Benny Franke
14 -
Reputation
0 NeutralPersonal Information
Location
Berlin Germany
Recent Profile Visitors
@Alan Woodwellsure. This is an example i am working on where i isolated this problem. I want to change the rectangles by manipulating there database values in the Worksheet. 05._EigenerWorksheetTest.vwx
@Alan Woodwell Thanks, I already have those but every node in there that gives you a value or string from subrow needs an subrow int as input which I can't get.... I want the network to show me the value of a selected subrow. The whole idea is to update objects by changing parameters in the worksheet. If anyone has a better idea or a different way that works please tell me. I am stuck here since 2 weeks. Thanks for the files Alan.
@Marissa Farrellwhere can i find those GetSubrow Count and Get Subrow Value nodes? I would like to have them for my Marionette as well. Thank you very much
marionette Object: how can i access the OIP parameter in a table?
Benny Franke replied to Benny Franke's topic in Marionette
hey @Marissa Farrell, of course since this all works i want to know how to make it bedirectional. I tried with the get record node combined with the equal and if node but it didn't really work. Can you point me in the right direction? Since i am in this forum Marionette is way more fun. Thanks for your kindness.- 7 replies
- marionette
- object
(and 2 more)
Tagged with:
Hi @Marissa Farrell, as always you made it happen. Thank you very much now it works and I can carry on. Thank you for the incredibly fast, correct and professional to a noob question. cheers Benny- 7 replies
- marionette
- object
(and 2 more)
Tagged with:
Hi there, I tried the Records nodes which did work until I created a Wrapper. That task created a group out of my object with the record and so I can't see them anymore when I select the Object Node. I need to attach the infos to the record after the automatic group command or get rid of the automatic group command all together. I will take the next 2 hours and figure out the PIO handle. Thank you very much so far- 7 replies
- marionette
- object
(and 2 more)
Tagged with:
Hi there, I am working on a project where i created a marionette object node (thanks to this forum it works so far) with a couple of adjustable parameters in the OIP. Is there a way to get access to those parameters to create a worksheet that lists all the object instances and there parameter settings? Before i knew marionette i used databases (records) to store all that information but within the object node i can't do it since it groups everything on the last step. I hope someone understands what i mean and ideally has an idea to make it work. thank you very much in advance Benny
- 7 replies
- marionette
- object
(and 2 more)
Tagged with:
Create Custom Nodes that can be seen in Marionette
Hi @Stephan Moenninghoff thank you very much for your answer. It took me 4 days to realize i won't be able to make it happen. Then i wrote this post and the easy answer is to just delete the whole grey text.... Come on. Anyway I am happy as can be. Thank you very much. Case closed for now.- 4 replies
- marionette
- nodes
(and 1 more)
Tagged with:
Thank you @Marissa Farrell for this rapid reply. I think i am still way behind your instructions. I have the german spotlight version 2018 and can't find the Convert to Plug in Object command but i did find a german help file that says to convert the node into a intelligent Object. Is that the same thing? Anyway i haven't even made it to change an existing node under a new name (it asks me to change the command to refile which i did but it still doesn't work). can you help me on this step too? tank you very much. I appreciate "the fastest Forum on the planet" very much.- 4 replies
- marionette
- nodes
(and 1 more)
Tagged with:
Hi there, is it possible to create custom nodes, or change existing nodes that then can be seen in the marionette node library? I couldn't find any instructions to that so far. If there are maybe someone can point me in the right direction. the only thing i managed so far was to change existing nodes which then got changed globally for ever. I am sorry for beeing a noob. thanks for reading
- 4 replies
- marionette
- nodes
(and 1 more)
Tagged with:
Marionette Node Object Text Label only visible in 2D view
Hi @sbarrett , @Pat Stanford thank you very much. that did work. now i have to arrange those labels slightly on top of the dice because they shimmer in openGL view. Is there a snap to surface node or something like this? sorry for all the questions but i can't really find documentation for all the nodes there are. I will definetly try the plane object thing later. Thanks for all the help.- 5 replies
- marionette
- node object
(and 1 more)
Tagged with:
Here is the part i was talking about. If you run it it does work. if you wrap it it still works. if you change to object node it does not. thanks VW_2018_Marionette_Test.vwx- 5 replies
- marionette
- node object
(and 1 more)
Tagged with:
Hello, this is my first post so please tell me if i did something wrong. My problem ist as followed: i create an rectange extrude and put a textlabel on all the 6 sides of the dice. All this is done via Marionette nodes. Once i create a wrapper it still works. Once i create a Marionette Object I can't see the text objects in the 3D view anymore. infos: the text objects are 6 groups i moved into place. anyone an idea? thanks for reading
- 5 replies
- marionette
- node object
(and 1 more)
Tagged with:
Info Palette not playing well with Marionette 2018
Benny Franke replied to Stephan Moenninghoff's topic in Marionette
Hi there, I have the same problem. I found out when ever you select a Node and press cmd+s it refreshes and works for one click. It is just a work around that forces you to save your project after every change in Marionette. I also have discovered that when you press undo that it jumps way back and I can't undo the undo. Has anyone the same issue? (only in Marionette)
