Mike Starobin
    3
Reputation
0 Neutral
Personal Information
  • Location
    United States
  1. Sebastian, It is set/enabled in File>Document Settings>Spotlight Preferences... Then you get 3 tabs Lighting Device-you can edit each Lighting Parameter(These lighting parameters will show up in label legend to be selected and Object Info Palette-OIP) Universe-you can edit the Universes in the show or leave as Manual (how I use it, then have Lightwright manage my Universe settings) Lightwright- You can edit/choose what is exchanged with Lightwright I use Lightwright to display my universe settings, as I changed them often to reflect what I am doing. My issue was the original file had rearranged all the Lighting Parameters and I did not see "address" as number/layer parameter 58. Normally it is 12 Hope this helps, the Lightwright site has info on this subject also. Mike
  2. Mickey, I figured it out. I was working on a drawing created by someone else, in that drawing the address label was 58, not 12. Thanks
  3. How do I add the Address field to Label Legend in Spotlight VW2018? All I can use is U Address Field
