cherie
72 -
Never
Everything posted by cherie
just send some pdfs to our print house. all text and just about every line has a shadow or grey background to it. what could be causing this? and it got worse when we had them do a half-size set. please help. cherie emac vw architect 10.1.2/osx.2.6
ok i spoke too soon. i played around with the "cut wood" object and got the wood grain option. can i use this with an irregular shape as in a trim profile?
sorry robert, i should have been more clear. i was looking for something that would show the wood grain to detail a piece of wood trim.
is there not a material fill for wood in this program somewhere? cherie vw architect 10.1/osX.2.6
great....thanks charles.
thanks for replying kristen. i'll try that.
can i then clip out portions of the plan that i do not need?
what is the best way to do enlarged plans? is it copy/cut/paste or is there a way to link this? cherie vw architect 10.1/osX.2.6
i've gone through the process for "create note database" in the architect user guide and created new sections for my notes and click ok. i try to go to the next step "add to note database" but that option is greyed out. cherie vw architect 10.1/osX.2.6
i just downloaded and installed the update but the vw version on my computer still says 10.1.0. cherie vw architect 10.1/osX.2.6
would that be the 10.1 updater or do i need to go back to 10.0 (that is the disc that i have)?
katie and jim...... thanx for the input. i will see what i can do. cherie
ok i deleted all doors and placed new ones. but i still get an item showing up in the schedule that i don't need anymore. is there a way to select edit that cell in the schedule?
i have a few door ids showing up in my door schedule that i long ago deleted. how can i get rid of these? cherie vw architect 10.1/osX.2.6
katie, i checked hp's website for the 650c driver but it is not supported on osX so, i downloaded the 755cm driver as you had suggested. i must be missing some thing because i cannot seem to find this option in print center when adding a printer. also, how would i go about adding a generic printer?
i just went to the microspot website and macplot pro does not support osX. are there any other option out there is this is what i need?
katie, turns out that each computer sharing the printer via rendezvous had to have the same version of the printer driver installed. it's working now. i had another question concerning .plt files. you had posted this on 2.21.03: (snip) "Creating a PS or PRN/PLT File PostScript and Plot or Print files are a way to print your drawing in VW to a file which you can then send to a service bureau for printing purposes. You will need a print driver installed on your computer that allows you to print as files. Generally, Post Script printers provide this support. A common printer driver we suggest is the HP 755 driver (PC) or PPD with LaserWriter or Adobe Post Script (Mac). This driver has not posed any major printing problems that we know of. Of course, it?s always a good idea to check with your service bureau to see what type of printer they will be printing to. If you know the printer they will be using, in most cases, you will able to install that print driver /PPD on your computer. If you are able to install the print driver/PPD file on your computer, you should use that option. If you can?t install it on your computer due to needing additional ripping software, the HP 755 should do the trick. Once you have the print driver installed on your computer, you will be able to Print to File from within the Print menu. Go to File>Page Setup. Specify the correct setting. Ensure the drawing reflects these settings. Then, go to File>Print. PC Users ? In the Print dialog box you should see a Print to File checkmark box somewhere near the upper right hand corner of the dialog screen. Checkmark this box. When you click on Print, a Save as dialog box will appear. Specify the full path name to where you want the file to be saved starting at c:\. Clicking on OK will generate the print file and save it to your computer per the above location. Mac OS 9 Users ? In the Print dialog box, you should see a drop down box that says Destination: Select File from the drop down box. When you click on Save, a save dialog box will appear. Select the location the file will be saved to as well as a name and click on Save. This will generate the print file and save it to the location on your computer you specified. OS 10 Users - In the Print dialog box there is a drop down box. Select Output Options. Checkmark ?Save as File? and set the Format to ?PostScript?. Click on Save. Select the destination folder you want to save it in and click on Save again." (snip) my print bureau told me to use the driver for an hp 650c (i've had a few problems with the pdf files there so i'm looking into other options). keeping in mind what you had said about creating a ps or prn/plt file, will i need to use macplot or something like it to make these files? also, before i've noticed that the postscript option in print/output options/save as file has been grayed out. why would that be? also any word on that buggy file i sent? cherie vw archiect 10.1/osX.2.4
i also got an "application unexpectedly quit" crash when i tried to select the hp color injet CP1700 printer in vectorworks.
katie, "When printing and crashing - what printer are you printing to?" hp color inkjet CP1700 & epson stylus color 800 (prior to today i had printed on the hp using vectorworks and i printed from the epson today from netscape) "When creating PDF files - are you using the OS pdf creator or are you using Adobe Distiller?" i'm using the 0S pdf creater (i tried 2 ways: print/save as pdf/save....and.....print/output options/save as file/pdf format/save. on this last option the postscript format was not hightlighted or i would have tried that route as well). "What do you have for the printer when printing to PDF?" either printer has been in the window in the past with no problems. i have sent pdfs to our print house before with the only problem being that the fonts were not what we had used. "What type of message do you get?" the application has unexpectedly quit. i'm crashing in every program now upon printing.
we are now having even more problems. my file crashed when prompted to print and when i sent them as pdf's to our print house they got error messages and could not print as well. when i view the pdfs i sent all sorts of info was missing. we cannot print out this job and we have a meeting in 10 min. and now, we are becoming more and more frustrated with this program because of all the problems we are encountering. i know others on this board have talked of a difficult adjustment period but this just seems a bit much. if things do not get resolved soon, we will have to look at another cadd option. we're just loosing too much production time. cherie vw architect 10.1/osX.2.4
i sent pdf files to our print house for plotting but when they came back our fonts we had used were not the same. is there a fix for this? cherie vw architect 10.1/osX.2.4
yes. i still have that drawing in a separate file. i do not want to create the rcp in my original drawing until the problem is worked out since i lost information on the plan after that (f.y.i.-the rcp is a problem on my computer, the wall join was on our other computer).
katie, we were having so many other problems that we just decided to do a clean reinstall of osX.2. after reinstalling vectorworks, everything is working as it should.
we are now having problems with the program on our other emac. the wall join tool has quit working. when trying to join 2 walls in a T or a corner, both wall will highlight but the small line that shows up when joining walls does not show up and the walls do not join. things i've done to this computer yesterday to try to clear up the problem: -ran disk utility -ran disk doctor -reinstalled osX.2 (archive & install): tried to upgrade to osX.4 but going through install process and at the point that you click the button to install, nothing happened. -ran dragster -reinstalled vw architect 10.0 and upgraded to 10.1 -ran disk utility again. my next option may be a full clean install of osX.2. any idea what is going on here?
