mharpur
27 -
Reputation
4 NeutralPersonal Information
Location
United Kingdom
Recent Profile Visitors
@Jesse Cogswell- `that's excellent thank you for the info. That was indeed the issue. Much appreciated
Wishlist - Data Vis & Schematic Views
mharpur posted a question in Wishlist - Feature and Content Requests
It would be great that when you apply data visualisation it is also applied within the schematic view. Eg. I have a a Visualisation for unused lights, (It highlights them in RED.) This does not apply within the Schematic view however. In addition to this - It would be great to have schematic of positions take have the same level of Layer control as Hanging positions. Eg. I have a Lighting Ladder (a vertical Position in 3D), I create a schematic of this position and insert my Fixtures accordingly. Some of these fixtures are Unused for a particular show, I would like to be able to move the fixtures from the schematic to this Layer and turn it off. At the minute if I change the Layer of one fixture it turns off the entire position. Thanks M- 1 reply
- 2
Hi All I have drawn a new position and and trying to give the Name or 'CIRCLE'. However, every time that I input this name into the relevant column it is coming uo as 'CIRCLE-2'. This is no doubt because I have recreated the position but I cannot seem to locate where this original position is. Any info to assist would be very much appreciated thanks in advance M
Hi All I am having an issue where I have a number of Schematic views of positions on a Layer. I have a number of Lights on these schematics which form part of a Basic Installed rig. I am trying to move a couple of the lights on to a "Unused" Layer but every time I do this it moves the Schematic position and the Fixtures attached to it to the Unused layer. Is this expected Behaviour? Is there a workaround so that I can choose the visibility that I require. Thanks in advance VWX 2021 SP4 Mac OS 11.4
Here is another file that the issue is occurring on thanks] M D-LX-Dorfman Basic v2021.vwx
Hi Juan Thank you for your reply. I have sent file via Wetransfer for you. thanks M Lyttleton Basic v2021.vwx
I'm currently using 2021 SP4 and am having an issue where when I export to a previous version of VWX it crashes the programme. This also was happening on SP3. I have tried exporting to 2017, 2018 and 2019 but the same issue occurs. This happens no matter what file I am using. Any assistance would be very much appreciated thanks M
Hi @klinzey - a full reboot of the system appeared to have solved the issue. I did t get a chance to log the bug report but I will do on Monday when I get back to the office on Monday.
Hi All I've just updated to SP4 and data exchange with Lightwright is now not working. I am getting an error of " You need to do a 'Complete export on exit'. Even when I do a complete export it keeps popping up with the same error message. Any help very much appreciated. I have also posted on the LW forum thanks M
Hi All is there a way to auto assign video object for instance in the same way that I can auto assign truss objects (With a prefix set within the document settings options) I have a template file based off of the VWX UK Template. I have the truss object prefix set up and would like to do similar for video objects such as projectors and cameras. Mainly to keep my class structure tidy so I don't have to spend time reassigning. Just wondering if this is possible. thanks M
@Rob Books Thanks for the update. Will br great to get them! thanks M
Hi All, Im sure this is a long shot but has anyone got symbols for the new Series 3 Source 4 Lustr as of yet? I have submitted a fixture request. thanks M
It would depend on your budget however the new M1 MacBooks run v2021 pretty well for 2d drawings (I haven't done much 3d yet on the M1s). Most of the MacBook Pros from the last couple of years are good. Check the current Tech specs tho here: - https://www.vectorworks.net/sysreq
Hi All I am getting this pop up every time I try to insert a new fixture in to my drawing. If I renumber it I can carry on with what I am doing. Any idea why this is occurring. It is only happening on this particular drawing and I can't seem to locate the issue.. thanks in advance M
