Katerina
91 -
Everything posted by Katerina
I wish I wish ... Esc.
Katerina replied to Katerina's question in Wishlist - Feature and Content Requests
must add that I already use the select command on the ecs key, so I couldn't do more than one command as of yet. if I created this wish with vector script I have to click somewhere in the drawing to activate command. -
Hello busy VectorWorks people again I wish . . . . . . The Esc key could have the option ( somehow ) to exit out of a group or symbol ( if tapped twice or something )
shift key while cross selecting
Katerina posted a question in Wishlist - Feature and Content Requests
Hello busy VectorWorks people this is a past wish . . . . . . holding the Shift key while holding the Option key (to cross select) should add to selected objects and not remove any previously selected ones. it hurts to draw -
Interactive snaps
Katerina replied to Bruce Pittard's question in Wishlist - Feature and Content Requests
double wish. I think its a good method like you mention to overide and control the snap points you wish, because there could be more than one in the snap radius of the mouse. Visual Cadd also did this (but in a better way than AutoCadd). -
Now.... when we double click on an object it can be edited or opened. I wish, I wish....... If more than one object is preselected, and you double click on it, the 2D reshape command would activate. Usefull for stretching all the objects at once, and speedier detailing.
thanks Katie again, I found the new update. Just to let you know, I reinstalled VectorWorks from scratch and all problems I had are fixed.
I recently downloaded the VW10 updates for a mac (a few times), to reinstall Vectorworks alltogether. And I discovered that the room record, door etc.... pio's are PC files. Is this right?
I can deal with the problem for now, just wanted to let you know the problems that have been occuring. Thank you. problems: the message pops up every time I add new doors, windows or room tags (if the setting is set off for not included on schedule, then the message goes away, but the default is always true). It also appears when I copy pio's into a drawing. They are constant and many at a time, as there is one for each pio. I explode the drawing labels to change their font setting, for now.
Hi, Thank you for your help. The alert does not go away, after restart. and problems with these pio's This alert exists on other computers in the office aswell.
since vw10.1.2 update, I've been getting a message dialog that says: Room Record.txt was not found. when changing doors windows and room name tags any suggestions? the Room Record.txt file does exist in my plug-ins sub folders
Layer (class) window and better management
Katerina replied to Julien's question in Wishlist - Feature and Content Requests
wish 2 -
Multiple Duplicate Selection
Katerina replied to matto's question in Wishlist - Feature and Content Requests
I know you might be looking for something different, but if this helps you for now any try the Duplicate/Multiple command found on VectorDepot -
Vectorscript wishes
Katerina replied to arthur&l?on's question in Wishlist - Feature and Content Requests
not clicking anywhere in dwg to activate pallette tool same wish for me......I wished this on this list a while ago -
What is the point of the zoom line thickness command....
Katerina replied to BAZ's topic in General Discussion
down load the plug-in found on Vector Depot for zoom line thickness. A menu command that turns the preference on and off. I don't usually like to draw with the thick line weights for now, because my monitor is not good for it, but I use this command to make sure - I dont have thick or thin lines in the wrong places before I waste a plot. -
I have a problem here. Please add me to list, Thanks Mac OSX 10.2.4 PowerBook G4 VectorWorks Architect Renderworks 10.1.0 CarbonLib 1.6
a couple of little things I would change
Katerina replied to Tasfire's question in Wishlist - Feature and Content Requests
the nice thing about VectorWorks is the freedom to customize the program. most people do not like to work the same way, this is true so I picked up vectorscript to customize the program and then donate the tools to help others out if ever interested in scripting remember : dselectall; this written at the end of scripts will deselect everything if you wish to try scripting: you can download a script from VectorDepot (there are a few move and copy commands there) most scripts are not locked so you can edit them. and then add the word dselectall; in the script -
my finding : when in a group, in the beginning the snaps work fine, but then when I pan the screen while in a command - I then loose the snaps my work around : I exit group and then go back in
Eyedropper Tool
Katerina replied to Dan Kessler's question in Wishlist - Feature and Content Requests
I hear your pain. I am currently writting an eyedropper tool that solves some issues like : if it follows class than follow class and if not, follow what ever the referenced object's attribute's are. i'm still fixing its versatility. But it works great so far for most tasks. I will post on VectorDepot soon. but feel free to send me a message requesting the plug-in I've worked on it so far. -
Updating to VW10.1 The installer did not work properly with 3 computers in the office, because their machines have OS10 buried and are running Mac OS 9.2.2 currently. (a wrong doing of some computer consultant to us) Can I get these update files emailed to me so I can install them manually....or....can I replace their entire VW folder with one copied from my machine?
Hi Katie, Thanks for the response. That font worked fine in the drawing. I just replaced his entire plug-ins folder with the same contents as mine, and everything seems to work O.K. now. I think when his computer updated to 10.1, something happened. I had problems before updating 3 computers in the office that have OS10 hidding, and all 3 installations acted the same weird way. No clue what really happened, but I got it to work now. Thanks -
The Room Name tag can be set to current font settings. This works great on my computer, (using OS 9.1) but someone else in the office is having difficulty. (his computer OS system has been dissected by a computer consultant - burying OS10, while making Mac OS 9.2.2 working......could this be his problem? or is there something else I could do to help him?)
Thank you Katie for your quick response and help. The proper updates were installed. I used your instruction by manually selecting the folder. This worked. I think the problem is the operating system, as it could not find the folder on its own? We have a computer consultant that keeps trying to recreate the computer, and he is inconsistent with his settings. Thank you for your valued time.
Trying to update to VW 10.1.0 : While updating most computers in the office will get the information of the machine, like user name, company, and serial number. One computer will not get the information for the program. This is some kind of operating system problem? Do you know what files drive the installation update for a Mac OS 9.2? or is there another installation method available? This machine also had no problem updating to 10.0.1 (the first update)
redrawall procedure in scripts
then I wish - a redraw for recently affected items and immediatly surrounding model space. I have been adding a redraw in scripts but some foundatiion scripts need this too. -
I have written a script to share with humility to the masses. duplication by 1- preselection or not 2-referenced-base click points 3-relative data entry 4-***continuous multiple duplication*** send me a private email if interested
