m.graf
135 -
Everything posted by m.graf
Okay good to know, but i only take numbers in names, to sort the input parameter for wrapper or objectnodes (such as 01_Input, 02_Input...) anything else only with simpel Text, without "ä,ö,ü,...@-*/&" greatings M.Graf
and here a simple solution for all angles between 0-360°, not a perfect solution - only one example for your next steps 🙂 if you take the "getvertex" node, take all the vertex(points) create all lines and then choose the longest line angle... ID script-freeangle.vwx
try this file... i have change the Nodes for the Input angle from "INT" to "ANY"... in your Network ID script-fix.vwx
Planar boolean creates additional, unexpected objects
m.graf replied to Grzegorz Krzemien's topic in Marionette
i can't (don't want) afford the trip to the Design Summit... we can meet in May... -
I love Marionette, but reported bugs should be fixed faster... we should meet to share our experience a little greatings M.Graf -
with the "set 2d vertex" node, here is a little example: smooth_Vertex.vwx
Solid Boolean node operation in the Marionette Object OIP
m.graf replied to Dmoozak's topic in Marionette
i change the script in this Node to: Sorry: "DIM" = Dimension, such as meter or inch. (Node DIM) "Marionette Network" = all connected nodes greatings M.Graf -
choose.vwx take a look at the script in this file (choose) the result from "popup node" is (0,1,2,3,4...) and you must add the DIM by script or with Marionette Network if choose == 1 Value = 2.135 -
try this spezial old "crit node" for menu 🙂 i believe the "criterium" by Popup (PIO?) will lost in new file or in Menucommand. Attrib_by_ClassName_v2019.vwx
i have build you a very simple "choose node" (VW2019) / this node works in Marionette objects try to open /edit the "choose node", it's very easy to change or expand the script. test_vw2019.vwx test_vw2020.vwx -
here the file in VW 2019 Attrib_by_ClassName_v2019.vwx
sorry, first i misunderstood your question: To set data you can try this IFC nodes. It is possible in "pSet Database" , other values in IFC_Slab such as Material / Component i didn't found a solution.
@Martijn Theunissen maybe my little tests (from last year) to get the "component_name" from Vectorworks Walls and Slabs helps you... to set your components. Last year i can't get other components value such as "vs.GetComponentWidth". you can find all other "Get or Set components..." here: http://developer.vectorworks.net/index.php/VS:Function_Reference if you get or set the other values please post it here. test.vwx
the node "enhanced rectangle" was created by Member "DomC", he create most of the best Nodes and Tools here. 🙂 the Enhanced Rectangle Node is much better then the normal Rectangle Node in VW @Admin - it's sad, that these node (and other new nodes) are not implemented in VW's - Node library! greatings M.Graf
- 3 replies
- marionette
- parametric symbols
(and 1 more)
Tagged with:
@Dishav Vasudev here are two simple starts that could help you ... 🙂 scriptstart.vwx
- 3 replies
- 1
- marionette
(and 1 more)
Tagged with:
here is my solution: more details you can find in the VWX File (wrapper) Sorry for the three screenshots, i have try to change the first one and got this result 😕 test.vwx -
@Andrew L "getWSCellValue" don't get text (string), you must take "vs.GetWSCellString" Greatings object_generator_v2019-MG.vwx
- 1 reply
- 1
Extra Outside Frame as Node Object or Command
m.graf replied to arquitextonica's topic in Marionette
it's getting better... here is some new stuff for you: 2d_to_3d_V2.vwx -
Rectangle to 3d and build the window for you... in the file is also a node for setting the hole in the wall you can also get the Wallthickness by Marionette, let my know if you want the script 2d_to_3d.vwx -
delete
