B Cox
85 -
Everything posted by B Cox
Am I stupid? I'm also missing the Center Line Marker tool.
This is a dumb question but what happened to the revision marking tool? it disappeared from my toolsets.
ADJUST FLIPPED TEXT TOGGLE NOT AFFECTING ALL OBJECTS
B Cox replied to B Cox's question in Troubleshooting
Bumping these two bugs. -
I'm having an issue with VW2019 SP2. I usually work with 'adjust flipped text' turned off. However, text inside my annotates is still flipped/rotated etc. VW does not properly show me the condition of the text, so I have to blindly export my sheets to PDF to truly see the condition of my text. Does anyone else have this problem? I also noticed another stupid problem in VW2019 SP2--if you do duplicate along path on a closed path (like circle or ellipse) it doesnt use your original object as the initial position. You have to split the path or you end up with random but equal positioning of generated duplicates.
Bump this. another day, another bug.
I have crash logs as well, admins?
No clue? Its been happening for me in one file for days since upgrading to Mojave. I have to remind myself no chains. Why does this happen?
When i am annotating my drawing in VW 2018 5.1 and Mojave and using the constrained linear dimension tool i reguarly get beach ball crashes when i am finishing off the string. What gives? Does anyone else have this problem?
Theres the critical piece of info--yep Its showing 461124
Same Result
It tells me Vectorworks 2019 is available. And then that Vectorworks is Currently Up To Date. WHich is also what it said before I downloaded the linked file. Can you provide a good link to a 5.1 installer for OSX?
The link in the announcement for 5.1 takes you to the forum post with the link to the SP5.0 link. I downloaded and installed even though I have 5.0 already. VW is still showing 5.0. Is the link totally misdirected? Or does VW just not report the correct SP?
I Can confirm this issue is NOT CORRECTED in 2018 Sp5
Tech Bulletin: Fifth Service Pack for the Vectorworks 2018 Product Line Now Available
B Cox commented on PVA - Admin's article in Tech Bulletins
Jim, It looks like you forgot to add the link to the post? Also does this SP have compatibility with mojave now? -
Time for Nemetschek to stagger releases with Apple
B Cox replied to B Cox's question in Wishlist - Feature and Content Requests
Exactly. SP0 is like a useless release. Too buggy and incompatible with current environments to use. It might as well be called Beta 1 Beta 2 Beta 3 until Sp4 -
There is a way simpler way to calculate this--you can just use the Reshape tool on your belt and pulley to drag it in space (marquee select what you want to move) and move to various locations. then remeasure the 'belt'
Since Nemetscheck estimates 50-60% of its username is running OSX, it is really frustrating that consistently the new release of VW is broken by the concurrent updates to MacOSX. Although I know Mods point to forum announcements, many people do NEED to upgrade their operating system (or buy new fast computers with Mojave pre-installed to use new VW features?) As a result, most users I know DO NOT upgrade to the new VW until mid year, and also have to hold off upgrading their OS, thus missing out on security patches, performance tweaks, feature releases. Wouldn't it be better for Nemetscheck to stagger with Apple and release upgrades to VW mid OSX cycle? (release in april rather than october?) That way there would be adequate time for testing and compatibility trouble shooting?
Last year macOs High Sierra was released 1 week after VW2018 and it broke VW2018.
They should really email the whole userbase. not everyone has time to browse forums to figure out they shouldnt follow an upgrade path
Hi I'm wondering if Nemetscheck is testing VW2019 with OSX 10.14. Last year they didn't test it thoroughly and failed to advise VW 2018 users NOT to upgrade to OSX 10.13 and I had to downgrade VW after 1 week of release to keep working. I hope their business communications will be better this year.
Just do it in the document prefereneces
Bug - Renaming Sheet Layers when referenced in Title Block
B Cox posted a question in Troubleshooting
Hi all, I am running VW2018 sp4 on OSX 10.13.6. I have a title block that references the sheet layer name (and other metadata). If i type in "Window Details" as my sheet layer name, and then decide to type it in again but with different capitalization such as "WINDOW DETAILS", the sheet layer name will remain as "Window Details". For some reason VW can detect the string is identical and won't update it, despite the format change. My temporary workaround is give it a temporary name like "VW Bug Window Details" and then name it "WINDOW DETAILS" it can clear the problem. CAN ANYONE REPLICATE THIS BUG AND GENERATE A REPORT? -
Ok thanks. I feel like there was a period in march where no one was monitoring bug complaints on the board. Must have fell through the cracks then.
