Stephen M.
Content Count
20 -
Community Reputation
0 NeutralAbout Stephen M.
Rank
Greenhorn
Personal Information
Occupation
Live event designer/planner, Residential Architectural Modeller.
Homepage
LTCAD.CA
Hobbies
Niagara Wine Region
Location
Canada
Recent Profile Visitors
519 profile views
I'm using one of the 3D photorealistic image props from the Entourage People resource and when I render the file in perspective a white box forms at the base of the image. Does anyone know if it's possible to eliminate the white box?
must be something else I'm missing. I've changed the drape to different objects and the lights still show through. Is there some other settings to the environment that has to be switched?
I think I tried that. could you look at the file and let me know what I missed? drape opaque.vwx
I am uplighting drapery and the light is showing through the drapery. Could someone remind me what I have to set to make the light "bounce" off the drapery and not go through it?
Thanks, my problem usually is when I'm building a model in the Layer and I just need a measurement to check something, not actually place a dimension in a Sheet. So if I'm building in a top/plan and then wish to check a measurement changing to a side view.
When I switch from top/plan to either a front or side views is there a way to set the parameters so it picks the points in a 2D plane. When I try to grab points they're not always in the same plane. Not sure if I should be re-setting the plane views. -could be I'm not familiar enough with the program after a year or so of using it. thanks if advance for any advice.
Thanks Pat, I did the import and the 14mb file blew up into a 187mb file! It is a bit heavier than I had hoped but it worked.
And just as I asked this question I went back to my Spotlight and see there is an import for the format, so I'm giving it a try.
Has anyone opened a .step file? It's a format I got from a truss supplier and I'm trying to import a model of an exhibit booth.
is there a way to add the current date into a drawing?
Stephen M. replied to Stephen M.'s topic in General Discussion
Thanks guys, I'll try the variations. I appreciate the advice. -
Thanks for the info Kevin. That must be a hidden command because I don't see it on a Keyboard Shortcuts list.
Does anyone know of a way to stop a render which is in progress without quitting the program? -using Spotlight 2018 on a Mac.
uplighting soft goods and drapery -lights show through
Stephen M. replied to Stephen M.'s topic in Rendering
All good tips guys, thanks. Steve M. -
A colleague of mine works in 3DS Max and sometimes he builds an object and makes it glow. Do we think we could do the same thing here? -build a fake instrument from an object and somehow shutter it to give the effect of a wide cyc light?
