46 -
Everything posted by Projx_CA
Thank you for the workaround, Sam. I was a customer of yours before VW incorporated the hoist tools into the standard distro, pre-braceworks. Seems like they've created a market for you again! Guess I'll submit a feature request to restore the lost tools. Total insanity over there!
How does one "Select All Hoists" in VW2021? I've re-added the legacy tool which was removed, but it does not select any hoists. Where can I read on the reasoning behind these changes?
Feature request: Braceworks Video Screen
Projx_CA replied to Projx_CA's question in Wishlist - Feature and Content Requests
Updated info in the post above.... -
So Braceworks calculates the screen and projector correctly, but does not like the slider supports having no Allowable Force on the drop to the screen. Later in the report, the sliders are seen as a Suspension Point capable of supporting 0 lbf. Any way to enable a load on the sliders, or hide them in the report? -
Projx_CA posted a question in Wishlist - Feature and Content Requests
We often hang video screens on VER-lock cable drops from trusses. My feature request is to have Braceworks incorporate the "'Screen Support>Sliders" function, and see the screen as a load a few feet below the truss. (I generally move the screen to the same elevation as the truss to force a calculation). I can also insert point loads at 50% of the screen weight, on each end then turn off screen calculation, but that adds a few steps.... -
Makes sense. Thanks for testing. Hope to see the 'ground support' feature working eventually!
Is there a workaround to get braceworks to calculate a vertical truss box? I have no trouble building the box, connecting all objects and rotating to vertical. Braceworks believes there are FEM forces on a strictly vertical load. This is using Christie Lites B-Type. Screen Frame Test.vwx
I converted my CS800 hoist distro symbol to a "Accessory", where you can give it an item weight. Spotlight>Object Conversion>>Convert to Accessory Alternatively, you can create a load with the "Insert Load" tool. Once the load is created, in the OIP, click on Show Symbol and select your existing symbol. You can change the weight value and item description at the bottom (Load Name).
Braceworks Cross Section info From Manufacturers
Projx_CA replied to Wesley Burrows's topic in Braceworks
Rob, Does the cross section file need to be updated separately, or is it part of the service pack? The Christie truss still registers as rigid, even after the SP3 update. Thanks! -
Are the Christie Lites truss symbols supposed to have Cross Section data? They appear to be set as RIGID -
Braceworks - Drape vs Border (or soft goods teaser)
Projx_CA replied to Projx_CA's topic in Braceworks
Nope, there's no quicker way. This seems to be the 'official' workaround for borders, teasers or any soft good that doesn't reach the ground.. -
Is there a correct way to attach a soft goods Border or Teaser to a truss in Braceworks? I am able to attach a full length drape (and calculate successfully) if the height of the drape is the same as the truss (i.e. 30' trim, 30' drape). When I shorten the drape to be a header (30' trim, 20'drape), THE LOAD IS NOT CONNECTED If I change the drape to a border, THE LOAD IS NOT CONNECTED If I draw a new border, THE LOAD IS NOT CONNECTED Is there a workaround other than extending the item to the ground, calculating, then shortening the item again?
Just downloaded the Christie Lites package from Select Service. There is a bug in the truss weights. The resource manager has the correct Imperial and Metric weights listed in the 'Truss Record', but the 'BrxTrussItemRecord' imports the Metric weight into the drawing (even though the Units of the document Mass is set to Pounds). Screenshot attached - the Total Weight in pounds should be 96lbs, not 44. So beware if you are doing weight calculations!
Interesting. I have hoist weight in some existing drawings, but not if i create a new drawing. 2 screenshots attached. I think you found a bug.
Thanks Moritz. I tried that too before posting...here is the result of the rigid connection. I still get the support error, plus the elements occupying the same space.
klinzey, Is there a correct way to cantilever a pipe on top of truss without the calculation failing? I want to out rig a pipe with a load at the end (in this case a fixture). I thought I stacked the pipe on top of the truss correctly....
Needed to vent. I want to love Braceworks - I really do, but it hurts me to do so. Screenshot attached. This drawing would take hours to clean and calculate. Back to the manual method.
I'm in the same boat Darrell! I spend more time trying to solve errors than it would take me to manually calculate the weights. I definitely feel like a beta tester too. I haven't solved the cable pick question either. For that scenario I manually input a weight in the a USER field - but it will not calculate or be part of the report. I don't know if you can connect a load directly to a hoist with out an intermediary piece of hardware like truss or a pipe.
You need to create a new symbol for the 18' type A curve. Copy the existing symbol in the resource manager and rename the new copy to "18' type a curve - V" Import the new symbol into your drawing double click the new symbol (With Class visibility set to Show/Snap/Modify) and select 'Edit" Edit 2D component Select and delete all the 2D information - Exit Symbol (top right) You now have a 3d only version of that symbol that can be rotated freely.
Here's a link to a working set of CL truss symbols with Braceworks. NB, this is not the official release - just one that I've put together. The cross section information is still RIGID. https://www.dropbox.com/s/y9hs50zhbk1ywlj/Christie Lite Truss v1.8.vwx?dl=0
