Tim Norman-Prahm
    38
Reputation
6 Neutral
Personal Information
  • Occupation
    Architect
  • Homepage
    www.normanprahm.com
  • Location
    United Kingdom
Recent Profile Visitors
  1. Thanks @zeno for reporting your test, really interesting. I also have a low brow question, do you notice any added performance in say more ‘normal’ files you work with (ie no point cloud) with the m1 max over the m1 while you navigate and draw? Or due to single core being the same is it fairly neutral? Tim
  2. Hi @zeno this will be really interesting, looking forward to hearing how it goes
  3. Hi @zoomer , I am really intrigued by this comment, will vwx be utilising more gpu cores in the future? I am trying to understand if having a 32 gpu core is worth the investment for the coming years of vwx versions.
  4. I have noticed a small issue with the dialog box when saving a pdf from the print dial box. I can only see 3 rows and cannot expand the panel. I noticed this before on 2019/Mojave but seemed to go away with 2020/Catalina. Its not the end of the world but feels funny looking at my files through a letter box. MBP 2016 TB - 2.7 GHz Quad-Core Intel Core i7 - 16GB RAM UPDATE : I have just noticed the same issue in Numbers (Mac app). So perhaps this is a OS issue. Tim
  5. Hi - I have gone for it with 2021 and Big Sur - all up to date with latest VW service pack. From my experience everything works okay and I felt panning and zooming was in fact faster/smoother than Catalina. I am using a Mac Book Pro late 2016, 2.7ghz, 16GB RAM My files though may be a bit light and so not pushing the limits with full on BIM. It is mostly CAD with some 3d modelling, wall and roof components. 3D more of a sketch.
  6. @JuanP I am following both this and the main Big Sur and I wanted to ask if there was a general update or the upgrade following the release on the 12th of Nov. It was said that some feedback would be given in a few days after its release and I was wondering how that was going? I am using - VW2021 SP2 Mac Book Pro Late 2016 2.7 Quad core i7 Radeon Pro 455 2GB 16GB RAM
  7. I just found this thread! it was perfect solution to my problem! Thank you all above Tim
  8. Hi Matt I have just downloaded the new Service Pack and I assume this might be something you look at in the next one? Tim
  9. Interesting idea How do you approach it - is it all free form solid elements? Does this integrate okay in your 2D drawings too. woudl be interested to also see an example. T
  10. As I noted on the other thread - I agree it is 100% related to the stair connection. If you adjust it to not interact at all with the slab it seems to go away. but not always! Any thoughts from VW teamed community welcome
  11. Ah yes I have the same issue - Thank you for noticing mine as well. It is 100% to do with the stair connection. A further shout out to Vectorworks for any ideas. T
  12. Dear All Does anyone know how to stop this happening! I am a fledgling VW BIM learner I have noticed that top and bottom of the stair has a weird clip / cut fill that comes through all layers. It does not show in the camera mode - just in clip cube - so If I want to export a view it shows through. Any solutions approaches appreciated! T
  13. Hi Boh thank you for your help - it seems to have settled. I made sure all objects were by class just in case. T
  14. Hi Bob - This is a good point - I will double check. I normally do make sure I am using that and keeps things to class. I will let you know. Tim
