jcogdell
Vectorworks, Inc Employee-
959 -
Everything posted by jcogdell
Offset Distance Between Fixtures and Truss in Right View
jcogdell replied to Cristiano Alves's topic in Entertainment
@Cristiano Alves I just tested your file and using the align and distribute tool is working as I would expect, snapping the fixtures to the truss. The workflow I used was rotate into a 3D view where I could easily select the fixtures for the first truss line group select the fixtures activate the align and distribute tool from the lighting toolset using align mode I then zoomed into the end of the hanging position and snapped the start of my line to the end of the truss chord that the fixtures need to be aligned with, zoomed backout and then zoomed in on the other end of the chord and snapped the end of the line to that end of the truss chord. -
What are you class and layer options set to?
I think you may have used the Align and Distribute menu command, which will only align object in the x/y plane. The Align and Distribute tool from the Lighting tool set will align and distribute object like lighting devices to a user drawn line in 3D, If this is not working can you post the file so I can take a look to see if there's abug? -
Hi Carl It sounds like you added the electrical components before you created a symbol. You have to create the symbol and then add the electrical components to it by editing either the 2D or 3D component, otherwise it will not register that it is a distributor object. The video series that @Scott C. Parker linked goes through the process in detail and should get you up to speed. If you have any questions or trouble reach out and I'll do my best to help
Do you mean alinging the fixtures rotation with the angle truss? Then yes you would have to manually set the rotation value based on the hanging angle of the truss. The quickest way to do this is to group select all the fixtures and enter the truss lines hanging angle into the Y rotation parameter of the fixtures. this should align them all in one go -
This won't work with autoconnect or Braceworks. The issue is that the 60° bar is set up as a standard 2 way corner, not as a 3 way T-corner. You could in theory create a new symbol defintion to do this but I'm not sure whetehr it would deliver valid braceworks results.
Hi Peter It sounds like your license details haven't updated correctly. You best bet is to contact Design Express, they will be able to sort the issue out
Another option is the create hoist report command from the Rigging/Braceworks section of the Spotlight menu This is a specialised command that will generate a list like above with a number of sort options, including hoist id's, y- position, straight path and the specialised antways. Antways calculates the most efficient path for the onsite riggers to use when hanging the hoists and will order list accordingly.
Other than the document settings the only restriction should be the hardware you are running Vectorworks on, but I would expect this to cause performance issues and not restrict the number of lights being actively rendered.
Export MVR - Export as 3DS does not export geometry
jcogdell replied to ReMatsu's topic in Entertainment
We are currently testing the fix for the document units not converting correctly. It should be in the next update as long as no issues are found with the fix -
Do you have automatic classing enabled for trusses? You can check this in the Spotlight document settings go to File > Document Setting >Spotlight preferences and look in the loads and rigging section.
- 1 reply
- 1
Have you tried using the Align and Distribute tool from the lighting tool set? It should maintain the spacing correctly using Align mode, the only thing to watch is you may need to change your point of view slightly to be able to draw the reference line along the correct truss chord. -
you can DM me the file if that works, it will be kept confidential and only used to check the issue
Are you using a template file, lighting device auto classing or possibly working with someone using a different language localisation? Any of these could affect the classing. Otherwise without seeing the file I can't really say what is happening, if you can post the file I can have a look.
Seeking Solution for Fixture Selection Issue in Vectorworks
Another option is to set up the automatic classing for Lights so each fixture type is assigned to its own class, you can then use the select similar tool set to class to select all the fixtures of the same type. -
PROJECT SHARING graphic refresh problem
jcogdell replied to JoeDrafter's question in Troubleshooting
It may be a graphics caching related issue. Try turning off the VGM cache in the document settings and/or the vector caching in the Vectorworks preferences, then change view and re-enable. This force Vectorowkrs to recreate the cache and may fix the issue. -
@Ross Harris Thanks for clearly explaining, Iwas having trouble working out how to explain the differences since I'm not a hardware expert
- 6 replies
- 2
- vectorworks
- 2024
(and 3 more)
Tagged with:
I'm not 100% sure, I'll see if I can find out and let you know
Ahh this is standard behavior, The issue is that if you drag and drop a symbol from the resource manager into your design you are only inserting it as a dumb symbol, instead double click on the symbol in the resource manager and it will activate the relavent insertion tool. I got a demo of the L-Acoustics plugin a couple of weeks back and its looking really good. We're actively working with several other audio companies as well to add more options for working with audio planning software.
Rendering changes when I add a lighting instrument??
jcogdell replied to phld's topic in Entertainment
Instead of turning the class off turn off the lights themselves, unless you need them for rendering purposes this is the best option with Spotlight lighting devices. You can either do this in the lighting devices properties or using the right click context menu (make sure to group select the lights first). -
Even after your upgrade, you are well below the minimum basic systems for running 2024. I'm sorry to say but your system is simply to old to be upgraded to the recommended minimum system specs.
- 6 replies
- vectorworks
- 2024
(and 3 more)
Tagged with:
Is this a seating section or simple symbols for the tabels? If its a seating section then you will need to change the table symbol choice in the seating section settings, you can access them from the OIP
@Peter Telleman Can you post the file so I can take a look Also there is good news for anyone using L-Acoustics Sound Vision for audio calculations, they announced thheir Spotlight plug in at ISE last week. This will enable you to send your Spotlight file directly to Sound Vision, since this is the first version it goes from Spotlight to Sound Vision but they are planning to make it possible to send data back to Spotlight in the future.
Venue Drawing Standards (from a rigger's perspective)
jcogdell replied to Wood's topic in Entertainment
@Wood I know there's not anything from the Ent side but there may well be something by the architect team on the university. I'll add it to the ent teams list of potential webinar and coffe break subjects Otherwise there have been a number of fairly detailed discussions here on the forums about the best practices for DWG importing. -
There are a couple of ways to accomplish this use the load tool to add point loads to the supporting truss or pipe structure where the screen will be suspended from. add an invisible pipe or truss that the screen is hung from (class it seperately to control visibility), and is in turn connected to the actual supporting truss or structure above with drops or hoists, effectively this is suimulating the structural part of the screen (or in the case of a LED wall the flying bars) where the rigging would be attached. If you are hregularly hanging LED walls and have the symbols for the flying bars you can go a step further and convert them into truss objects to roughly approimate the behaviour of the bars for Braceworks and to be able to reuse them in the future.
