83 -
Everything posted by HebHeb
when operating with nurbs curves (my go to when creating solids inside marionette) some things to mind: - for closed curves take the first point and use it at last point also (otherwise they are not "closed") - use the "loft surface" node to generate solids (get familiar with the settings (rule, solid, close, ...) - chek the order of the curves and their point direction (with the data flow nodes everything is possible)
In DomC's Node Collection is something that might be interesting? Actually there a a few Nodes/ small example Networks that might help u with your idea! DomC Nodes - Marionette - Nodes - Vectorworks Community Board
- 2 replies
- marionette command
- duplicate
(and 1 more)
Tagged with:
Thanks for reaching out! @Letti R was so kind to help me out with a alternative Python script ❤️ this did exactly what i wanted. @Antonio Landsberger But thanks for the version 2 of this node!!! I am 100% sure I will use it later in another script.
i guess this is something basic, but never did this with marionette: i have a list of points that looks something like this (points for each poly) i want to triangulate each poly separately and not the whole polys together... so i need a flattened list for each 'list' and not the whole list flattened. can anyone help me? thanks!
Notches at regular intervals in a curved ceiling
HebHeb replied to Tobias Heinzmann's topic in Marionette
I think there not enough Info to help you. But one Node comes to my Mind that might be wort lookin at: "Get Point On Poly" so you can place and rotate Objects along Polyline shapes. -
1. not very complex, some nested math... squences, ranges, series,... recalculating z-height of polys etc... graphically: no 2. of course only the dedicated gpu active As said: just curious if maybe more "generel problem" acoss other hardware configurations. Might have a chance to test on a system with dedicated gpu only next week...
Hey there, i have some Networks/ and or Marionette Objects that crash my Windows 2024 Update 3 Installation of Vectorworks, on MacOS everything just works fine and as expected. I have already sent a test file to my local Distributor and they said that the issue was now reported to Vectorworks Inc. I also experience much faster response of Marionette on MacOS than on Windows... even my "slow" M1 with 16GB RAM (13" Pro late2020) is oddly faster than my i9-12900H, 64G RAM, RTX 3060 (Laptop GPU) Windows Machine. Wouldn’t expect such huge differences with that hardware. So out of curiosity: Anyone else in this community having similar trouble?
Question on DomC's "Extrude along Path with Ref point" Network
HebHeb replied to HebHeb's topic in Marionette
@DomC @Pat Stanford this works perfect! 😍 in this context: is there any acess to the "fixed direction of the profile"? i would literally die for a english Version (or at least the possibility to switch from german to english) Sometimes it is really hard to guess the english terms and get proper search results... -
Thank u! I will test it tomorrow and will report my results here 🙂 -
ty Pat for reaching out! ...and thats exactly the problem: no matter how the profile is moved, after an operation the movement is reset 🙂 if not operated on the result its working, thats exactly what DomC's solution is doing. -
had some time to work on this again... Whenever I operate on the resulting "VW-Handletype: 86 Plug-in object" (in this case convert to 3d polys > mesh) the movement of the profile is lost (happens with any operation (also bool) unfortnetly there is no info for 3D Path Plug-in Object (86) on the developer page that might help me to sort it out myself... @DomCHave you any idea how I cloud avoid this behavior? Extrude along Path with Ref point (3D Path Plug-in Object - Handle Type 86).vwx -
I can't remember excatly; but could it be possible that this only happes with active plan rotation?
FYI. Found a working soloution: In some cases (i.e. when using a rectangle as path) i had to ungroup twice to get the 3D poly handle. @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Send to DTM Surface' ) this.SetDescription( 'sends object to DTM Surface' ) #Input Ports hPath = Marionette.PortIn( vs.Handle(0), 'hPath' ) hPath.SetDescription( 'the input path' ) hLayer = Marionette.PortIn( 0 ) hLayer.SetDescription( 'the layer containing the DTM' ) iTINType = Marionette.PortIn( 0 ) iTINType.SetDescription( 'A number identifying the Site Model surface (0 = existing or 1 = proposed)' ) #OIP Controls #Output Ports hPathOUT = Marionette.PortOut('hPathOUT') hPathOUT.SetDescription( "the resultung elevated path" ) #BEHAVIOR def RunNode(self): #inputs hPath = self.Params.hPath.value hLayer = self.Params.hLayer.value hDTMObject = vs.DTM6_GetDTMObject(hLayer) iTINType = self.Params.iTINType.value #script vs.DTM6_SendToSurface(hDTMObject, hPath, iTINType) vs.Locus(0, 0) # Create a dummy object dummy = vs.LNewObj() hPathOUT = vs.PrevObj(dummy) vs.DelObject(dummy) # Delete the dummy object #outputs self.Params.hPathOUT.value = hPathOUT
Thanks for your reply. Now the Python example makes sense ;D _, _sPIOName, _hPIO, _hPIORecord, _hWall = vs.GetCustomObjectInfo() # Get info from current PIO instance _hPath = vs.GetCustomObjectPath(_hPIO) _hDTM = vs.DTM6_GetDTMObject(vs.GetLayer(_hPIO), False) # Get Site Model on the PIO's layer _hPoly2D = vs.HDuplicate(_hPath, 0, 0) _b = vs.DTM6_SendToSurface(_hDTM, _hPoly2D, 0) vs.Locus(0, 0) # Create a dummy object _h = vs.LNewObj() _hPoly3D = vs.PrevObj(_h) vs.DelObject(_h) # Delete the dummy object I kind of failed like shown above, but with waldo in my mind i'll give it another try 😉 But anyhow, I hope someone can sort it out
Hello, I somehow can't figure out how i get the "resulting" object when using "VS:DTM6 SendToSurface" there are some comments on developer.vectorworks.net: vs.LNewObj() doen't seem to give the handle to the desired result... i am really no expert in creating my own nodes, so please be patiend ;D ...see attched file maybe @Marissa Farrell can sort this out. the "send to surface" operation seems to work, i just can't get the output handle- @Marionette.NodeDefinition class Params(metaclass = Marionette.OrderedClass): #APPEARANCE #Name this = Marionette.Node( 'Send to DTM Surface' ) this.SetDescription( 'sends object to DTM Surface' ) #Input Ports hPath = Marionette.PortIn( vs.Handle(0), 'hPath' ) hPath.SetDescription( 'the input path' ) hLayer = Marionette.PortIn( 0 ) hLayer.SetDescription( 'the layer containing the DTM' ) iTINType = Marionette.PortIn( 0 ) iTINType.SetDescription( 'A number identifying the Site Model surface (0 = existing or 1 = proposed)' ) #OIP Controls #Output Ports hPathOUT = Marionette.PortOut('hPathOUT') hPathOUT.SetDescription( "the resultung elevated path" ) #BEHAVIOR def RunNode(self): #inputs hPath = self.Params.hPath.value hLayer = self.Params.hLayer.value hDTMObject = vs.DTM6_GetDTMObject(hLayer) iTINType = self.Params.iTINType.value #script vs.DTM6_SendToSurface(hDTMObject, hPath, iTINType) ### hPathOUT = ### #outputs ### self.Params.hPathOUT.value = hPathOUT ### HebHeb_send to DTM Surface.vwx
again I ran into troubles lately. Especially with projectsharing… What I also noticed: when I import a Marionette Object (style) out of the resource Manager some nodes loose their connection… (but not always… thats the funny part…) What always works: copy paste from file to file… I save every network as style, so I can always replace the „inside“ with a working „backup“. the only workaround that works for me at the moment. Also I try to place every Marionette style before setting up the projectsharing file. For now I stopped using projectsharing in projects where i relay heavily on marionette objects… (no fun solution when busy teamworks is needed)
Not always. Texture was applied for objects that wehre converted from 2D to 3D out of the control geometry. (so they had texture info from the beginning via class), For 3D geometry that was created inside the MO i had to manually assign texture (even after the class should have automatic texture assignment) My workaround was: I created a „dummy“ texture that got color from the attribute palette and assigned this specific texture for that geomety with missing texture to get at least the class solid color (and in my case transparency) via class. Was also missing a native node as OP.
Hello there, any chance of seeing native Material Nodes in near future? Materials took a huge role in our workflow, a shame that our marionette scrips can't work with them 😞 Cheers.
Hello there, it would be nice to have a native node that operates with the DTM. Input: Site Model (via Location on Layer - handle Input via obj by criteria ?) State of the site model (existing/proposed) x/y-Value Output: z-Value btw: I am aware of the possibility right now 😉 https://developer.vectorworks.net/index.php/VS:DTM6_GetZatXY I don't come from a scripting background, and never feel comfortable (or future proof for version updates) when I create my own nodes... Cheers!
Thank u! The solution suggested by @Letti R works!
hey there, can someone explain how I could use the Strip Node whilst using repeating "sub-parts" of the"substring example: string Input is: TestStringStripFriend-From Test ("From" should stay) Strip Operator is: TestStringStripFriend- result is: om Test ("From" should stay) result should be: From Test ("From" should stay) Anyone? Cheers!
Marionette - get values/strings or formulas from a existing worksheet
@Marissa Farrell @DomC Maybe one of you can sort this out? How do I get the correct handle to work with an existing worksheet? (best case: without placing the ws inside the drawing/ layer - just inside resource manager) Cheers. -
Hello, am I missing something? I kind of don't get values/strings or formulas from a existing worksheet... I tried different rows and columns but I don't get the expected values. I can't figure out how I get the right "Handle to the Worksheet = hWorksheet I can search with obj by crit (=worksheet) and get i.e. type #56 - is this the correct one? Can I access a Worksheet inside the Resource-Manager? (by name?) Cheers.
Thank you for your explanation! I guess I didn't notice because I have things going on afterwards that seem to reset anyway (didn't test outside my network) Okay my question on the solid boolean operation was confusing: After the generated path extrude I think I have to convert the object to mesh or simple 3D to do a solid boolean, if I do a solid boolean with the path extrudes they do that without the movement to the ref point. I don't find any node to convert to mesh or similar... Is there any other workaround/ possibility?
