TEEM BEEZY
    3
Reputation
0 Neutral
Personal Information
  • Location
    Germany
  1. Hello everybody, Since I couldn't find a solution for my problem I would like to ask you to help me out. I want to preconfigure different tools with settings. For example I would like to edit the tool "move by point" tool to activate duplicates and set the amount of duplicates to 9. Is there a way to define these options with the "SetTool"-command in vwx script? I already discovered that the selector number for "move by point" is "-352" but I'm missing information to define all the extra options. Thank you very much. Tim
  2. hey guys, when moving grouped objects with the move (m) tool, some objects will remain at their original position with irritating lines (see attached picture). this happens quite often to me, when moving imported objects (e.g. 3DS). if i convert the group to a 3D-Symbol i can move them without any problems. do you a hint for me? maybe there is a option i'm missing while importing or converting the objects?! i'm using VWX 2018, but had this issue also with VWX 2017. best, tim
  3. Hey guys, I'm currently studying event technology so my software to go is VWX Spotlight. Quite often we receive ground plans of the venue as DWG files or even PDFs. These files are full of information which we do not need. First we have to clean all plans for our daily use which is really time-consuming. We move all unnecessary information to one class which is turned off - not deleted - because later we need maybe some information. To achieve this we have to make a lot of clicks to move the selection on one specific class, let’s say this class is called 00_off. Is there a way so speed things up and move the selection via marionette/script on that 00_off class? thanks guys for your help kind regards tim
