GRZEGORZ
Content Count
61 -
Community Reputation
16 GoodAbout GRZEGORZ
Rank
Apprentice
Personal Information
Location
Poland
Recent Profile Visitors
715 profile views
Linestyle of a wall - non-uniform outline of a connected wall
GRZEGORZ replied to GRZEGORZ's topic in Architecture
@Tom W. Yes, that is exactly what I am looking for! Thanks, I can not believe I missed that. -
@Jonathan Pickup Thanks, but it is rather work-around. In the Info Palette there is an options but it is greyed "Copy linestyle from..." and it is set to "Wall line". Is it possible to change this setting? -
Hello, I have a simple problem. I want to connect two walls with the same component (all attributes are connected with a class) to create one wall with various thickness. As you can see in the picture VW recognises ends correctly, but uses two different line styles - for the outer and inner face as defined in the class and for the endings much thinner. Any hints? WallConection.vwx
@Peter Neufeld, thank you so much for your time. I will do some more research and probably report this.
@Peter Neufeld, I have checked this one and still it is not the answer. No matter how you manage visibility settings, objects that should be partially covered by a solid are visible like they would be on top of solid, not inside it. See the picture in the attachment.
So I am using clip cube to create some kind of horizontal section (like a plane, but by using clip cube). The thing is that if I use clip cube to create plan (horizontal section) there is a bug. But if I use the same clip cube to create classic section (lets say vertical) it works perfectly. Clip cube bug.vwx
@Peter Neufeld, thank you for your time anyway 🙂 I really hope I will find where the problem is.
It is not a solution. By changing cut plane to infinite you just show the top view. If I add "slab" to my solid (add an extrusion on top to mimic slab top view) chair is still not visible. More accurate model in attachment. Clip cube bug.vwx
@Peter Neufeld, thanks for answer. But it is not the 3D view or OpenGL problem. My case is visible on the sheet layers (I have prepared one with explanations). You can see that there are differences between section viewports that go through solid with a hole and solid without a hole. I cannot see the chair in the section viewport on the sheet layer. Changing view from standard to orthogonal does not work. If I change rendering style to "Dashed Hidden Line" it works (chair is in place), but using option "Hidden lines" chair is gone some how but it should be visible.
v2020 Group node does not work as v2019 Group node
GRZEGORZ replied to GRZEGORZ's topic in Marionette
I think the same. This really looks like a bug or some kind of "work in progress" thing that was not finished. I will report it and maybe it will be changed in the next patch. It is a quite important node so it should be fixed as soon as possible. @AlHanson, @the frog - thank you so much for your time 🙂 -
Hello, I have a problem with Clip Cube tool. While using clip cube to create sections it creates some kind of white mask (white filling) when cutting through solids. Objects does not appear if they are below cutting line and at the same time cutting line does not go through a hole in the solid. Everything works fine if cutting line goes through any kind of hole in the solid. Hope someone can help mi with that or at least explains why it works like this. Example file in attachments. Clip cube bug.vwx
Hello, I tried to recreate my old script from 2019 and I have encountered strange thing. Group node in v2020 is different than Group node from v2019. In my example new node (v2020) does not work (gives 0 values), while v2019 node works fine. Does anyone has an idea why this node needed to be changed any why it does not work now? Both nodes in example file. Group test.vwx
Thanks, I need to check this, but anyway can't wait for VW2021 then 🙂
@Pat Stanford Values in OIP does show unit marks. Values without OIP does not.
@Pat Stanford, I used your script and got results (attached file). 'CWDObj'.'OpeningWidth' and 'CWDObj'.'OpeningHeight' are "REAL", so they should be numbers, but they do not change according to current document units. 'CWDObj'.'OIPOpeningWidth' and 'CWDObj'.'OIPOpeningHeight' are "Real - Coordinate Displacement". I have no idea what this kind of data type is, but it is working. Information is correct in terms of document units. Do you know the difference between these two data types? I can not use math operations on both results, so it looks like they are not numbers.
