GVRT
15 -
Everything posted by GVRT
I often mirror boom units from one side to the other and am frustrated by the way that half top-hat accessories mirror across - flipping the accessory vertically (image attached) I currently use two versions of this accessory for SR and SL but am looking for a cleaner solution. Can anyone offer an explanation or a solution to this? Many thanks!
Hi Nikolay, Turning off text wrap completely works - thank you! Thanks for taking the time to have a look at it.
Of course, sample file attached. I'm using VW22 datatag sample.vwx
Hello, I've created some data tags for position labels. I've left justified the text of the label because the content is sometimes long, sometimes short. When I mirror it, I need the text to automatically right justify - is there a way to achieve this? See image attatched I currently use two data tags styles - left and right - to work around this problem, but it's very fiddly. Thanks in advance GV
Adding a specific number to the channel of an instrument
GVRT replied to GVRT's topic in Entertainment
Hi Sam, Without going into specifics, I'm working on some plots where using autonumber isn't possible. Otherwise of course I'd use that. If any of the vector script geniuses on here could suggest something I'd be very grateful! Thanks -
Is there a way to add (or subtract) a specific number from the channel field of a group of instruments? For example: selecting a group of instruments that are numbered 1 to 9 and adding 10 so they're now numbered 11 to 19. Maybe there is a vector script that can do this? Thanks
Brilliant. yet again! Thank you
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Hi Pat, I'm using VW2017 and Michael's script rotates multiple symbols around their individual insertion points for me. Your script behaves very strangely with multiple symbols. Sometimes it only rotates one of the selected symbols, sometimes it rotates one of the selected symbols but by double the angle that's specified. I'm still using your script because it can distinguish between symbols and other objects. The multiple symbol selection would just be the icing on the cake! Thanks
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Ha - I'm unaware of hierarchy! The bit that's really clever about Pat's script is that it can tell between a symbol and an object that isn't a symbol. That's why I'm using his at the moment. However, as I said, Pat's doesn't work like yours when multiple symbols are highlighted. I'm aware this isn't just a script order factory so I very much appreciate your guy's help.
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Thanks Pat, that works a treat The only thing your script still doesn't do, that Michael's does (who posted at the top of this thread) is rotating multiple symbols at once. Could that be incorporated into your super-script?! Michael's script quoted below:
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Thanks again Pat. One more question and then I'll leave you alone! With the version I've just made that rotates 45degs, is it possible for the symbol to stay selected so I don't have to keep on re-selecting the symbol to rotate it multiple times? Many thanks
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Thanks Pat, that is brilliant. I especially like that it can distinguish between symbols and other objects. Is it easy to make it rotate the objects by a set amount without the dialogue box? Many thanks
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Thank you everyone. Both scripts work now. Michael, your one is brilliant for working on multiple symbols. I have no idea why rotating around the insertion point when label legends are applied isn't default in VW anyway!
- 26 replies
- 1
- spotlight
- vectorscript
(and 2 more)
Tagged with:
Hi Sam, Thank you for this. I just tried running this script but it comes up with the errors shown in the attached image. Apologies I have no knowledge of scripting! Many thanks in advance for your help.
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
I’m using VW2017 with Spotlight and I use the ‘rotate left 90 degrees’ command as a keyboard shortcut a lot. I’d like symbols to automatically rotate around their insertion point but mine don’t when I’ve got a label legend applied to them. When the label legend is applied the symbol rotates around the centre point of the symbol and the legend combined instead. I've explored using a vectorscript to help here but haven't got enough knowledge to make it work. I've noticed when I insert a locus on top of the insertion point and highlight both the symbol and the locus, the symbol will rotate around the locus. Could a script: insert locus on insertion point, rotate left 90degs, delete locus? Many thanks in advance!
- 26 replies
- spotlight
- vectorscript
(and 2 more)
Tagged with:
