dshuhy
    3
Reputation
0 Neutral
Personal Information
  • Location
    United States
  1. I've been using Vectorworks since 2005 and this has been bothering me. I have not found a way to snap to a point that is not on the layer plane or the working plane, and I'm hoping that this feature has been added at some point, and I'm just missing it. If I were to want to draw an object aligned with the top, back right corner of a cube (as shown in the picture) and just began to create an object it would actually line up at the bottom of the cube which is on the layer plane. To get it where I wanted it, I would have to either: Switch to working planes, create the working plane and create my object, or Create my object, then drag it into position Both of these requires several, unnecessary steps and drastically slows down the work flow. Any suggestions?
  2. I am fighting with VW2017 Designer, I cannot change the paper size that Publish uses. I have changed the paper size in my sheet layers, I have changed the paper size in Page Setup, but using VW's PDF printer still gives me a diferent size sheet. This error seems to be somewhere in my template that I'm using, e.g. drawings started using another template are fine, so I'd like to find a way to change it. See attached file. Any suggestions? Thanks and happy holidays. TEST.vwx
