582 -
Everything posted by JustinVH
@michael john williams Are you using VW2021? In the Document Preferences there is a new feature called 'Save VGM Cache'. This is on by default and can cause the file size to increase. Turning that cache off should help to reduce the file size but will make file opening and navigating slower. I hope that helps.
@wadecordts I downloaded your file and set the corner up for you using the proper truss record and the auto connect settings that should apply to corner blocks. Without having a piece of straight truss to connect to the corner it is hard to confirm is all the settings are correct but testing using the corner appears looks right. I left your original symbol but duplicated it and drew it again to setup with the naming that would be used if I released this myself in the shipped VSS libraries. Use the symbol I circled in the screenshot as that is the setup symbol. If you have any questions or issues please DM me and I will be glad to help. Justin Setup XSF 20.5%22 truss symbols.vwx
v2021 - Speaker Array Hoists, Shackles, Stingers
JustinVH replied to Mark Aceto's topic in Entertainment
@Mark Aceto Those wire rope "stingers" are not in the content at this time. My recommendation is if you would like to add steel to the pickup symbol to duplicate the symbol and add the length of steel you desire as geometry. Just remember to change the offset in the SlingRecord and add the additional weight in grams. -
@Mark Aceto The 3D loci in the shackle is from the zNested shackle that lives with the new pickup symbols. They live on the NonPlot class and are there to take measurements from the pin and the apex of the bell(mainly put there by me to set the heights and insertion points of all those new symbols) when in wireframe. That is why the new hoist hook also has a 3D loci. The sling offset is measuring the distance from the center of the truss (that auto connect cross that cannot be hidden) to the top of the inside of the bell in the shackle, of course if the pin is up then that measurement is to the bottom of the pin where the next rigging point will connect. Keep in mind this measurement must be in mm due to the code of the record and I like to use 3 decimal places even though the field is set to use 1 place. The loci are on the NonPlot class so they can be turned off by the user. -
Vectorworks Manifesto - One Workspace to Rule Them All
JustinVH replied to Mark Aceto's question in Wishlist - Feature and Content Requests
@Mark Aceto The reason they are all in mm is because the code is in metric and all of our internal scripts for setting up the data are in metric. It makes it easier if both of the spreadsheets that are used for setup are using the same units and that is why the record in the RM is in mm even though the truss properties will use document units. However, an experiment was conducted late last year and it was determined that the RM record could be Imperial as long as the spreadsheet to setup the Braceworks part of the symbol was in metric. As a result, we made a change and decided to ship US manufacturers with Imperial units in the RM record and European, UK, and Australian companies with metric units for all future releases. You can see this change in some of the later XSF libraries and some of the new James Thomas and Tomcat libraries in 2021as they were released in the 2020 version after the decision was made. As new truss libraries are released you will see the preferred units for the country of use/manufacturer in the RM. -
@Alexey Trebukhin I have found that if you go into the OIP and choose 'Edit Accessories' you can then add additional clamps. You want to be sure to use the second mode though so that the extra clamps do not insert at the insertion point of the symbol but instead where you click them into the document. You may also have to go into a front or side view and adjust the clamp height to line up with the bottom of the base. If you make a custom symbol and add an additional clamp so that two attach in one symbol you will need to update the weight of the symbol.
@MattG Here is a file. Please note that the weight may not be exactly correct. If you want to change it note that weight is in grams and offset length is in mm. Truss Sling HUD.vwx
@Mark Aceto What is the width of the Tyler GT? Could the placement of the appropriate symbol in the Pickups folder be altered to work? I know it is not a sling but at least it is a pickup symbol.
CONTENT REQUEST!!!
JustinVH replied to Jacobtheld's question in Wishlist - Feature and Content Requests
@Jacobtheld If you are using Vectorworks 2020 the Roe BP2 is available in the Resource Manager in the Vectorworks Libraries>Objects Ent Video>Video ROE file. -
I believe the issue with not being able to apply a texture has been resolved. I was able to apply a texture using the render tab of the OIP using VW 2020 SP4.
- 5 replies
- 1
- straight truss
- texture
(and 1 more)
Tagged with:
@Haydenovative Not sure how to change the 3D fill as the geometry is generated from using the tool but you can assign a texture using the render tab of the OIP and choosing the texture that you desire. In my test I downloaded the Chrome texture and applied it successfully for renders.
- 5 replies
- 1
- straight truss
- texture
(and 1 more)
Tagged with:
@gmulder I took a look and I was able to fix your file and come up with a solution. The trick is to use the No Connection option on the flat base portion of the truss base when when setting up the truss info. Using the No Connection option will force the Auto Connect Engine to only use the Neutral, Male, or Female end of the symbol which will flip the symbol accordingly when placing on top of a piece of truss, this way you only need to have one symbol that can be used on both ends. In the file I have attached I set your base as a "No Connection" start and a "Male" end connection and the corresponding test piece of truss as a "Female" connection for both start and end. I did this as I saw you were using the gendered connections and decided to stick with that for you. Typically the conical connections that are on the H30V line of truss use the "Neutral" connection in the libraries that ship with Vectorworks as a separate coupler is used in the real world and is not actually placed into the drawing. I typically only use Male/Female with the shipped libraries if the end connections are welded onto the truss at the factory like you see with fork and gable style truss. I also tested with using "Neutral" on the truss and male portion of the base plate and also had success in getting the plate to properly connect to the top of the truss. If you decide to use other shipped H30V content out the Resource Manager keep in mind these will be using the "Neutral" connection and you will have to adjust them to Female/Female to use the base in your file. Let me know if you have any further questions. Justin Base plates 30x30 Fixed.vwx
@gmulder I will take a look at this, I think I have a solution that will work for you. I will post the file here is I have success.
Shiiping container model wanted
JustinVH replied to Cadplan Architecture's topic in General Discussion
@trashcan There are shipping containers in the Resource Manager in the Objects-Landscape Site>Equipment Shipping Containers file. There are multiple sizes and they can be connected together to make different structures. -
@MAURO I know it is not Marionette but if you have VSS the Litec Q30 product lines have been released as symbols and are available in the Resource Manager.
Lighting fixture does not look properly hung in 3d view
JustinVH replied to Sal's topic in Entertainment
That is normal for truss. The insertion point of all of the truss in the Resource Manager is bottom center when viewed from the side. It just happens that triangle truss in the point down direction puts the insertion point on the chord and not in between the chords. -
All of the truss that ships with the software in the Resource Manager has the insertion point at the bottom of the lower chord or Z=0. If you do decide to adjust the insertion point of the truss in the 3D component I would make a duplicate symbol first and do this in case any of the auto connect settings get messed up. -
@DCI For some reason your image file did not upload properly but I think I know what crosshairs you are speaking. Those crosshairs are the Braceworks connection points that show the center of the truss and the load from where calculations are originated. Unfortunately, they are hard coded into the structural data and are determined by the truss height and width in the Truss Properties dialog. If you look at the Truss Properties of that symbol you will see that the height and width are grayed out and cannot be edited. You can click the Change Cross Section button and make a custom cross section which will allow you to change the height and width but if Tyler does add the data at a later date you will have to manually assign the proper cross section to your truss in order to perform load calculations with Braceworks and the crosshairs will return to the original middle of the listed dimensions in the data. You can also insert the truss as a 2D/3D symbol instead of a truss object and this will remove the crosshairs but you will also lose the auto connect ability that comes with truss objects and will have to rely on the 2D and 3D loci for snapping. I hope this all makes sense
what is the model of this trellis?
JustinVH replied to diogo.kos's question in Wishlist - Feature and Content Requests
@diogo.kos Do you know the brand of that truss? There are nearly 20 different manufacturers of truss in the software. You can also use the Straight Truss tool and create a 30cmx30cm generic box truss if you are unsure of the brand. -
@trashcan A trick to help you align the 2D and 3D components of symbols is to make sure that while in the 2D component you enable the visibility of the 3D components. This allows you to draw right on top of the 3D and if your snaps are set correctly to snap to the 3D geometry. To enable the 3D visibility just make sure to show 3D in the "Show Other" dropdown in the Component Edit palette.
@Charlie Winter The only thing that I have found successful is to find the center of the base in Top/Plan with and place a 3D loci on this location. Then in a side view measure how far the 3D loci is from the beginning of the truss and then move both the the 2D and 3D in the base symbol by the appropriate distance. I believe the truss base symbol insertion point wants to be half the size of the truss box to the left of the center of the base. If you want me to check your file just let me know but I rarely get it right when I make the default content libraries so I just go into a side view and find the measurement and make the move. Justin
I agree with Scott. Definitely want to start with the base and build up and across. Also want to make sure that the base is set to vertical and the start connection is set to "No Connnection" so that the truss can only build in the up direction.
@trashcan Are these Vectorworks symbols or custom symbols? If you send me your file I can see what is the issue.
There are some truss pickups in the Vectorworks Libraries>Objects-Ent Truss>Truss Pickups folder in the Resource Manager. However, at this time they are setup as static rigging accessories and have no Braceworks or Auto Connect functionality.
Have you tried opening the gear icon at the top of the RM and choosing 'Refresh Libraries'? This usually solves that issue.
