick reply. Unfortunately, that's what I feared. Do you think it works with a string node that contains the hyperlink as a string? Then I would pull the data from a list in the marionette.
- 8 replies
- marionette
- hyperlink
(and 1 more)
Tagged with:
Hi everyone, I am in the process of creating a kind of wiki from a worksheet in Vectorworks. Column 1 of the worksheet shows the topic. Column 2 of the worksheet contains a suitable hyperlink. The aim is to select a topic via a pop-up query and then get a pop-up that contains a clickable hyperlink. So far I have only managed to display the hyperlink as text. However, this is not clickable. Does anyone have an idea if it is possible to get a working hyperlink in the pop-up? Thanks in advance. Test Marionette Wiki.vwx
- 8 replies
- marionette
- hyperlink
(and 1 more)
Tagged with:
Hi Scott & Spettitt, thank you bith for your answer. i hope we see this feature for data vis combined in graphic legends very very soon. greets.
Hi Scott, thank you very much for this Hint. just to be sure. The Datavisualization is only working for the Equipment List but not for Graphic legends, right? tia tom
Script to create selection scripts of used Light Instruments
Tom M. replied to Tom M.'s topic in Vectorscript
Wow amazing! I really appreciate your help Jesse and Pat! I knew about the Select Similiar tool, but didn't think about saving defaults. Thank you all for the push in the right direction.- 8 replies
- 1
- vectorscript
- light instrument
(and 1 more)
Tagged with:
So happy with your help. The script brings me directly to another idea. Do you think it is also possible to create a script that selects the remaining fixtures of the same type used in the drawing based on an activated fixture? So if I have a Fixture selected I run a Shortcut to select the rest of the same Fixtures? Bonus. Possibly even for similar plugin objects, like speakers etc.? Tia Tom- 8 replies
- 1
- vectorscript
- light instrument
(and 1 more)
Tagged with:
Hi Jesse, wow thank you very much for sharing this script. It's close to what I was looking for. Great timesaver for me. Thank you!- 8 replies
- 1
- vectorscript
- light instrument
(and 1 more)
Tagged with:
Hi there, Unfortunately, I have little to no experience with Vectorscript. So far I have created scripts via Marionette or menu commands. I often want to select Light Instruments by its "Fixture Name". Therefore I used Vectorscripts to select them by their individual name. Script looks like this: DSelectAll; SelectObj(INSYMBOL & INVIEWPORT & ((PON='Lighting Device') & ('Lighting Device'.'Inst Type'='ALEDA B-EYE K20'))); I have all these scripts in the Scriptpallette: 'Sel Scheinwerfer' The annoying thing is that so far I have to modify each script individually as soon as I add new light instruments to the drawing which I have not used before. It would be great if its possible to use a script that creates the individual scripts for the light instruments currently imported in the drawing. Is this possible? Maybe someone can point me in the right direction. Thanks for your help in advance Tom
- 8 replies
- vectorscript
- light instrument
(and 1 more)
Tagged with:
