Juay
33 -
Everything posted by Juay
Hi Scott, Thanks. I see where this is going so I have an LED wall with multiple circuits, I will have to plant multiple consume objects with the total wattage for each circuit in the said symbol to simulate it?
Hi all, does the power planning workflow work for the tools in Event design toolset like Video Screen or LED Screen? or does it work exclusively with lighting and custom symbol(as distributor) with consumer component in it?
Hi Bjoerka, I definitely waited for minutes on end multiple times without luck. didnt try to paste to a new file though. I have already tried to simplified the object quite a bit. in your experience how simple do it have to be? do you have a sample? thanks 😃
Hi all, I am remodelling some LED panel as the STP imports were too heavy to work with. I have modelled the important bits(mounting points) and ignore the rest. The last bit of this remodelling process was to create auto hybrids for all these objects My VW 23 and VW 22 is crashing when creating some of the auto hybrids in my file. Somome of the solid addition auto hybrid is created without any issues. The attached file has 5 auto hybrids and 5 that crashes. Hope there is someone kind enough to take a look and let me know whats wrong. URMIII Model.vwx
Hi, i was trying to use sling in my bridle and had issue adding it in. Does any one know what i did wrong?
Custom Data Tag with dynamic field(wattage to current)
Juay replied to Juay's topic in General Discussion
Hi Nikolay, Thanks for the help and explanation 😁 -
Hi Nikolay, Thank you so much. It does work! I notice that it is 'Power Requirement'.'Wattage' instead of #Power Requirement#.#Wattage#. May I know whats the rule for this syntax? -
Hi guys, I was trying to use a custom record format field(wattage) and do a simple math operation to get the current to appear in a data tag. #Power Requirement#.#Wattage#/230 This works and i end up with lots of decimal space. I am able to get #WS_ROUNDUP(numerical_value,0) working if i put a number. Anyone can point me how to put the math operation in?
Hi, on my drawing, i have a symbol comprising of autohybrid symbol in it lined up against another object when i create a viewport and scale it after. the alignment goes a fair bit off. any idea what is wrong? first photo is the aligned object. 2nd is the object in the viewport
Thanks Joshua. This helps!
Hi Joshua, Thank you. The 2nd option worked for me. seems like the workflow has to be tilt of the truss object after converting. Flipping the order around will mess it up, is that so?
Hi Mark, I supposed you are talking about the simplified truss class. Did that but still look the same though.
Hi all, I was exploring the schematic view and there is something i couldn't figure out. I had a truss that was at a 45 degree tilt, converted to a hanging position and had 3 fixtures on it. i created a schematic view and had the impression that it will remove the tilt and make it show the full length. However, it is the same length. Am i mistaken about it? the two attached image shows top/plan view and also iso view to show the tilt.
Hi Markdd, thanks for pointing out Annotations on sheet layer. That will definitely help.
Hi, is there a way to limit visibility of the dimension based on the axis they are on? for example on the top view, I wish to get rid of the lines of the dimensions I created for front or side axis
Hi, I cant recall what I did back on my Mac based VXW but recently I moved to windows and using the step as described(including modifying the empty array), I did get the import option.
Hi all, My Speaker Array tool Speaker setting has the import option to use non-generic symbols from the spotlight library My speakerArray tool Bumper setting is lacking the import option. I have already dropped the speaker bumper in the default folder and i just need to get that import button Is there any particular steps/setting for it to appear?
Hi Rob, So I presume that under the licensing, the 2017 library will not be made available to 2015 users even if we do a library update? I see where you are coming from in terms of being pragmatic in the model design. Aesthetic vs efficiency. Will keep this in mind as i continue in my practises. Thank you so much!
Hi Rob, I don't seem to see the file. I could have missed it. On the other hand, could it be due to the fact that I am running VW2015 and it is not included in my version? Appreciate the advice and knowledge you and Mark are providing. it really speeds up my learning.
Hi Mark, Thanks for the taking the time to look through my file and explaining the details! I will give it a go tomorrow first thing in the morning.
Hi Will, Thanks for the link, That is the same video that I saw and try to practise on. I tried to do the same thing except for the modelling part. Some how when i change it to a instrument the attached photo happens. My loci is shown as the center of the yoke arms. Somehow the head is still at the wrong position.
Hi all, Still picking up vectorworks spotlight and is trying to customise lighting fixture. My practise here is to import the Clay Paky DWG and make it into a symbol. When use Spotlight>Object Conversion>Covert to instrument, the 3D model main body of the moving light goes out of position. Does anyone know where I am doing this wrongly? ClayPakyMythos.vwx
